Gen 3 OBD2 data logging
Discussion in '3rd Gen Tundras (2022+)' started by sd172, Jan 5, 2022.
  1. Jan 5, 2022 at 8:31 AM
    sd172
    sd172 [OP] New Member
    South Dakota
    2021 Sequoia Nightshade
    Ha anyone used an OBD2 reader in the new Tundra? Mostly interested in long drives city/highway and max/average temperatures such as coolant, engine oil and ATF.
    Here’s an example of my 2021 Sequoia driving from Sioux Falls to Omaha on December 14:
    And Omaha to Sioux Falls:
  2. Jan 5, 2022 at 9:06 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Its all so Cool yet what to do what the data?
  3. Jan 5, 2022 at 9:17 AM
    sd172
    South Dakota
    Temperatures correlate with fluid change intervals. Some of the more modern vehicles run hot (212 plus on coolant and oil) and that degrades fluids quicker than the manufacturer recommended change intervals. I wonder how Toyota solved cooling system and what to expect when changing your engine oil and ATF.
