Spring compressor
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kblood, Dec 28, 2021.
  1. Dec 30, 2021 at 9:48 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    $600 all day long on the used market. $820 new (plus shipping I imagine) For me it was either Branick 7600 or pay the shop.
  2. Dec 30, 2021 at 5:38 PM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    I used these bad boys from Shankly to swap to 700lb coils on icon 2.5s. They were plenty strong and didn't bend. I felt fairly safe. They appear to not be available at the moment but they were only ~$60 at the time. I would recommend them as well as use them again myself.
    https://www.amazon.com/gp/product/B071DQJG24?ie=UTF8
  3. Dec 30, 2021 at 6:19 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    those are the ones I used looked exactly the same just another name to the one's I posted
    JCBerb and blackoutt[QUOTED] like this.
  4. Jan 28, 2022 at 7:35 AM
    Kblood
    Kblood [OP] New Member
    2017 SR5 Tundra
    Back shocks are on. I’m waiting for Eibach spring to install the front struts next.
  5. Jan 28, 2022 at 7:36 AM
    Kblood
    2017 SR5 Tundra
    I ended up buying this will be testing it out next week see how it work finally
    CodyP[QUOTED] likes this.
  6. Jan 28, 2022 at 7:38 AM
    Kblood
    2017 SR5 Tundra
    I started all this because originally the truck was all just spacers and the spring in the front started hitting the control arm. Thinking about getting some new control arms if anyone has any recommendations please let me know thanks.
  7. Jan 28, 2022 at 8:30 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    SPC or Total Chaos arms will treat you well...
  8. Jan 28, 2022 at 8:42 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I installed 5100s on my Sequoia without using a spring compressor.
    Check this video out on removal.
    This video is installation.
    Note: the video isn't me but a guy working on a Taco. Still fully applies to how to do it on a Tundra
  9. Jan 28, 2022 at 8:47 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    Local Tire Choice charged me $150 to assemble and install both front, along with the rear shocks. Then I paid for the alignment.
    rock climber and Chip_Tundra like this.
  10. Jan 28, 2022 at 8:56 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    That's a great price!
  11. Jan 28, 2022 at 9:06 AM
    CavBluTundra
    Howard
    I thought so to since I did not have a spring compressor and wasn't going the ratchet strap route if you know what I mean.
  12. Jan 28, 2022 at 9:09 AM
    rock climber
    I tried the ratchet strap method once and it was a complete failure, luckily I gave up before it got dangerous.
    CavBluTundra[QUOTED] likes this.
  13. Jan 28, 2022 at 9:33 AM
    AggiePhil
    College Station, TX
    If you’re going to have to pull the shocks for rebuilds or replacement, you might as well buy the proper $800-$1000 spring compressor too. Saving the $200 a shop will charge knocks the price down to $600-$800, plus what you’ll save at rebuild/replacement time. Something to think about.
    JCBerb and HulkSmurf14 like this.
  14. Jan 28, 2022 at 1:43 PM
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    I usually do my suspension work myself. But yesterday I had a local repair shop do my 5100s and align the truck too. $300 and I was back on the road without any fighting with coil compression tools. These Tundras are built more like 3/4 ton trucks compared to all the trucks I've done before. Didn't want to use a cheap coil compressor on these.
  15. Jan 28, 2022 at 2:31 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    No, I see no need why someone would need a commercial grade spring compressor. We talked about not using the cheap autozone rentals and buying a $100-$150 spring compressor which is more than strong enough. No one is doing 2-3 spring assemblies a day here...
    If you're spending that cash on a spring compressor then you better already have a 2 or 4 point lift.
    Sumo91, texasrho83 and parkerbows like this.
  16. Jan 28, 2022 at 5:48 PM
    Kblood
    2017 SR5 Tundra
    2016-2020 Toyota Tundra 2.5" Front Pro-Lift-Kit by
    Eibach Springs and they arrive on Tuesday, so they should be on hopefully by the end of the week lol
  17. Jan 28, 2022 at 5:53 PM
    Kblood
    2017 SR5 Tundra
    I’ve already noticed a difference in the rear shocks with all the shitty roads around here. Can’t wait to do the front Going with the middle snap ring since the truck is sitting on spacers and has a 3in lift as it sits now. I’m not taking any lift away but giving it a proper lift. Adding half inch in the front to adjust with all the extra weight.
