Getting lower ball joints and upper ball joints - do I need a camber kit?
Discussion in '1st Gen Tundras (2000-2006)' started by DanielDD, Apr 12, 2021.
  1. Apr 12, 2021 at 4:50 PM
    DanielDD
    DanielDD [OP] Too Old to Rock and Roll and Too Young to Die
    2001 TRD Tundra
    Alignment shop says I may need a camber kit. They won't know until they put it back together and do an alignment. The upper control arm along with the lower and upper ball joints are going to be replaced. Can't see the need to spend another $200 for a camber kit.
    What is your recommendation?
  2. Apr 12, 2021 at 5:04 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    By "camber kit" I'm assuming they are referring to the eccentric bolts. Chances are they need to be replaced for a proper alignment, it's not that uncommon. My alignment guy wouldn't touch my truck until I replaced the eccentrics... they were froze in pretty good, I had to cut them out with a Sawzall and Diablo blade.
  3. Apr 12, 2021 at 5:29 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    If it's the eccentric bolts you need @Tundra2 has one new complete bolt/sleeve/cam for sale here.
  4. Apr 12, 2021 at 6:13 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Camber kit? The eccentrics don’t need to be replaced unless they are seized. Clean them up and add a little anti-seize before they go back together.
    It’s a total of 3 pieces per side, 6 per control arm. You only need to replace 2 if they are seized. I got mine from Toyota and they were like $80 for all 4 for 1 control arm.
    Only thing that would make me change that would be if you are in the rust belt and they are dissolved.
    I’d find out exactly what they are talking about.
  5. Apr 12, 2021 at 6:34 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Is the truck stock or lifted? If lifted, you may need uppers.
  6. Apr 12, 2021 at 6:46 PM
    DanielDD
    2001 TRD Tundra
    Pretty much stock except for a couple of spacers on the front coil and and add a leaf on the back. They want $1200.00 to replace the upper/lower ball joints and upper control arms, including the camber kit + an alignment included in price. I did a quick check on Rockauto and the parts to replace are not expensive. I think I'm just going to pick the truck up tomorrow and do it myself and then take it back and have them do the alignment once I replace the components. The money I save I can use for tires...
    Got a good source for parts? They talked about using Moog....
    Glock 40 likes this.
  7. Apr 12, 2021 at 7:38 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I installed a set of Moog eccentrics and they have grease zerks, I like.
  8. Apr 12, 2021 at 9:16 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    OEM lower ball joints.
    TRDGen and Glock 40 like this.
  9. Dec 29, 2021 at 8:30 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    How difficult is it to replace these? I know it's just 3 or 4 bolts on the LCA. Then do I need a press to get the BJ off the spindle and to install the new one?
  10. Dec 29, 2021 at 9:00 PM
    Aerindel
    Aerindel New Member
    Montana
    Its not $1200 difficult....holy crap. I've never needed a press, just hammer and socket....but a press is only like $200 even if you needed one.
    TRDGen likes this.
  11. Dec 29, 2021 at 10:37 PM
    nickrick78
    nickrick78 New Member
    Pittsburgh PA
    2004 DC
    Only way you need cam kits is if they are seized. Only way to know if they're seized is to try to turn them.
  12. Dec 30, 2021 at 12:49 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    The lower ball joint also is the steering knuckle. You'll need to remove 4 bolts, the tapered ball joint into the lower arm and the outer tie rod end.
    No press needed. A ball joint separator or picklefork and hammer will work.
    TRDGen[QUOTED] likes this.
