  1. Dec 28, 2021 at 4:57 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Noah would go.
  2. Dec 28, 2021 at 5:03 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    That would be the next step if these things back off again or I could go with the spherical links set up and some new type of bolt and nut set up that won't back off, maybe try lock wire! Lol.
  3. Dec 28, 2021 at 5:04 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    NordLocks
    They’ll change your life.
  4. Dec 28, 2021 at 5:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hell yeah! Gonna fuck up royally, but it'll be fun as fuck if it all works!
    Thanks my man! Fellers, I bid you good night. I will return to the junk yard early Friday morning if they are open. I forgot that I also have to work Thursday this week... whoops.
    @Hooptytrix said it best. https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-161#post-1809609
    bmf4069, oscardog86, shifty` and 4 others like this.
  5. Dec 28, 2021 at 5:33 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    After Noah's day I'm a little embarrassed to mention all I got done was putting in new tag lights (and hit post 500)...
    bmf4069, shifty`, KNABORES and 6 others like this.
  6. Dec 28, 2021 at 5:38 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Congrats on post count! :D
    Voss, bmf4069, KingSequioa007 and 5 others like this.
  7. Dec 28, 2021 at 6:03 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You’d want the engine harness and ecm if they’re the same year as your truck. If not custom wiring can keep the stock computer and just make an ADD relay to control the front diff when the t case is engaged
    Voss and Tundra2[QUOTED] like this.
  8. Dec 28, 2021 at 6:10 PM
    WWND
    bmf4069, Darkness, chrisb and 4 others like this.
  9. Dec 28, 2021 at 6:13 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It's a 2001. The ECM is gone from the donor truck, and harness was cut before my arrival on scene. Gonna get the parts, and pieces though.
    Are there any other modules I need from inside the cab on the donor?
    Any clue on the odds that my trucks wiring has plugs to accept 4wd or would I need a complete gut, and replace? Might be moot without ecm or ecm connectors.
    All thoughts welcome. Would it be a good idea to deliver the trans to a certified transmission shop, and have inspected or rebuilt?
  10. Dec 28, 2021 at 6:15 PM
    empty_lord
    05 rollover special
    A340s behind v6s rarely fail. I’d just run it. Are the tundras j shift transfer cases or push button? I’m not sure. If it’s j shift there’s company’s that make harnesses and kits to make the ADD work properly without needing the ECM and factory harnesses. You just lose the safety of it never being able to shift into 4x4 when going above 65
    Tundra2[QUOTED] likes this.
  11. Dec 28, 2021 at 6:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    -.5 internet points for Jimmy jumps
    @chrisb as most of the regulars have probably surmised... with the last job I did not have the luxury of time. Therefore, I had no real room for comfort. I had to learn to make full use of my time off from work.
    Make the most of your time. Just my .02. Fucking full send bro! It won't take too long, and think how good it's gonna look.
  12. Dec 28, 2021 at 6:24 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    When anyone tells me they’ll do something after they retire i’ll tell em it wont be worth it. Do it now and do it all.
  13. Dec 28, 2021 at 6:25 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    There wasn't a button on the bezel so I'm assuming that's its just a j-shift. I know you and I talked about this about a year or so ago. My memory is rusty on the j-shift subject...
    So with this company harness I could still shift into 4wd while in motion below 65? If so, I'd be fine with that.
    oscardog86 likes this.
  14. Dec 28, 2021 at 6:27 PM
    alb1k
    Left Coast
    It's good
    Yes, what indeed?
    Tundra2 and FrenchToasty[QUOTED] like this.
  15. Dec 28, 2021 at 6:29 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Fix it then send it. The bane of country boys. City folk know to send it, then fix it.
    bmf4069, Darkness and Tundra2 like this.
  16. Dec 28, 2021 at 6:34 PM
    empty_lord
    05 rollover special
    Yes
  17. Dec 28, 2021 at 6:39 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'd already have them bitches mounted, torqued, and on the fuggin road. JS. Lol
    Darkness, chrisb and alb1k[QUOTED] like this.
  18. Dec 28, 2021 at 6:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    What are the odds that the gear ratio on donor truck is the same on my truck? Likely?
    Need new steering knuckles now...
  19. Dec 28, 2021 at 7:12 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    little by little you're gonna disassemble a whole truck to reassemble it in your driveway, lol
    bmf4069, Darkness, chrisb and 5 others like this.
  20. Dec 28, 2021 at 7:13 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Voss, bmf4069, shifty` and 6 others like this.
  21. Dec 28, 2021 at 7:44 PM
    Not likely unfortunately. 4.08 VS 4.30
  22. Dec 28, 2021 at 7:54 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Bummer, but....
    So the rear axle is on the donor truck, and already has one axle shaft removed (I think). If the diff isn't watery inside I could just snag that too. Gearing differences solved!
    I know the rear pumpkin on that axle was rufff. Driveshaft was meh, but still usable. Needs grease.
    Gonna be a wild ride!
    Still haven't found much for that wiring harness thing that @empty_lord mentioned for the j-shift adapter. Might not be using the correct key words. Iunno. I ry need to sleep. Up in 5!
    NUDRAT and Darkness like this.
  23. Dec 28, 2021 at 7:57 PM
    Yeah, bummer. But, moving to 4.30’s will be nice!
    TRDGen and Tundra2 like this.
  24. Dec 28, 2021 at 7:59 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Big if.... IF the rear end hasn't blown up or something. There is no impacts on the body. The only reason I can visually see for it being in the junk yard is rusty body/frame. A mystery that kinda has me scared, but willing to take the risk.
    Maybe engine problems but I'm not sure because no history. Didn't think to snag a picture of the Vin to run through toyota owners.
    Sticker on back glass said something about some store in Maine. Truck been in the thick of the rust...
  25. Dec 28, 2021 at 8:11 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    anyone have a reason why I shouldn't buy an OEM radiator from my local dealer instead of a Denso off Rockauto? Also, I should be using the red (concentrated) or pink (diluted) coolant for my 06 yes?
    KingSequioa007 likes this.
  26. Dec 28, 2021 at 8:20 PM
    daveeasa
    Mishimoto was my choice. But I live in a desert.
  27. Dec 28, 2021 at 8:21 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    no desert here...OE or equivalent would be fine with me.
  28. Dec 28, 2021 at 9:22 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Yeah that's win for sure
    Tundra2 likes this.
  29. Dec 29, 2021 at 3:21 AM
    I can't think of a reason why you should buy one from a dealer. Unless you just enjoying supporting local businesses?
  30. Dec 29, 2021 at 3:31 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Heading to work.
    Chat soon.
    bmf4069, oscardog86, alb1k and 4 others like this.
