  1. Dec 31, 2021 at 12:07 PM
    Unclebuck
    Unclebuck New Member
    2018 Crewmax SR5 TRD Offroad
    Got the Bakflip and Bedrug installed yesterday. Love the Bedrug, so much easier on this old body than the existing Rhino lining.
    Tundra805, Beesta, Ayvatr and 9 others like this.
  2. Dec 31, 2021 at 12:28 PM
    HamHands
    HamHands Honey-Glazed Member
    2018 Tundra DC MGM SR5 5.7 TRD 4x4
    How do you do all that in the snow?? Yikes!
  3. Dec 31, 2021 at 12:47 PM
    joey2018
    joey2018 New Member
    Added Tech 12volts auto start. Great product and fantastic customer service! Highly recommend buying from them! Also preordered HRS tail lights. Their sight says maybe they will be in stock before 2/30/22.
  4. Dec 31, 2021 at 12:49 PM
    Unclebuck
    Friend with a garage. It did cost me a few whiskeys, but he provided the pizza.
  5. Dec 31, 2021 at 1:51 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    busy few days and great work. Truck looks fantastic.
    SoJersey[QUOTED] and D3VA like this.
  6. Dec 31, 2021 at 3:00 PM
    D3VA
    D3VA New Member
    NoVA
    2021 TRD Pro in the MGM Master Race!
    I took some time to replace the Tundra's hollow front sway bar with the solid TRD version. It took longer than anticipated as I had to get the TRD skid plate off. Overall, a quick and easy job and it does tighten up the roll a bit and might even help with diving. I'll have to drive it more to get the full experience.
    Using the garage that's never used as a garage - tight fit!
    Had to remove the skid plate.
    Job complete!
    TRD plate has some touch up required to get rid of that surface rust from the tow hooks and some frame rust in the same spot before it's reinstalled.
    Also lots of surface rust here:
    GELCW, Ayvatr, WawaLunar and 8 others like this.
  7. Dec 31, 2021 at 4:07 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Seems like a decent amount of rust for a 21, but maybe it’s just me. NOVA definitely has some humidity though too.
    GELCW and D3VA[QUOTED] like this.
  8. Dec 31, 2021 at 4:13 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    SHEW - I say that’s a TIGHT fit !!
    Yea TOO Dam much RUST. For a 21- that’s that DAM salt brine shit for ya
    Have you tried a Woolwax treatment?
    D3VA[QUOTED] and Spyker like this.
  9. Dec 31, 2021 at 4:15 PM
    D3VA
    D3VA New Member
    NoVA
    I just bought this '21 and it's the first time I've been under it. At least it has a 3-yr warranty. :)
  10. Dec 31, 2021 at 4:37 PM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    I got my ‘21 last December so I never had the opportunity to spray it with fluid film before it’s first winter. Mine had rust in the same spot when I took the tow hooks off to have them powder coated. I just took a wire brush to that spot then sprayed it with paint before I reinstalled the hooks.
  11. Dec 31, 2021 at 5:09 PM
    TUNDRA375
    TUNDRA375 New Member
    GA
    2021 TRD PRO LUNAR ROCK
  12. Dec 31, 2021 at 5:41 PM
    thedonn
    thedonn New Member
    what drawer is that ? I like it !
    Isntthatdandy[QUOTED] likes this.
  13. Dec 31, 2021 at 5:43 PM
    DuneShoot
    DuneShoot New Member
    West Phoenix
    ‘21 Limited Cement
    Hola D3VA!
    D3VA[QUOTED] likes this.
  14. Dec 31, 2021 at 5:48 PM
    Midnite72
    Northern MD
    18 SR 5.7 4x4
    Took advantage of a RARE 56 degree DEC day in MD !!
    Full wash wax detail - DONE !!
    Tyman, 3xYOTA, Rgross2112 and 15 others like this.
  15. Dec 31, 2021 at 5:53 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    If I waxed my truck today, the doors wouldn't open for the next couple of weeks. It is too cold to do any of that right now. Don't worry about the Celsius to Fahrenheit conversion, when it gets down this low it is pretty much the same thing.
    WILLINH, NewImprovedRon, D3VA and 3 others like this.
  16. Dec 31, 2021 at 9:29 PM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    Man ole man, I have been working on the Yota like crazy since I got the ole Rona. I swapped out to the black trim and had my girlfriend sew the leather on it. I also did the radio knob, DIY center console charger, swapped the rear plug to USB, and plan on putting the SDHQ ABS guards on tomorrow (Pics tomorrow).
    On a side note, I noticed that the steering wheel trim pieces come with the right side open. I contacted AJT to see if they can send an insert, if they can't what have others done to cover it?
    Ayvatr, WILLINH, mgm16trdpro and 3 others like this.
  17. Dec 31, 2021 at 10:56 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    AJT sells the inserts.
    https://www.ajtdesign-llc.com/online-store/Steering-Wheel-Trim-Toyota-Button-Inserts-p418179402
    AggiePhil and YotaBro[QUOTED] like this.
  18. Jan 1, 2022 at 3:39 AM
    D3VA
    D3VA New Member
    NoVA
    Hey Brother! Almost went Cement but couldn't give up the MGM!
  19. Jan 1, 2022 at 5:28 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Hey,
    I’m planning to do this exactly where/tire combo except in 18 inch. How’s it ride so far? Do you wish you when small tire size? Do you have a matching spare 35 inch and does it fit under the bed?
    Thank you! Looks awesome!
  20. Jan 1, 2022 at 7:26 AM
    HamHands
    Nice work! So the TRD Pro doesn't come stock with the TRD front sway bar? Kind of ironic, isn't it? Does it come stock on anything, or does it just exist as an OEM add-on? I guess I just assumed that a TRD Pro would come with all the TRD things...
  21. Jan 1, 2022 at 7:35 AM
    sounds like it comes stock on some of the sequoias. Just not in red.
    HulkSmurf14 likes this.
  22. Jan 1, 2022 at 7:50 AM
    D3VA
    D3VA New Member
    NoVA
    Correct this '21 Tundra TRD Pro did not come with solid red TRD sway bars. Someone will know, but it may have been a factory option not selected on this build.
    ETA - For clarity, this did come with the standard (hollow) front sway bar. I replaced the hollow bar with the solid TRD bar.
    TundraLLama likes this.
  23. Jan 1, 2022 at 7:59 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    I think it's standard on TRD Sport's. I could be wrong though...
    AggiePhil, GODZILLA and TundraLLama like this.
  24. Jan 1, 2022 at 8:03 AM
    TundraLLama
    TundraLLama New Member
    Massachusetts
    2015 Black Platinum Tundra
    Color matched mirror caps and door handles TRD dual exhaust TRD shift knob TRD Pro FOX shocks Spray in LINEX bed liner TRD 18” wheels FOX TRD Pro suspension Michelin 275/65r18 LTX AT2 Soft top Roll up bed cover Go Rhino RB10 running boards TRD Pro LED blackout headlights TRD Pro LED blackout fog lights TRD Pro grille AJT DESIGN blackout vent/shift/cup holder Wireless charging tray Remote starter Upgraded alpine speakers, amp, dual sub box. Rear underseat storage.
    Tundradude34 has a video about the rear TRD pro sway bar. He said that it actually has a negative impact on the ride quality when the truck has fox TRD pro suspension on it. I guess to each his own but you can check out his YouTube video for more clarity. The TRD pro does not come with the rear sway bar.
  25. Jan 1, 2022 at 8:34 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Pro comes with the smaller hollow front sway bar, just like most other trims. Only the TRD Sport gets the beefy front sway bar, and it also gets the rear sway bar. Any other trim you have to buy the rear one yourself
    a522467, D3VA and HamHands like this.
  26. Jan 1, 2022 at 9:47 AM
    Flying Gorilla
    Flying Gorilla New Member
    Austin, TX
    2018 SR5 TSS Blazing Blue Pearl
    Factory Lift 35” Tires Black Rims
    Installed the Teton Workshop shifter which I like so far. Keeps my black and blue theme going.
    Also installed the Console Vault half Safe in the center console.
    59304393-DAC1-40A5-84D6-10F3C87693EC.jpg 0CA77533-445D-4FF8-A680-76055B3719F8.jpg
    My AJT chrome delete came in as well, but I need more time to install that. Happy New Year everyone!
    Fish Wagon, Jego, Rgross2112 and 15 others like this.
  27. Jan 1, 2022 at 10:49 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Got the old school TRD Pro grille and matching hood bulge for Christmas. Went with the older style because I think it suits my 2016 better.
    Didn't get seat jackers for a gift, so ordered those and they should be arriving this week. So ready for those!
    Will soon be prepping for my suspension install. I am going to need to trim the factory skid and order bumper shims. Pro Truck 2.0 suspension and RAS sitting in my living room and ready to install once I get the prep work and bumper shims installed. No real rush as my OR suspension is still working well.
  28. Jan 1, 2022 at 10:49 AM
    RobertD
    Robert
    DFW, Texas
    Lovely shifter! I was going to get that in the same scheme until I got lucky and found a Tomahawk shifter. Look forward to seeing the update once you get the other chrome delete stuff installed :thumbsup:
  29. Jan 1, 2022 at 12:23 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    Came on my 2020 Sport
    WFD473[QUOTED] and GODZILLA like this.
  30. Jan 1, 2022 at 12:25 PM
    GODZILLA Ask me about my hot doc
    You're not wrong. The TRD sway bars were standard for the TRD Sport Package.
    WFD473[QUOTED], 1UP and HulkSmurf14 like this.
