Slight Thud accelerating at highway speeds
Discussion in '1st Gen Tundras (2000-2006)' started by g2turbo, Dec 26, 2021.
  1. Dec 26, 2021 at 4:03 PM
    g2turbo
    g2turbo [OP] New Member
    I purchased a 2002 Tundra a few months ago and have started to notice a thud when accelerating at highways speeds... mostly noticeable when starting to go up long hills.
    I can't tell if the truck is actually downshifting, but it doesn't seem so as the RPM stay pretty consistent in the low 2k range.
    Truck shifts just fine any other driving conditions.
    Thoughts? Thanks!
  2. Dec 26, 2021 at 4:46 PM
    18" TRD Off Road Wheels
    Is your spare secured? If they loosen up they can thud about pretty readily.
    dinosaur likes this.
  3. Dec 26, 2021 at 5:09 PM
    g2turbo
    I will check that, thank you for posting.
  4. Dec 26, 2021 at 5:18 PM
    Aerindel
    Aerindel New Member
    Montana
    Have you greased your driveshaft? Particularly the rear propeller shaft. It telescopes to accommodate suspension travel, but also shifts from axle wrap under torque. Its normally filled with grease, which dampens this out, but if its dry, it will clunk under torque.
  5. Dec 26, 2021 at 5:55 PM
    g2turbo
    I have not, will give that a look tomorrow. Thanks for the input
  6. Dec 26, 2021 at 7:37 PM
    Aerindel
    Aerindel New Member
    Montana
    It its empty, you can put about half a tube of grease into it before it starts coming out, which would be a good indication that its your problem.
    One of those weird thing that I had never heard of before coming to this forum but sure enough, it was the source of my rear end clunk. It was kinda crazy pumping it in, you could see the shaft expanding like a hydraulic cylinder.
    FrenchToasty and Jack McCarthy like this.
  7. Dec 27, 2021 at 3:34 AM
    Would be a great opportunity to grease all the U-joints also. Especially if they haven't been done recently. I had a similar issue as you but at low speed and it was my slip yoke as Aerindel mentioned. I would also inspect your carrier bearing while you are under there.
    Here is an old post I've shared a few times on this subject. I didn't write this but found it on another site.
    "The driveshaft slip yoke has a zerk fitting for adding grease. There's a large void under the zerk fitting and it may take 30-40 pumps on a grease gun to actually get any grease on the splines, depending on how much grease was in there to begin with.
    Take your grease gun loaded with lithium-based NLGI #2 grease and start pumping grease into the slip yoke zerk fitting. At some point you will encounter increased resistance on the grease gun handle and see that the slip yoke is expanding. Continue to slowly add grease. You will likely see the slip yoke expand on each pump of the handle and then slowly contract. Continue adding grease for about five to ten more pumps or until you see grease coming out around the seal, then stop.
    Now get on the rear bumper and bounce it up and down a few times. This will compress the slip yoke and force more grease along the splines. Now take a wrench and remove the zerk fitting to allow excess grease to escape. Once the zerk is removed gently bounce on the bumper again to give it a little help. Clean up the expelled grease, re-install the zerk and you are good to go."
    https://www.tundras.com/threads/shutter-or-jolt-as-i-come-to-a-stop.39219/
  8. Dec 27, 2021 at 3:51 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Need to grease crackie's shaft... still haven't done that.
    shifty` likes this.
  9. Dec 27, 2021 at 5:20 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    That sounds dirty! :rofl:
    FrenchToasty and Tundra2[QUOTED] like this.
  10. Dec 27, 2021 at 5:32 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    alb1k and tvpierce[QUOTED] like this.
  11. Dec 27, 2021 at 7:57 AM
    tvpierce
    Maine
    Crackie or Conky? :eek2:
  12. Dec 27, 2021 at 8:06 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  13. Dec 27, 2021 at 10:58 AM
    Kandgo
    Kandgo New Member
    R
    2006 4door 4x4
    Good info!
  14. Dec 27, 2021 at 5:38 PM
    Yup. @g2turbo check this thread and click the links: https://www.tundras.com/threads/black-hole-zerk-wtf.93630/
    It'll maybe help you avoid my confusion with the process.
    alb1k likes this.
  15. Dec 27, 2021 at 5:41 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    This is Danny McBride right? @Tundra2 (s) brother.
