  1. Jan 6, 2022 at 5:48 AM
    60ish or less is where you get better gas mileage. Not a vehicle design issue, an aerodynamics issue. Somewhere over 55mph is where wind resistance really starts to cause significant drag on the vehicle. The faster you go, the harder you have to fight the wind resistance. And it has a bit of an exponential effect. Even a few more mph takes a lot more power to overcome. If the truck was tear drop shape it would be more effective at slicing through the wind and yield better high speed efficiency.
  2. Jan 6, 2022 at 5:52 AM
    I drove to Florida Tuesday and kept it around 75mph most of the way. I averaged 15-16mpg. We get worse MPG with winter blend gas right? One thing I noticed is that for the first 3-4 hours my trans temps wouldn't get above 118 because it was so cold out. I need one of those thermostats for the trans cooler apparently.
    Voss likes this.
  3. Jan 6, 2022 at 6:00 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    That right there is a damn miracle. I had to send two back and gave up and drove the hour and a half down to Summit to pick one up in person. Should have just done that the first time knowing how many folks had broken tube necks and inlets.
    CodyP[QUOTED] likes this.
  4. Jan 6, 2022 at 6:13 AM
    daveeasa
    I still need to figure out how to get scangauge to tell me trans temp. All my attempts at entering codes have failed to report anything useful. Might you happen to have a link to something new I can try next time?
  5. Jan 6, 2022 at 6:19 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Ahhhh thats the one! haha
  6. Jan 6, 2022 at 6:24 AM
    There's a whole forum for that out there. Supposedly you can increase your mpg up to 13% with one of these aerodynamic shells...
    https://ecomodder.com/forum/showthr...aps-aeroshells-ecomodder-elsewhere-23775.html
  7. Jan 6, 2022 at 6:25 AM
    I can't help with Scangauge unfortunately. I use OBDII and the Torque Pro app.
    daveeasa[QUOTED] likes this.
  8. Jan 6, 2022 at 6:37 AM
    you have to lower the vehicle also, that shell alone won’t do much. It’s about the competition between the air moving above and the air moving below the vehicle. Also smoothing the path below the vehicle to help with the air movement. Skid plates for the win!!
    RUSTYNUTS and chrisb like this.
  9. Jan 6, 2022 at 7:35 AM
    EvilMilkshake
    05 AC Limited 4x4
    Sorry to hear. Hope you weren't hurt. Looks like you rolled it down the ditch? Sad ending to a lot of sweat and hard work.
  10. Jan 6, 2022 at 7:58 AM
    If you managed to get it in that pristine of condition, AND it's not a counterfeit, you really need to go to the store and buy 10 lottery tickets today. If you win, please consider contributing a meager 5-10% of your share to my retirement. I stopped trying to ship radiators, odds are not even 50/50 you'll get it undamaged unless the warehouse is extremely close by.
    I thought the 2.7 also had a belt, and there was a change somewhere around the 2000s? You're the Toyo mech, so I trust you, just curious if this isn't the case. It's just what I've got in the back of my head.
    It's always been a curiosity of mine why the 2.7L is much closer (almost identical) to the 3.4L in MPG, and the 2.4L stands so much farther away from both. 0.3L displacement isn't significant enough to result in a 20-30% MPG boost in my mind.
    I think I saw where you showed this. I've been thinking about it, if for no other reason than to stop by damn keys from slapping the dash on bump roads, which in ATL, is pretty much everywhere.
    Yup. Ever since I moved to ATL, I just make the 30ish minute drive south to Summit @ McDonough any time I need a radiator. Buy online when a discount code comes up, then run down there to get it.
    A lot of people claim you can gain 1-2MPG just from adding a tonneau. I guess I'll be testing that theory soon.
  11. Jan 6, 2022 at 8:13 AM
    EvilMilkshake
    05 AC Limited 4x4
    Darkness likes this.
  12. Jan 6, 2022 at 8:32 AM
    Darkness and Abos like this.
  13. Jan 6, 2022 at 8:36 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    You guys are making me nervous now lol. I’ll have to go over it with a fine tooth comb to make sure there are no cracks by any inlet/outlets.
    I believe the shipping gods are on my side as I basically am on UPS/FEDEX’s route everyday. Sometimes they slow down in front of my house only to realize they don’t have a package for me which doesn’t happen often at all. Lol
    bmf4069 and shifty`[QUOTED] like this.
  14. Jan 6, 2022 at 8:45 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The balance shafts eat efficiency due to parasitic drag
    chrisb and shifty`[QUOTED] like this.
  15. Jan 6, 2022 at 8:53 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
  16. Jan 6, 2022 at 9:40 AM
    T2ndLife
    T2ndLife New Member
    JD
    '02 4.7L 225K 4WD Ext Cab
    WIP - keeping stock Kenwood DNX9960 GPS Nav/Stereo NexD XD400/4 400W Amp Wood Trim package added 4Runner alloy 17 inch wheels
    There is "HazMat" and a separate "ORM" other regulated material category. Technically they were likely answering is it Hazmat? (No). But highly possibly ORM, not requiring a HazMat label. Been a few years since I was HazMat handling certified, but I wouldn't think that basic difference has changed.
  17. Jan 6, 2022 at 9:51 AM
    daveeasa
    I skipped that endorsement on the CDL testing b/c I figured since I'm only ever hauling horses I don't have to think or care about hazardous materials. That and tank stuff, seems like real trucking. Though air brakes (or maybe brakes in general) are not a strength yet, don't really feel like I could fix anything on the road with duct tape in a pinch.
    T2ndLife[QUOTED] likes this.
  18. Jan 6, 2022 at 10:10 AM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    ORM classification/labeling for low qty went away/changed for start of 21. They changed the labeling and rules overall to be more relaxed than previously. Now its just covered under Limited Quantity provisions under CFR title 49 from what i was digging last week (ive been out of daily shipping for years as well)
    NUDRAT, daveeasa and T2ndLife[QUOTED] like this.
  19. Jan 6, 2022 at 10:53 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I also asked if I needed to mark anything else and they said no just to clarify. Standard package
  20. Jan 6, 2022 at 11:02 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  21. Jan 6, 2022 at 11:05 AM
    I guess if you're single and out to impress, possibly a lot.
    If you're stuck in an endless pit of a marriage with no way out, maybe not so much.
    Also, when you reach a certain maturity in life with nothing to look forward to except maybe death, I'm willing to bet you probably don't care at all.
    Voss, bmf4069, txagg and 4 others like this.
  22. Jan 6, 2022 at 11:09 AM
    alb1k
    Left Coast
    It's good
    Or...all of the rear visibility and half the room of a standard top?
  23. Jan 6, 2022 at 11:25 AM
    oscardog86
    Southern California
    Such a funny post! had me chuckling at my desk at work
    alb1k and Jack McCarthy[QUOTED] like this.
  24. Jan 6, 2022 at 12:30 PM
    Am I the only one who heard the M*A*S*H theme song while reading this? :rofl:
    Jack McCarthy[QUOTED] and alb1k like this.
  25. Jan 6, 2022 at 12:32 PM
  26. Jan 6, 2022 at 3:26 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Got my desert does it seat jackers installed after yesterdays fail. Bought a couple of new bolts and chased the threads. Still don't have all my energy back from the chinaronavid, but not near as taxing as yesterday's try. Have not driven in the truck yet, but initial impressions aren't great. Seems to boost me up too high, maybe half or a third as much of an increase would be better. I will really have to lean down to see stop lights, wasn't the case before. I am 6'3 and have leather buckets for reference.
  27. Jan 6, 2022 at 3:30 PM
    alb1k
    Left Coast
    It's good
    I was thinking half the distance would be good on my Gen 1, but I think bolt heads would overlap. The more I drive the more I like it, but I'm 6'0"
    txagg[QUOTED] likes this.
  28. Jan 6, 2022 at 5:17 PM
    Damn, I was getting ready to come here and tell you that was a hell of a lot of hard work, good job, etc. Then I saw the end. WTF.
    I don't see anywhere in your posts, nor in the vid, nor YouTube comments about what happened. Were any of the dogs with you in the accident, and were they OK too? The pup still shots toward the end made it feel a little memorial-ish.
    I got really nervous towards the end because I didn't see you put in that last cotter before the wheel went on. I was relieved you finally got there :D
    oscardog86 and FrenchToasty like this.
  29. Jan 6, 2022 at 5:19 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I feel the exact same. I wonder if the rear risers would give the better seating option instead of the front being jacked up so high.
  30. Jan 6, 2022 at 5:20 PM
    alb1k
    Left Coast
    It's good
    I think you will feel higher, then you are really moving your butt up
    CodyP likes this.
