2022 Tundra Dimensions
Discussion in '3rd Gen Tundras (2022+)' started by Aviatorchris, Sep 28, 2021.
  1. Oct 4, 2021 at 4:10 AM
    nuclear
    nuclear New Member
    Yeah, crazy they make a bed length which is the most popular for consumer sales.
  2. Oct 5, 2021 at 6:21 PM
    nuttz565
    nuttz565 New Member
    Denver
    2020 DC SR5 LoooongBed Calvary Blue
    ToyTec Coilovers & Shackles Dirty Deeds 8” exhaust Method 18” Wheels Aftermarket tow mirrors
    I have noticed garages built in the 70’s were deeper for those long boat caddy’s they had back then. My buddy’s garage which was built in the 80’s is much shallower because cars got smaller I think in that decade.
  3. Oct 6, 2021 at 4:17 PM
    rocky5100
    rocky5100 New Member
    I'm still in contact with the original owners, i'll have to ask them what they had sometime!
  4. Oct 20, 2021 at 3:15 PM
    adamag98
    adamag98 New Member
    I'm curious where they added the length. The wheel base appears to be the same as the previous gen. When I park my '16 Pro Crew in my garage I pull in until the tires hit the tirestop. That leaves about 1 - 1.5" clearance for the door to shut. If the added length is in the nose - no problem as I have about a 12 - 14" clearance up front. If it is to the tail then I'll either have to figure out if I have enough driveway approach forwards so that I can then back in w/out a 20 point turn, park on the street (nope), or find another vehicle whenever I'm done with this one :(
  5. Oct 20, 2021 at 3:24 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    The EV credits will only last until a given manufacturer reaches 200,000 EV units sold then it goes to zero. If we get lucky, really, really lucky the feds will increase it to $12500 (I know, I know only for units built by unions).
  6. Oct 20, 2021 at 7:58 PM
    Blitz79
    Blitz79 New Member
    It's 12 inches longer than my tacoma. Assuming that 6 of those inches are in the front it is going to be a really close fit in my garage. Crossing fingers.
  7. Dec 8, 2021 at 12:15 PM
    ProfLonghair
    ProfLonghair New Member
    Michigan
    I have the same issue. Test drove a '14 1794 Crewmax, listed at 229 inches, pulled into the garage to the tirestop and it fit. Also tried a 2021 Ram 1500 Crewcab 5-7 box, which is listed at 233 inches, and it fit too. Anybody got an answer for where this added length is in the 22 Tundra?
  8. Dec 8, 2021 at 12:46 PM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    It’s 233.6
    it can all be found on the front end
    ProfLonghair[QUOTED] likes this.
  9. Dec 20, 2021 at 5:11 AM
    ProfLonghair
    Michigan
    This seems to be basically correct. Most, if not all, the added inches are in the front. 2014 vs. 2022, in my garage.upload_2021-12-20_8-8-53.jpg upload_2021-12-20_8-9-20.jpg upload_2021-12-20_8-9-58.jpg upload_2021-12-20_8-10-21.jpg
    Toyotoholic, MTRock, Texican and 5 others like this.
  10. Dec 22, 2021 at 5:48 AM
    Krusher22plat
    Krusher22plat New Member
    22plat
    Question for anyone with a short bed 5.5. I am looking to order an in bed mechanical ramp for one person use loading and unloading a motorcycle. As it has some lead time to ship want to order now for incoming short crew.
    The bed measurement is listed under specs but also need the cab bedwall measurement to edge of tailgate when DOWN. Confirmation of bed itself would be great as well. Many thx if someone has a chance.
  11. Dec 26, 2021 at 10:45 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Did some work for you guys and gals:
  12. Dec 26, 2021 at 11:56 PM
    Toyotafanboy
    Toyotafanboy New Member
    Mark
    Very useful, thanks
  13. Dec 27, 2021 at 9:08 AM
    Krusher22plat
    22plat
    Any chance someone has come across the outside cab wall to top of tailgate when tailgate is down on a 5’6” bed?
  14. Dec 27, 2021 at 9:32 AM
    mass-hole
    mass-hole New Member
    It's def the Jay Leno chin adding the 4".
    Honestly, if you look at the cooling system, I am not surprised they had to add some length. The intercooler exchangers straddle the radiator and they had to fit those in behind the headlight/front clip. I bet they needed a little room to fit it all in.
    Toyotoholic and borla123 like this.
  15. Dec 27, 2021 at 9:33 AM
    csuviper
    Broomfield, CO
    Bed length + bed height??
    Cpl_Punishment likes this.
  16. Dec 27, 2021 at 9:34 AM
    csuviper
    Broomfield, CO
    Yep
  17. Dec 27, 2021 at 9:39 AM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    8^0
  18. Dec 27, 2021 at 5:40 PM
    Krusher22plat
    22plat
    Sorry if garbled. The ramp goes from outside cab wall to the very edge of the tailgate when DOWN. Specs are not generally listed for such a measurement. Easiest way to look at is how long of a board will fit flat in the bed of a 5’6” model with tailgate open and zero board overhang.
    ** An edit…yes the bed plus tailgate should be the number and likely is, but manufacturer insisted it is close but usually slightly different due to how tailgate is on a hinge etc.(I am still skeptical of that reasoning)
  19. Dec 27, 2021 at 6:13 PM
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    I’d casually shit myself every time I shut my garage door with either one.
  20. Dec 27, 2021 at 6:39 PM
    #50
    OppoMojo
    OppoMojo New Member
    Exactly 89 inches
  21. Dec 27, 2021 at 7:01 PM
    #51
    csuviper
    Broomfield, CO
    :annoyed::angrygirl::argue:
    didn’t pull in far enough one day
  22. Dec 27, 2021 at 7:32 PM
    #52
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    I would park it out side, call it a day and start shopping for boats that would fit in the garage. I Dont understand the “need” to park a truck in a garage.
  23. Dec 27, 2021 at 7:48 PM
    #53
    RavingOx
    RavingOx Member
    WNC
    I already don’t park my truck in the garage…just saying how my anatomy would respond to that situation.
    Toyota1234[QUOTED] likes this.
  24. Dec 28, 2021 at 8:08 AM
    #54
    Krusher22plat
    22plat
    Excellent!!! Many thanks as this will enable me to have loader ready as soon as truck arrives.
  25. Dec 28, 2021 at 8:37 AM
    #55
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    Does the 2022 height listed at 78" account for the radio antenna 'fin' ? I'm right at 80" height for my garage opening. I don't mind keeping it outside most of the time, but I'd love to move it in to avoid snow and hail.
    Russ_S likes this.
  26. Dec 28, 2021 at 9:24 AM
    #56
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    You would think with the smaller motor and redesign, the truck would actually be more compact on the outside and roomier on the inside. Seems they went the opposite direction? It's longer, wider, taller, and less roomy? Wonder how that happened, maybe they didn't hear all the people in their surveys telling them what they actually wanted, or needed (to fit into parking garages or a home garage).
    I finally saw the 22 in person and side by side with my 17' I loved the look of it, (as long as I didn't look at the grille or the rear bumper) but the longer I looked, the happier I was to have my 17' it just feels more like a truck than the newbie does. Maybe it will evolve enough over the next few years to increase my attraction to it , but not yet.
  27. Dec 28, 2021 at 9:39 AM
    #57
    Toyota1234
    Jack
    Yes they had to for crash ratings and mpg.
  28. Dec 28, 2021 at 10:16 AM
    #58
    mass-hole
    I bet the cooling system is what caused it it to get longer. They have the radiator, two intercooler exchangers, and likely a hybrid system cooler in there. They had to fit all that somehow and be able to flow air through it efficiently.
    The interior volume change could very well be airbags and safety stuff. Or it could just be that truck cabs have gotten ridiculously big and the space simply isnt needed. When I sit in the back of my F150 screw, I have like a full 12" between my knees and the front seat which is completely unnecessary.
  29. Dec 28, 2021 at 10:32 AM
    #59
    CMikeB
    CMikeB New Member
    Agree! When we had our home built, I wasn't aware of 18' garage doors. Found out 'after the fact' from a older and much wiser neighbor. When I had my garage built, I made sure there was a 18' door on each end!
    Toyota1234 likes this.
  30. Dec 28, 2021 at 11:26 AM
    #60
    OppoMojo
    OppoMojo New Member
    Glad to help!
    All this talk about it being cramped or feeling smaller is blown out of proportion. The seat always bugged me in the 2011 that it didn't go back very far at all and I'm long legged. The 22 seats offer more seat room than I need and feels bigger inside. So, if you think it's a deal breaker, go sit in one and enjoy. Like McDonald's...I'm lovin it
