Towing trans tests
Discussion in '2.5 Gen Tundras (2014-2021)' started by Creepbam, Jan 5, 2022.
  1. Jan 5, 2022 at 8:28 AM
    Creepbam
    Creepbam [OP] New Member
    2020 SR5 4x4
    I have a 2020 CrewMax 4x4. Currently running 5w30 oil.Reading all the threads related to trans temperatures on the non cooler models, I thought I'd try some stuff
    Outside temperature was 88-92 F towing around 3000lbs of side by side. The tow was 10.5 hours around 70 mph on slightly hilly Texas country. Slight headwind.
    I drove with tow haul in S4 per owners manual. Trans and oil temp never exceeded 218 degrees. RPMs were around 3k. During this trip when I would get to a flat stretch I'd push it up to s5. Trans temp and oil temp would almost instantly go to 225-230 and hover around there.
    On the return trip post cold front. 35F temps resulted in 205 Trans temp
    Some things I've read on this forum the 218 temp isn't too far off from what some user are getting towing with factory cooler.
    Just throwing this out there for some data for you guys. Keep her and s4 when towing and those insane Trans temps you hear about don't seem to happen.
    panicman, LS3, Cpl_Punishment and 2 others like this.
  2. Jan 5, 2022 at 9:04 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I hate the idea of 3K rpms for extended periods, but oh well....
  3. Jan 5, 2022 at 9:12 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    302 I believe
    2mchfun and ColoradoTJ like this.
  4. Jan 5, 2022 at 9:12 AM
    Unclebuck
    Unclebuck New Member
    2018 Crewmax SR5 TRD Offroad
    Is that for fuel consumption? Running in mid 3k is nothing on this engine and tranny.
    Y0TA PR0 and AZBoatHauler like this.
  5. Jan 5, 2022 at 9:13 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    The owners manual does not tell you to tow in S4...there is one specific situation they suggest towing in S4.
    sask3m and ColoradoTJ like this.
  6. Jan 5, 2022 at 10:02 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    While technically speaking this is true but the manual does say not to tow in “D”. I have been dropping a gear with towing and/or while carrying heavy loads since I owned my 89’ 4Runner. Seven Toyota trucks later never had a blown engine or transmission (knock on wood) due to it. The 4Runner needed a head gasket as 475k though…. If done properly it will simply not damage a thing.
    And @Johnsonman you have nothing to worry about the engine running a 3k except how your going to pay for the extra gas ;)
    tundratoofun likes this.
  7. Jan 5, 2022 at 10:06 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Do yinz mean to tell me I could've kept my '19 PRO by staying in S4 instead of selling it before the transmission exploded in a conflagration that would vaporize everything within 300 yards?
    f*ck my life.
    Piki, Ericsopa, bflooks and 2 others like this.
  8. Jan 5, 2022 at 10:18 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Gosh I must have missed that. I thought I had read everything on towing. Do you have a screenshot where they tell us to not tow in Drive?
    AZBoatHauler likes this.
  9. Jan 5, 2022 at 10:27 AM
    303Tundra
    303Tundra New Member
    Denver
    2021 Tundra Platinum
    I have a 2021, so I was curious about this and read through the manual. The spot where it mentions 4s is a bullet point about engine braking efficiency.
    "To maintain engine braking efficiency and charging system performance when using engine braking, do not use the transmission in D. Transmission shift range position must be in 4 in the S mode."
    I'm thinking that means they're recommending to use 4s when wanting to engine brake. Very well could be understanding it wrong though.
    ColoradoTJ likes this.
  10. Jan 5, 2022 at 10:28 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    No I do not, however why is the exact statement that you posted from the manual (and the same exact statement I was implying) is under the towing section? The reverse here is where does Toyota state you can’t tow in 4S? If it were in a different section I would tend to agree but it’s specifically under towing hence why I said technically…
  11. Jan 5, 2022 at 10:36 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    That statement I posted is specifically for if you are using "Engine Braking" and does not apply any other time.
    ColoradoTJ and 303Tundra like this.
  12. Jan 5, 2022 at 10:39 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Sure, but if everyone sees lower temps in S4, why not use it? As @Oey12 says, it doesn't say not to tow in S4.
    Unclebuck and Oey12 like this.
  13. Jan 5, 2022 at 10:41 AM
    303Tundra
    Denver
  14. Jan 5, 2022 at 10:41 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    I completely understand that, but again it’s under the towing section. Which would suggest to a owner to use engine breaking during towing, meaning it’s safe in my interpretation. Even though it’s intended cause is not to lower transmission temps
    Cpl_Punishment likes this.
  15. Jan 5, 2022 at 10:43 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Can't help ya. Carry on.
  16. Jan 5, 2022 at 10:45 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    That section just states that, while towing and while using engine braking, don't use D. Nothing more or less than that.
    Elsewhere in the towing section, it states "Before towing depress TOW/HAUL button." No where in the "Before towing" section does it state which transmission setting to use (or not use). It leaves that open.
    But I do agree it's not a well written section. This is why I contacted Toyota and asked the question. The e-mailed response that I received stated that you use T/H in D while towing unless using engine braking, in which case you use S4. However, for my personal needs while towing, I generally use S4 and S5, depending on the hills and such.
    Toyota is a bit of a mess though on this. If someone else contacts Toyota and asks the same question, it would not surprise me if they would receive a different answer.
    Oey12 likes this.
  17. Jan 5, 2022 at 10:47 AM
    AZBoatHauler
    So.Arizona
    I’ve been driving mine this way since new towing 6,500lbs up 8% grades and it runs like new 5 years and 65k later. 3k RPM isn’t screaming and it gives you way more power than 2k RPMs. Lugging an engine seems far worse than letting it run.
    My boat turns 4.2k rpm on slalom runs. :anonymous:
    2mchfun, Cpl_Punishment and Oey12 like this.
  18. Jan 5, 2022 at 10:52 AM
    68rs75z28
    68rs75z28 New Member
    2020 tundra sr5 dc
    Yet we have people reporting that EMPTY.
    My truck reported 215 degrees with an EMPTY load on a 100 degree day.
    With a cooler? Never over 195 EVER even loaded.
    2mchfun and sask3m like this.
  19. Jan 5, 2022 at 11:18 AM
    S4 is a 1 to 1 ratio in the Tundra with converter lock up. This will give you the lowest transmission temps (as people are seeing on here). Fuel economy suffers a bit for sure. For a 2019-2021 Tundra truck with the puck heat exchanger it might be a better way to tow when around 6-8k lbs.
    I did a couple short videos on how if a truck can stay in converter lock up, trans temps really don’t change much.
    Towing 9k lbs in 78* heat, mountain terrain. In 5th gear, converter lockup.
    Almost at destination at 85* ambient temps. So not a fair comparison since the Allison can lockup in 2nd gear, but I tried to keep it in 3rd gear. This dirt road is rough and steep. In the short distance trans temps went up from 140* to 162*.
  20. Jan 5, 2022 at 11:28 AM
    Creepbam
    2020 SR5 4x4
    I didn't mean to start a pissing match on to tow in s4 or not. Just stating what I found by towing that way. I also had a "absolute engine load" Guage on OBDFusion and while in S4 it was significantly lower than when S5 was used.
  21. Jan 5, 2022 at 12:14 PM
    It really isn’t a pissing match. If I owned another Tundra in the 2018 or older model, I would tow in D/TH mode and shift to S4 and lower for steep grades for engine braking. I rarely towed under 7500 lbs with my 2nd Gen and I was in 3rd and 4th gear most time anyway with the motor singing away at 2800-3800 rpm all day long.
    Now if I owned a 2019-21 Tundra and towed 7k or more, my first upgrade would be the factory upgrade back to 2018 and prior years. When a Toyota Engineer totally recommended doing this mod, all I need to know.
  22. Jan 5, 2022 at 5:42 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Is now a good time to point out that the manual says not to exceed 65 when towing?
    Oey12, GODZILLA, JDR76 and 2 others like this.
  23. Jan 6, 2022 at 4:06 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I resemble this remark.
  24. Jan 6, 2022 at 4:44 AM
    glowblue
    glowblue From time to time
    VA
    You didn’t start a pissing contest, it’s been raging for a while on this forum. @hagrid is the resident transmission temperature guru and can provide counseling and therapy for those transmission temperature blues!
    GODZILLA, ColoradoTJ, hagrid and 2 others like this.
  25. Jan 6, 2022 at 4:46 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I come here for the @hagrid wisdom.
    it is the comic relief to the Tundra epic.
    Ericsopa, GODZILLA, hagrid and 2 others like this.
  26. Jan 6, 2022 at 6:32 AM
    blanchard7684
    blanchard7684 New Member
    S4 is indeed a good mitigation for high trans temps while towing. With 4.30 gears and the shift changes, the lock up is maxed and this is why the temps drop. Combined with 3k engine rpm and highway airflow the engine coolant is circulating and removing more heat as well.
    JDR76 and hagrid like this.
  27. Jan 6, 2022 at 9:41 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    When are people gonna wise up and start using liquid helium to pull heat out of the converter?
  28. Jan 6, 2022 at 6:36 PM
    glowblue
    VA
    My transparent aluminum idea is better, I just submitted a patent application for it.
  29. Apr 21, 2022 at 6:11 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    So i finally did a camping trip with my scanner installed the whole time. Trailer on the scales weighed 4380lbs. Truck had approx 300lbs of cargo in bed. 2010 model with external trans cooler. I used to tow exclusively in S5 and enjoyed amazing fuel mileage of 13-14.
    towing in S4- trans temp 203-204 (TC) consistently
    towing in s5- trans temp 210-218 (TC)
    Both on flat freeway at 65mph.
    The extra rpms took 1mpg off the mileage, however im thinking the lower trans temps will be worth it in the long run. The temp never once pegs above 204 at the TC in 4th gear. Its constantly shifting in 5th more than i would have assumed.
  30. Apr 21, 2022 at 7:04 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I installed a cooler in my 2021 400 miles after purchase. I intially saw trans temps of 220F unloaded going over bridge in Houston lol. Installed cooler, 74 mph pulling 5500lb boat to FLA from Houston, trans temp never got above 203F. That is in 5th gear and many times D. Only reason I didnt keep in D all the time was sluggish throttle response. WIth no load trans temps never gets above 195F. I was averaging about 11.5 mpg. Surprisingly even in very heavy rain events the trans temps didnt drop but a degree. Truth be told I dont even know I can read my trans temps anymore as I havent checked in over a year and forgot how to do it after cooler install.
    Hbjeff likes this.
