Bed Drain?
Discussion in '3rd Gen Tundras (2022+)' started by WasAChevy, Jan 2, 2022.
  1. Jan 2, 2022 at 3:22 PM
    WasAChevy
    WasAChevy [OP] New Member
    Does the composite bed have a drain hole(s)?
  2. Jan 2, 2022 at 6:57 PM
    BlacknWhite23
    BlacknWhite23 New Member
    2021 Black TRD Off Road
    The Tacoma did. FWIW
    WasAChevy[OP] and Mattedfred like this.
  3. Jan 2, 2022 at 7:35 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    If it doesn’t it’s easily remedied with no risk of corrosion. All you need is a handy-dandy drill and nice sharp drill bit! Drain hole(s) achieved!
    WasAChevy[QUOTED][OP] likes this.
  4. Jan 3, 2022 at 6:05 AM
    OppoMojo
    OppoMojo New Member
    Yes Sir! No need to sharpen drill bits on a Toyota. Just sit back and enjoy the ride.
  5. Jan 3, 2022 at 10:05 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Can confirm, just like the composite bed in the Taco, that the Tundra has drain holes up front near the cab.
  6. Mar 9, 2022 at 3:21 PM
    WasAChevy
    Has holes, smalll holes. Nothing a 1/2" bit can't fix.
  7. Mar 9, 2022 at 7:03 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    There are 4 of them at the forward end (towards the cab).
    Small but drillable if you need them bigger.
    If you install the OEM Tonneau cover it does utilize 2 of those holes for its drain tubes but the holes are there.
  8. Mar 9, 2023 at 7:56 AM
    smkmsqt_23
    smkmsqt_23 New Member
    I bought a synetic USA cover and it has 4 big drain hoses. I am not sure where to drill...anyone has a picture of where they drilled. Ultimately, I am trying to just drill the liner and not the metal of the bed...is that even possible? if not, I may look for drain tube reducer to make it fit the tiny factory holes.
    Gray Hawk likes this.
  9. Mar 9, 2023 at 10:36 AM
    urmomspad
    urmomspad New Member
    SoCali
    23 Tundra TRD OR
    I installed a Retrax cover which requires 2 drain holes. They are located in the corners of the bed closest to the cab. I drilled the holes out to 5/8” to accommodate the drain tubes. I drilled from the underside of the bed liner. You do not need to go through the actual metal bed, just the liner.
    Also, I’m impatient and went straight to a 5/8 bit. I would definitely start smaller and work your way up.
    gmotoring likes this.
  10. Mar 9, 2023 at 10:52 AM
    smkmsqt_23
    I’ll crawl under there and see! Appreciate the quick reply!
  11. Jun 2, 2025 at 9:03 AM
    Gray Hawk
    Gray Hawk New Member
    Cincinnati, Ohio
    2023 toyota tundra 4x4 1794 edition smoked mesquite
    Tonneau cover; dash cam
    I bought the same. What did you end up using? Reducer insert?
