Front Diff drain plug is stripped, how to remove?
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Dec 30, 2021.
  1. Dec 30, 2021 at 4:52 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I went to change the front diff fluid today and the fill plug was tight but it came out ok. When I went to remove the drain plug I ended up stripping it. I was using a 10mm hex socket and a breaker bar plus pushing on it with my feet and it would not budge. Someone at the factory or dealer was happy with a impact gun or a big wrench. The hex socket still fits but it is pretty much stripped.
    I gave up getting the drain plug out so I put the bottle pump hose down into the fill hole and pumped out about a quart of fluid. I stopped pumping out after a quart because the fluid looked clean a and new. I them pumped in a quart of new fluid until it ran out of the hole and called it good. My truck has currently has 57k miles on it.
    I dont use 4x4 a lot at all so I guess I wont worry about it for quite a few more miles but at some point it will need addressed. So, any ideas or tips on how to get the drain plug out? Could it be chiseled loose, drilled through the center and tapped or something else?
  2. Dec 30, 2021 at 5:00 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Consult "the chart."
  3. Dec 30, 2021 at 5:12 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  4. Dec 30, 2021 at 5:14 PM
    IowaGuy
    In Process
  5. Dec 30, 2021 at 5:32 PM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    I took mine to a local shop and asked them to weld a nut to mine, then break it loose while it was still hot. Before doing that I bought a new one from the Toyota dealership. Welding the nut on is the ultimate weapon, so why waste time screwing around and getting frustrated?
    Backslider likes this.
  6. Dec 30, 2021 at 5:34 PM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    A quality cold chisel makes quick work of it. Or welding a sacrificial socket on it even quicker.
  7. Dec 30, 2021 at 5:37 PM
    Also hitting the head of the bolt with a hammer or brass drift helps shock the threads loose while compressing the washer, hopefully enough to get it loose
    MT Madman and DSLKSL like this.
  8. Dec 30, 2021 at 5:39 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    I just noticed it's not fully stripped yet. I would do as suggested above and try tapping it in with a hammer. Or get a sacrificial torx bit that's a hair larger and hammer that sucker in so it bites into the nut. Or the other suggestions above.
    JLS in WA likes this.
  9. Dec 30, 2021 at 5:44 PM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Once you get it out replace it with this. A notorious problem. Credit to someone on this site for teaching me this.
  10. Dec 30, 2021 at 6:18 PM
    DSLKSL
    DSLKSL New Member
    Don
    Insert a hex bit, smack it with a 5lbs hammer like you to drive it through once. Then remove it.This type of thread always acts like this on the 1st removal.
  11. Dec 30, 2021 at 6:28 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    yeah i learned always go after the drain plug first
  12. Dec 30, 2021 at 6:29 PM
    parkerbows
    Jack
    you will get it though, in easy area at least
  13. Dec 30, 2021 at 6:38 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    It’s always good practice to loosen the fill plug first. What if he drained the diff and then couldn’t get the fill plug free? Would be a bad day.
    JLS in WA and FrenchToasty like this.
  14. Dec 30, 2021 at 6:41 PM
    parkerbows
    Jack
    oh shit your right I said it backwards. so yeah nothing done wrong. couple beers tonight
    EatSleepTacos[QUOTED] likes this.
  15. Dec 30, 2021 at 7:08 PM
    IowaGuy
    In Process
    Yes I made sure the fill plug came out first.
  16. Dec 30, 2021 at 7:17 PM
    NWPirate
    Zach
    WA
    I welded mine, this was a couple years ago. Worked awesome.
  17. Dec 30, 2021 at 7:31 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Air hammer with a chisel bit. Couple taps and it turned for me.
  18. Dec 30, 2021 at 7:35 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    This is the easiest, most reliable, and least frustrating solution.
    Your problem also highlights why you always remove the drain plug last.
  19. Dec 30, 2021 at 7:36 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    So that's where my 10mm is....
  20. Dec 30, 2021 at 7:42 PM
    NWPirate
    Zach
    WA
    :D
  21. Dec 30, 2021 at 8:16 PM
    IowaGuy
    In Process
    Humm, I wonder if a big glob of JB Weld on the hex socket and plug would hold enough to crack it loose? Also if I use a chisel should I use a flat cold chisel or a punch type?
    I have the fluid replaced and it doesn't need maint. again for quite a while but now it is just irritating and a challenge to get it loose.
  22. Dec 30, 2021 at 8:18 PM
    IowaGuy
    In Process
    Also the plug looks like aluminum, can it be welded with a normal stick welder or do I need a special setup?
  23. Dec 30, 2021 at 9:50 PM
    SnowB0und
    SnowB0und New Member
    2013 SR5
    I did the same thing on my Tacoma. The heat from welding definitely helped.
    NWPirate[QUOTED] likes this.
  24. Dec 31, 2021 at 12:16 AM
    Chip_Tundra
    Chip_Tundra New Member
    Get yourself the one on the right next time. Not all 1/2" drives are the same lol. A little PB blaster and some leverage works wonders.
    NWPirate likes this.
  25. Dec 31, 2021 at 5:37 AM
    Backslider
    Tooele, UT
    I am extremely doubtful the plug is aluminum... similarly doubtful that JB Weld would give the bind needed to break it free.
