What does the TPMS button do?
Discussion in 'Wheels & Tires' started by AndrewSmith, Jan 5, 2022.
  1. Jan 5, 2022 at 3:41 PM
    AndrewSmith
    AndrewSmith [OP] New Member
    Thornhill, Ontario
    2021 Sequoia Limited
    At some point I noticed that my 2021 Sequoia has a physical TPMS button to the right, under the steering wheel.
    I never needed to use it, I had the sensor IDs cloned for the winter tires.
    But I am curious what it does? It must have something to do with sensor programming, could it be for some kind of "relearn" feature?
    Thanks in advance.
  2. Jan 5, 2022 at 3:47 PM
    Randy F
    Randy F New Member
    2021 Voodoo blue tundra sport premium
    It's for tire rotations and learning new id's. It's in the manual.
    BravoDeltaRomeo and Taco-Spike like this.
  3. Jan 5, 2022 at 3:48 PM
    Taco-Spike
    Two Trucks
    Reset button. Rotating tires and such
  4. Jan 5, 2022 at 3:59 PM
    AndrewSmith
    Thornhill, Ontario
    Ah, so I might need to use it when I rotate the tires in the spring.
    I don't see it in the manual. Do you just press it once and it will do everything that needs to be done?
  5. Jan 5, 2022 at 4:01 PM
    Taco-Spike
    Two Trucks
    Yes. I do it when I start driving. Sometimes it takes a few seconds, sometimes it takes a few minutes :confused:
  6. Jan 6, 2022 at 7:53 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    It also resets the "normal" pressure. My truck had 20s and LTs from the factory...so "normal" pressure was 49 psi. Low pressure light would go on at 44 I believe.
    At one point I put passenger highway tires on, so my "normal" pressure needed to be 36 instead of 49. So put the new tires on, pressure up to 36 all around...then hit the reset button. The low pressure light would then turn on at about 32/33 psi.
    15whtrd and RitcheyRch like this.
  7. Jan 6, 2022 at 8:49 AM
    906UP
    906UP New Member
    Weird, I've had my truck 5yrs & a 100K miles, haven't ever touched the TPMS button thru countless rotations & 2 sets of tires
  8. Jan 6, 2022 at 8:51 AM
    RussellVaughan
    Houston
    you really don't need it for rotations unless you're rotating winter/summer tires.
    GODZILLA, BravoDeltaRomeo and 15whtrd like this.
  9. Jan 6, 2022 at 7:05 PM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    I never used it. I have always just made a habit out of taking 10 minutes every few weekends to check my own tire pressure manually and adjusting as needed. The couple times it did alert a low pressure warning I didn’t need it to tell me which tire was rapidly losing air, but was nice to have a warning before a complete flat.
  10. Jan 7, 2022 at 10:46 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Use it when off roading an air down, an when u air back up
  11. Jan 7, 2022 at 12:07 PM
    Ericsopa
    Ericsopa Old man and the sea
    For a '13 model, but probably the same function.
  12. Jan 8, 2022 at 4:37 AM
    AndrewSmith
    Thornhill, Ontario
    Thanks Mike!
  13. Jan 8, 2022 at 6:31 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Whatever you do, do not touch that button.
    Cpl_Punishment and Ericsopa like this.
  14. Jan 16, 2022 at 7:26 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Hoping someone can help me out with a stupid question on this, please. Since I put my winter tires on my truck, the TPMS hasn't worked. I don't necessarily need it but looking at the yellow warning light all the time is annoying.
    The manual says to turn the key to On then hold the button until the light flashes three times. But my light starts flashing immediately, before I can even hit the button. I've also tried the whole process of holding the button then driving for 30 minutes three or four times and nothing changes. Any thoughts?
    I'm pretty sure when I put my summer tires last spring the reset process worked flawlessly. I also didn't see the light last winter when I bought the wheels and tires from the dealership.
  15. Jan 16, 2022 at 8:33 PM
    Ericsopa
    Well, I'm not much help, since I've never had to use it. Not after rotations, not even after going up one tire size.
  16. Jan 16, 2022 at 9:40 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If the light is flashing immediately it is sensing a fault of some sort. Usually means a sensor is out of range (looking for your summer tires sensors) or one of your sensors is dead.
  17. Jan 17, 2022 at 5:33 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    :angrygirl:
    I think I have to get it in for an oil change soon. I guess the dealership can deal with it.
