Dashboard lights up like a Xmas tree
Discussion in '2.5 Gen Tundras (2014-2021)' started by ADay2Long, Dec 27, 2021.
  1. Dec 27, 2021 at 11:43 PM
    ADay2Long
    ADay2Long [OP] New Member
    Hey guys,
    I have a 2018 Platinum with almost 100k kms and out of nowhere while driving 2 days ago my dashboard lights up and I get errors after errors popping up. Pre Collision System malfunction, Drive Start System malfunction, Cruise control, ABS, Trailer brake, rear cross traffic alert, traction control malfunctions.
    4HI and 4LO keeps flashing on the dash and the dial will not change anything. Truck runs fine, I just have no 4x4 and no electronics assist.
    Plugged my bluetooth OBD2 scanner with Torque to pull error codes, no errors found in ECU. Drove it for 100kms today, no changes. I did notice in the fall a rodent had gotten cozy in my air filter but I took care of that, tried to look quickly for frayed or damaged wires, could not find anything.
    Anyone has any ideas before I'm forced to bring it in to a dealer? Thanks!
  2. Dec 28, 2021 at 12:11 AM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    Have you tried disconnecting the battery for a few minutes to see if the ecu resets?
    Seafury, 1UP and Tundra14Platinum like this.
  3. Dec 28, 2021 at 4:35 AM
    glowblue
    glowblue From time to time
    VA
    Seafury and 1UP like this.
  4. Dec 28, 2021 at 5:18 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    This happened to me last week; check your battery terminal for corrosion. If not that replace the battery. That was my issue. Low voltage wreaks havoc on tundras
  5. Dec 28, 2021 at 5:28 AM
    2mchfun
    Battery test? When multiple systems go south simultaneously, a loose ground is a strong possibility.
  6. Dec 28, 2021 at 5:40 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Seafury, 1UP and HulkSmurf14 like this.
  7. Dec 28, 2021 at 5:52 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Cold weather and a battery
    Seafury, Rodtheviking and 1UP like this.
  8. Dec 28, 2021 at 7:28 AM
    ADay2Long
    I unplugged the battery and tried again still no luck. Checked with a multimeter and the voltages are definitely on the low side, might change the battery see if it helps. I'll also keep digging around for chewed wires.
    Reading other posts similar, people keep talking about a blocked or dirty sensor, which sensor are they referring to?
  9. Dec 28, 2021 at 7:31 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Wheel sensor does that almost everytime.
  10. Dec 28, 2021 at 7:32 AM
    HulkSmurf14
    2014 Tundra Limited
    Your battery is still OE and not an AGM, correct? I'm not sure what sensor you mention but you either have a slow draw, (maybe an aftermarket remote start?) or a bad OE battery...
  11. Dec 28, 2021 at 7:44 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    My guess is wheel sensor or rodent damage. Definitely check under the engine cover. I had all the same symptoms, mine turned out to be rodent damage.
    F058D0D6-32EC-4544-98D7-2C25648C691D.jpg 4FDF6DE2-2B51-4E6C-85F8-CA61A363E9F9.jpg
    Seafury and HulkSmurf14 like this.
  12. Dec 28, 2021 at 12:33 PM
    Rocko9999
    Rocko9999 New Member
    Battery or rodents chewed through wires.
    Seafury likes this.
  13. Dec 28, 2021 at 1:07 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Sounds like a new battery is in store for you. Could have a bad cell. Bad batteries do some crazy things in these modern vehicles.
  14. Dec 28, 2021 at 3:21 PM
    ADay2Long
    I've cleaned the engine bay of rodent droppings to see if they are left overs from when I had a resident in my air box or new.
    I'm getting a new battery tomorrow. I do have an aftermarket remote start.
    On a rodent side note mystery, about 2 months ago the tissue box I keep in the center console clearly had the visit of a rodent in it....I'm clueless as to how it got there as the box was new and placed there and when I noticed and took it out there was no rodent in the box or center console. I also don't see any physical holes it could've used to enter the console....
    Seafury likes this.
  15. Dec 28, 2021 at 3:40 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I would try a new battery first, but do a good visual inspection for chewed/frayed wires.
    Seafury likes this.
  16. Dec 29, 2021 at 6:10 AM
    ADay2Long
    Tried a new battery with no success, time to do a deep dive into the engine bay and look for rodent damage....
    Seafury likes this.
  17. Jul 12, 2023 at 4:38 PM
    JmacDorion
    JmacDorion New Member
    2018 Black Tundra SR5 5.7
    Any updates? Mine is having the same issue! Thanks
  18. Jul 13, 2023 at 5:12 PM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Did you check all the wheel speed sensors?
    We often forget those, but they are critical part of every system you mentioned, and they will all start screaming if they lose a sensor.
