Lighting Options for Rear of Truck
Discussion in 'Lighting' started by 2point5seconds, Dec 29, 2021.
  1. Dec 29, 2021 at 3:29 PM
    2point5seconds
    2point5seconds [OP] Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    This site has helped me with ideas and installs for the last couple of years. So, I'm just throwing this question out there with some history of what I was going to do.
    Truck: 2019 Tundra SR5 4WD 5.7l DC
    I was going to eventually add a bed rack so I can add lights to the top and point them backwards for camping/off road/outdoors. This will allow me to see into the bed better, help with reversing in the pitch dark, light up the camping area, etc. I was also going to add my recovery items to the rack (as everyone does). Such as a shovel, ax, whatever else.
    Now I'm not sure I want to go the bed rack route. I'm not getting a tent for it. And I do use the bed for hauling stuff every so often. I'm thinking of getting the Decked Tool Box to haul my recovery items instead of throwing them in the back seat. It takes away from passenger space.
    So, I'm wondering if I could get some ideas and/or pictures of what you did besides getting a bed rack to light the rear of the truck better. I do have VLED bulbs in the rear bed lights, but they're okay.
    Thanks!
  2. Dec 29, 2021 at 3:36 PM
    timsp8
    NY
  3. Dec 29, 2021 at 3:45 PM
    2point5seconds
    Sensei
    Nor Cal
    timsp8[QUOTED] likes this.
  4. Dec 29, 2021 at 3:58 PM
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    bulldog93, Mater, memario1214 and 2 others like this.
  5. Dec 29, 2021 at 3:59 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    My rack is pretty much used to house all of my lights for exactly what you described. I've got 2 chase lights, while the rest are for lighting up the surrounding area, which comes in very handy when setting up camp at night.
  6. Dec 29, 2021 at 4:02 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    If I didn't want to cut, I'd get a hitchpod.
    On my '08, I cut the bumper and installed lights in the bumper that turn on with reverse lights. I am also mounting a rack and platform on top of my canopy which will have switched lights on the back.
  7. Dec 29, 2021 at 4:05 PM
    HamHands
    HamHands Honey-Glazed Member
    2018 Tundra DC MGM SR5 5.7 TRD 4x4
  8. Dec 29, 2021 at 4:08 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I wired it independent of reverse lights on a switch. Obvious limitation is it has to come out for hitch stuff.
  9. Dec 29, 2021 at 4:08 PM
    You could get the high output reverse bulbs from Vleds as well. I actually have a set that I just took out of mine. As far as lighting an area, you can get brackets that mount to the bed rails unless you are using a bed cover.
  10. Dec 29, 2021 at 4:23 PM
    2point5seconds
    Sensei
    Nor Cal
    AggiePhil likes this.
  11. Dec 29, 2021 at 4:25 PM
    2point5seconds
    Sensei
    Nor Cal
    Yeah, kind of the set up I was thinking. Do you use the rack for anything else? Does it get n the way when hauling? I see you have wood that slides out (that's a hecka good idea). I wouldn't be able to install a tool box with a rack right? Thanks!
  12. Dec 29, 2021 at 4:27 PM
    2point5seconds
    Sensei
    Nor Cal
    Yeah, I want to get a rear bumper in the future. The one I want does have cut outs for lights. So that could be an option. Thank you!
  13. Dec 29, 2021 at 4:38 PM
    2point5seconds
    Sensei
    Nor Cal
    Thanks! I will check out his site!
    HamHands[QUOTED] likes this.
  14. Dec 29, 2021 at 4:38 PM
    2point5seconds
    Sensei
    Nor Cal
    have some VLEDS for my rear bed light housing. I just spoke to them today actually about their options for the Tundra. Thanks!
  15. Dec 29, 2021 at 4:57 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Depends on what I'm doing. If I'm overlanding (or have extra gear to carry) then I've got a platform on the rack that allows me to mount things on it. If I'm wheeling, then it's just the lights. Can't really see that well out the rear window.
    You might not be able to easily open and access the toolbox with a rack above it.
  16. Dec 29, 2021 at 5:09 PM
    2point5seconds
    Sensei
    Nor Cal
    yeah. That is like something I was thinking of doing. I wanted to get a tool box that locks because sometimes, I do not go straight to the campground/trail/etc. So i want to make sure everything is locked down. I see you got the RCI rear differential skid plate. I had it on order, but cancelled it because I wanted to get their rock sliders instead. It's been awhile (almost two months) but they're in transit now. What kind of top do you have over your bed that's covering it? Thanks!
  17. Dec 29, 2021 at 5:28 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    2point5seconds[OP] likes this.
  18. Dec 30, 2021 at 6:19 AM
    Taco-Spike
    Two Trucks
    I have a couple rear pods in the bed, and a hitch pod on the taco.
    vled license plate reverse bar for tundra
  19. Dec 30, 2021 at 7:28 AM
    HamHands
  20. Dec 30, 2021 at 3:17 PM
    cran2
    cran2 New Member
    Folly Beach, SC
    07 Crewmax 4x4 and 03 Sequoia 4x4
    Just installed the VLED license plate light, huge difference! . VLED is having a 20% sale until the 3rd
    7BFE3D66-F67D-45E2-AF8C-B9B048617CCD.jpg A737DEF4-1E2F-4B8F-B0EE-51C174A1FC91.jpg
  21. Dec 30, 2021 at 3:21 PM
    VLEDS has good stuff. My truck is loaded with it lol.
  22. Dec 30, 2021 at 3:45 PM
    2point5seconds
    Sensei
    Nor Cal
    That is a huge difference. yeah 20% off. that's why I was looking at those options. I spoke to someone there and they said that the license plate lights and the Triton lights will only be bright for about 5 minutes before it starts to dim. I don't see myself backing up for 5 minutes, but I've been in the middle of nowhere and it could happen if it's some single lane logging road. But that brightness is definitely what I'm looking for in lights. Thanks for sharing!
  23. Dec 30, 2021 at 4:00 PM
    cran2
    cran2 New Member
    Folly Beach, SC
    Definitely worth doing!
    Eventually I’ll add something switched like a pair of Diode Dynamic’s SS2’s, but this was a clean, cheap, easy install and bright option for now.
  24. Dec 30, 2021 at 4:15 PM
    2point5seconds
    Sensei
    Nor Cal
    Nice boat too. That's eventually on my 'to get' list. lol
    cran2[QUOTED] likes this.
  25. Dec 31, 2021 at 12:05 AM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Baja Designs flush mount. Changed the lenses to Amber, and powered through Switch Pros. Just one more option.20210311_133208.jpg
    bulldog93, Nic146, Wallygator and 5 others like this.
  26. Dec 31, 2021 at 5:34 AM
    Kayaking Tundra
    Kayaking Tundra New Member
    2019 White Toyota Tundra TRD PRO
    I also thought about something like this. I do a lot of hunting, camping, kayaking, etc... I also didnt want something permanent. I wanted to move it to the kayak for night floating, and camping on the different sides.
    I chose 2 of these. It lights up the night for sure. Of course it has a battery, but I zip tie those to what ever I need.
    https://www.olightstore.com/rn-3500.html
    I also have some rechargeable work lights that I can stick to my rack because its magnetic.
  27. Dec 31, 2021 at 7:14 AM
    AggiePhil
    College Station, TX
    No joy on the link. Post a pic of it on your truck if you would.
  28. Dec 31, 2021 at 1:10 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Another option I've seen done is wiring up a couple lights to make use of the bed's bulkhead track and slide where is needed...it could also be used as a reminder to those that roll up on you with their brights on...
    2point5seconds[OP] and cran2 like this.
  29. Dec 31, 2021 at 1:17 PM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    How was the install on these? What did you use to cut the bumper? Ive never wired anything from the back, do you just run it under the truck then up to the switch pro? I like the looks of those
    AZ Red Nek[QUOTED] likes this.
  30. Dec 31, 2021 at 1:23 PM
    alb1k
    Left Coast
    It's good
    You run the wiring along the frame with the factory wires for the rear lights and hitch. I brought mine into the cab where most (all?) of the wires enter under the driver's seat. (gen 1)
    bulldog93 and 2point5seconds[OP] like this.
