New to me 2010 Tundra oil change question
Discussion in '2nd Gen Tundras (2007-2013)' started by Bozothedog, Dec 31, 2021.
  1. Dec 31, 2021 at 4:13 PM
    Bozothedog
    Bozothedog [OP] New Member
    Just picked up a 2010 Tundra SR5 Double cab, 5.7, with 114000 miles. So far….new tires, struts, front brakes(power stop Z36)and of course a modern Radio with a back up camera and all the car play features. I’m pretty stoked.
    Now for my oil change…I would like to start using synthetic oil in this vehicle. Any downside to switching from regular to synthetic that I am not aware of?
  2. Dec 31, 2021 at 4:17 PM
    Welcome from NY.
    No downsides to switching to synthetic.
    snivilous and GODZILLA like this.
  3. Dec 31, 2021 at 4:20 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    If the truck has had 0W20 oil its whole life, it has never been run on conventional oil.
    JLS in WA, GODZILLA and TTund16 like this.
  4. Dec 31, 2021 at 4:33 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  5. Jan 1, 2022 at 3:58 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    This is a MYTH, misconception, lie, or joke....... From the Mobil Oil website: "Synthetic oils typically provide better protection than conventional oils, but switching back and forth between full synthetic and conventional oil will not damage the engine."
  6. Jan 1, 2022 at 5:20 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Why can’t you switch back to conventional oil?
  7. Jan 1, 2022 at 5:58 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome.. Mobil1 is a good start... Pic of Rig?
  8. Jan 1, 2022 at 7:04 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I dont see how the age of the tech is relevant :)
  9. Jan 4, 2022 at 3:13 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    sounds like everything on facebook
    Ericsopa likes this.
  10. Jan 4, 2022 at 4:59 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Once you switch I would not go back. :plane:
  11. Jan 5, 2022 at 6:24 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Your question has already been answered, but to reiterate, it is not only an option to go full synthetic, it is much better for your engine.
  12. Jan 6, 2022 at 4:49 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  13. Jan 6, 2022 at 5:11 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Hey so in regards to oil change intreval. I run full synthetic. But the question I am asking myself is I have a newish to me 275k mile truck. I did an oil change. But now on the next oil change...should I go 10k or 5k? or should I for the first few do 5k and then go 10k? Also does timing on this matter? like ever 6 months etc?
    BTW I do get a slight ticking on really cold mornings form the engine that goes away in around 30 sec or so. This ticking btw happens rarely. I also do live down south so only on freezing mornings I have this issue.
  14. Jan 6, 2022 at 7:00 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Should always just follow manufacturers recommendations. These trucks should of been on synthetic the whole time since its such a refined weight of 0W20, 5W20. I would suggest using the 0W20 unless your physical conditions or engine wear is telling you its time for 5W20. The general rule of thumb on the intervals to change is every 5k miles which is the recommended change time.
    •If you do a lot of city driving, on/off cycles, fleet vehicle, idling or highway driving that is bumper to bumper slow speed stop and go traffic = 5k is you change interval
    •If you do a lot of just highway driving non stopped for long miles at a time, with not a lot of on/off cycles or stop and go traffic = 8-10k miles change is okay but remember to be checking oil if it looks like it needs the change then do it sooner
    •as for the 6 months change this really only applies if your not driving the vehicle long enough for it hit operating temperatures in short drives frequently. This can depending on the environment let the oil collect moisture that would normally burn off under normal driving conditions and operating temps.
    as for switching from conventional to synthetic in a non synthetic built engine (old) it all comes down to health and mileage if its a high mileage engine with baked seals theres a good chance switching to synthetic will show you were every small leak is real fast.
    as for switching from synthetic to conventional in a synthetic built engine it is not recommended as the shapes and refinery of the molecules differ and could cause poor oil flow or coverage in the tight tolerances in modern engines.
    Donut media did a few episodes on oils and the differences.
    baraynavab likes this.
