Poll - New 2022 Tundra Owners Please Post Comments on Real World Mileage
Discussion in '3rd Gen Tundras (2022+)' started by borla123, Dec 22, 2021.
Gas Mileage Expectation Gen 3 Tundra ? 17-city / 22 hwy /19 cmb (Votes can be changed later)
  1. I am achieving EPA ratings
    27 vote(s)
    27.8%
  2. I am not achieving EPA ratings
    70 vote(s)
    72.2%
  1. Jan 6, 2022 at 11:34 AM
    #91
    EvilSteve
    EvilSteve New Member
    2022 Lunar Rock Tundra Limited
    Definitely have the air dam installed and this works as you demonstrate.
  2. Jan 6, 2022 at 12:06 PM
    #92
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Nice!
    Maybe that accounts for the much better fuel efficiency TFL Truck got on their towing test up to the Eisenhower tunnel versus their results with various Ford EcoBoost engines.
    TK1979 likes this.
  3. Jan 6, 2022 at 12:49 PM
    #93
    Coal Dragger
    Kung Fu Dick
    I found that to be an impressive performance as well. Sweers said he wanted diesel like performance out of the new engine, and it seems they have achieved that.
    The comments of the TFL Truck crew about the Tundra not straining at the leash like an EcoBoost so to speak was funny to me. I get the feeling those guys don’t fully understand the difference in performance of a long stroke under square engine like the V35A-FTS, and shorter stroke over square engine like the 3.5L EcoBoost. The V35A-FTS did exactly what it was designed to do: make as much low RPM torque (and therefore horsepower at that low RPM) as possible. Just nonchalantly building power with no drama, no need for large engine speed increase, and minimal need for gear changes.
  4. Jan 6, 2022 at 1:53 PM
    #94
    cruising down the highway with no load at 1200rpm will not create boost. Turbos are always spinning. Quite fast even. But they are not always creating boost. They certainly are not creating boost in an unloaded small displacement engine in a light duty vehicle at very low rpm. Manifold air pressure during this type of driving will be negative or vacuum. Even at 2k rpm unloaded, likely still vacuum. Would love to hear some real world reports under these conditions in the new Tundra.
    Larly5000 likes this.
  5. Jan 6, 2022 at 2:00 PM
    #95
    Coal Dragger
    Kung Fu Dick
    Well our friend @xc_tc knows how to data log….
  6. Jan 6, 2022 at 3:45 PM
    #96
    xc_tc
    xc_tc New Member
    Unfortunately I didn’t measure cruising manifold pressures… I can imagine low torque operation would have wastegate fully open and not producing boost. I don’t have wastegate positions signals so I can’t check.
  7. Jan 7, 2022 at 9:56 AM
    #97
    68rs75z28
    68rs75z28 New Member
    2020 tundra sr5 dc
    So max boost on these engines are around 24psi? That is pretty crazy--and I guess not very high in today's world. Still pretty cool.
  8. Jan 7, 2022 at 4:24 PM
    #98
    mass-hole
    mass-hole New Member
    show us.
    Thats not how my Ecoboost works. Flat road at 55mph my truck is basically ambient manifold pressure at very low rpm.
    at 70 mph its in boost.
    And mine is an old 6 speed with 3.73’s. when you have a 3.31 axle with and very tall 10th gear, then the engine is gunna need to be producing boost to move the truck. 70 mph in 10th gear is only 1500 rpm.
    TK1979 likes this.
  9. Jan 7, 2022 at 5:36 PM
    #99
    Cool, show us
  10. Jan 7, 2022 at 5:44 PM
    #100
  11. Jan 8, 2022 at 1:16 PM
    #101
    barfree1960
    barfree1960 New Member
    16 sr5
    Mud
    2022 sr5 sport, getting about 17 mpg
    sd172 and Mattedfred like this.
  12. Jan 8, 2022 at 4:09 PM
    #102
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    TK1979 likes this.
  13. Jan 9, 2022 at 12:36 PM
    #103
    mountaingroan
    mountaingroan New Member
    Frank
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Long time lurker, first posting....
    Don't believe everything you read. Most of us here have had the Gen Is and Gen IIs and whether it's the 4.6, 4.7 or 5.7 the mileage is, and always has been, woeful. 20mpg is a wet dream. Anything over 18 is honestly, yeah, yeah. Yours is different! grin.
    Some can justify horrible mpg, I can't. I'll be drinking the TTV6 koolaid. I was never happier than when I was getting a legitimate 22-23 mpg with my T100 sr5 ext cab with 4wd and automatic.
    No excuse to not be getting 20's in this day and age.
    DeesCrewMax, raylo, TK1979 and 3 others like this.
  14. Jan 9, 2022 at 6:00 PM
    #104
    RoddersLV
    RoddersLV New Member
    Rodney
    Las Vegas, NV
    2022 Tundra DOA
    Regardless of one’s economic situation, I’d advocate $900+/year not burned is quite tangible.
    Mattedfred likes this.
  15. Jan 9, 2022 at 6:07 PM
    #105
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Power, longevity, fuel mileage. You can have 2 out of 3 in the real world.
  16. Jan 9, 2022 at 6:30 PM
    #106
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    Refer to post #123 - That TTV6 is indeed Koolaid
  17. Jan 9, 2022 at 6:46 PM
    #107
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    I’ll fill up tomorrow but I’m getting 16.5 mpg in eco, with really mixed driving. This tank had some long warm up idles as well and there are approximately 1200 miles on it. The next tank will be normal mode just to see if there’s a difference. Every vehicle I’ve had, eco always sucked.
    Henry1jg, TK1979 and sd172 like this.
  18. Jan 9, 2022 at 8:51 PM
    #108
    mountaingroan
    Frank
    North Idaho
    We'll see, but I don't expect a ton of objectively from a current late 5.7 owner. That isn't meant as disrespectful, just factual. I've met very few with late model Tundras that want any part of the new TTV6 truck. They are out there, just haven't met one.
    raylo and Toyota1234 like this.
  19. Jan 9, 2022 at 9:36 PM
    #109
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    There are lots of us… it’s just the anti gen 3 guys that bark the loudest. I can’t wait to get my gen3, improvement in almost every way over my 2.5gen
  20. Jan 9, 2022 at 9:54 PM
    #110
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    My first tank was 16.7, that was about half highway driving mixed with a lot of idling and a lot of 4x4 to and from work. Seems I could get 21-23 on a highway tank but in town driving I’m looking more around 15. Considering I drive 4 miles to Work I’m happy.
    TK1979 likes this.
  21. Jan 9, 2022 at 10:04 PM
    #111
    Rwaters
    Rwaters New Member
    Thats not bad. My very first tank was 21 and change, but it was highway and tollway mainly.
    To put my daily driving in perspective. I work nights, so I pick up (drop off in the a.m) both kids from school which is right down the road. Then I pick my son up from daycare in the next town, take the kids to my wife’s work a town west from there and finally head to work a town south from there. Of course it’s a straight shot home. So I drive a huge circle approximately 60 miles total three days a week.
    TK1979 and mountaingroan like this.
  22. Jan 10, 2022 at 6:07 AM
    #112
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    "You haven't met"?...You haven't looked to hard neither- The vast majority on this forum
    Good Luck!
  23. Jan 10, 2022 at 6:43 AM
    #113
    Kung
    KG, VA
    I would have absolutely no problem going with one of the new TTV6 Tundras.
    That being said, it's long been 'standard' that some avoid the first year of a major refresh due to potential issues that might crop up - and that's without supply chain issues being in play. That, plus the fact that the 2.5 Gen wasn't exactly a piece of crap (the 5.7 IS pretty dang reliable) and there are a few questionable design decisions with the 3rd Gen, mean at the very least that guys like me aren't exactly breaking our necks to trade our vehicles in ASAP, that's all.
    With THAT said, once supply chain issues clear up and they work out a few bugs, I'll have NO problems trading for a new one.
    TK1979 and jpod like this.
  24. Jan 10, 2022 at 7:33 AM
    #114
    68rs75z28
    2020 tundra sr5 dc
    Hell that sounds like my commute and I am getting 16 LOL
  25. Jan 10, 2022 at 9:09 AM
    #115
    mountaingroan
    Frank
    North Idaho
    Well, I know lot's of guys with Gen 2.5's but am new here so hopefully that's true, time will tell.
  26. Jan 10, 2022 at 12:34 PM
    #116
    TTund16
    TTund16 New Member
    My point was that some people including a friend with a perfect low mileage 2019 was talking about buying a '22 just for the gas savings!
    That's what I called dumping a perfect truck for a bad reason ...
    He told me he saves a lot of gas money! But based on the trade numbers he gave me, it would have taken him more than 20 years to recover the trade loss, fees, taxes, etc. (based on the $900 annual gas savings). I think he changed his mind after that! :D
    I told him if you want a new car, buy it. but don't fool yourself and justify it with a little gas savings.
    GODZILLA, TK1979, JLS in WA and 2 others like this.
  27. Jan 10, 2022 at 12:54 PM
    #117
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Mine gets better MPG in non-freeway driving with 35x13" Hankook ATMs than the crappy Bridgestones it came with.
    If it's the same tire design, a bigger tire will have less rolling resistance. In my case I went to a much heavier AT and still get better MPG. Aerodynamics are going to suffer though, especially if you get a lift.
    Most ATs have crappy rolling resistance as well, but the Hankooks are good. Since there very few actual tests I think the best proxy is to look at speed (temperature) rating. Falken AT3W are another good pick.
    TK1979 likes this.
  28. Jan 10, 2022 at 12:57 PM
    #118
    68rs75z28
    2020 tundra sr5 dc
    I totally get this... I wish they made a tundra prime.
    My rav4 prime is paying for itself quite quickly with gas prices where they are compared to the subaru I traded in on it. 24 vs basic 9999999.99 with my wife's commute on all electric(we had excess solar so it is -free- since I oversized the system for other future needs that we won't be doing anymore)
    It will pay the difference within 70k miles versus say a base rav4.
  29. Jan 10, 2022 at 12:58 PM
    #119
    mass-hole
    What year is that truck. Does it have a 10 speed and 3.31's?
  30. Jan 10, 2022 at 12:59 PM
    #120
    68rs75z28
    2020 tundra sr5 dc
    This is so wrong... it is amazing the mental gymnastics you used to try it make it right.
    A bigger tire will ALWAYS get worse than a smaller tire since it takes more energy to turn that larger tire.(weight)
    A bigger tire has lower rolling resistance? Uh no... that is why you put bigger tires on it.. for better traction/better contact patch.
    DexterL, DeesCrewMax and TK1979 like this.
