Probably very dumb question re: wipers
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kung, Jan 2, 2022.
  1. Jan 2, 2022 at 4:17 AM
    Kung
    Kung [OP] [Insert Custom Title Here]
    KG, VA
    So, like a complete dumb@$$, I forgot to pull up my wiper blades yesterday before a minor winter storm started…and then pulled up a little TOO hard when they froze to the windshield. As such, the wiper “broke.”
    Specifically, if you look @ the OEM wipers, the part that’s broken is the little cap on the end the wiper blade arm fits into; it has a small Toyota emblem on it.
    My question - I assume this isn’t necessary for installation of a new set of wipers? I’ve searched everywhere and am pretty sure it’s not but I’m not 100% clear.
  2. Jan 2, 2022 at 6:40 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Photos might help us assist you... but it seems like the cap is just to protect the blade itself. As long as your arm isn't bent (assuming it isn't), then you can just get new wiper blades?
    Kung[OP] likes this.
  3. Jan 2, 2022 at 6:48 AM
    18" TRD Off Road Wheels
    As stated, pics will help.
    As for avoiding in the future, fire up the truck and hit the heated mirror/rear defroster button for a bit before trying to move the wipers. https://www.tundras.com/threads/heated-windshield.69173/
  4. Jan 2, 2022 at 7:24 AM
    Kung
    KG, VA
    I did…but obviously either not long enough, or I’m stronger than I think. I’ll assume both. ;)
    As for the pic, sorry, I thought I’d attached it. It’s the little cap at the end with the Toyota symbol. (Icy as hell out there.)
    Brownsfanhere and Jackstraw like this.
  5. Jan 2, 2022 at 7:29 AM
    Flex them guns! :muscleflexing:
    Mater and Kung[QUOTED][OP] like this.
  6. Jan 2, 2022 at 7:57 AM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    The same thing happened to me over the summer driving across the country and though I could seem to fix it by realigning it all the blade fell off again every time I tried them anyway.
    I needed new blades and there are 2 kinds of OEM evidently.
    I have read that the older style which are twice as expensive are the real deal and a lot better than the newer cheaper ones and they had both at the Toyota Dealer in Bozeman and I bought the expensive ones,they are great now!
    Did you get bad ice down there ,we sure did after it rained all day long!
  7. Jan 2, 2022 at 8:08 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    If you have the original blades that came on the truck when it rolled off the assembly line you can simply get replacement blades which cost typically 7 to 10 bucks. These are the “expensive” ones…
    If you get the Toyota Sightline then you have to replace the entire wiper every time.
    OP I would replace the whole thing with the NON Sightline because it’s simply cheaper and they work 10 times better in the long run…
  8. Jan 2, 2022 at 8:16 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Does anyone have the part numbers for the OEM non-sightlines? I bought the sightlines thinking they were the right ones.
  9. Jan 2, 2022 at 9:45 AM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    I’m impressed with Trico Titan blades on our trucks. Best I’ve experienced to date.
  10. Jan 2, 2022 at 12:34 PM
    Kung
    KG, VA
    I ended up getting a set of Bosch Icons; they went on just fine. :)
    pvn.beluga and Lovetrucks like this.
  11. Jan 2, 2022 at 1:40 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Costco always has sales on Goodyear Wiper blades... honestly, for the price they sell it at ($6.99 - limit 4) they work fine to be replaced every season.
  12. Jan 4, 2022 at 10:45 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Bosch icons have been the best wipers I have used so far on the Tundra, and I have tried a few- rainx, trico, etc.
  13. Jan 4, 2022 at 10:48 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Isnt the consensus now that you should not put up your wiper blades since it puts stress on the springs and may deform the wiper and cause them to not sit flat?
    I usually just take a cup of hot water outside after a storm and gently pull up on them as i pour.
    WILLINH likes this.
  14. Jan 4, 2022 at 12:59 PM
    Kung
    KG, VA
    Yeah, you're probably right - next time I'll likely just put socks on the wipers and cover with a throw blanket or something. LOL
  15. Jan 4, 2022 at 2:26 PM
    MadMaxCanon
    Just last week when i spent 20 minutes cleaning the car after a snow storm, i was considering throwing a moving blanket over the cab or something, assuming there is no wind lol. Might try it.
