Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Dec 25, 2021 at 9:55 AM
    #1501
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Merry Christmas to you and your family as well!
    transfercass takes straight 75w gear oil. But just use the same shit you put in your diffs. 75 is impossible to find. If you pop the actuator off again make sure to move the shaft around until you can freely move the front drive shaft. The Your in 2wd proper.
    Tundra2[QUOTED][OP] and NUDRAT like this.
  2. Dec 25, 2021 at 9:56 AM
    #1502
    empty_lord
    05 rollover special
    Tundra2[OP] likes this.
  3. Dec 25, 2021 at 10:49 AM
    #1503
    Drain,
    Fill,
    27'lbs I think***
    Tundra2[QUOTED][OP] likes this.
  4. Dec 25, 2021 at 11:42 AM
    #1504
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Pretty sure my jeeps tcase used atf? Quick search said toyota uses 75w90 gear oil?
    KNABORES, w666 and Tundra2[OP] like this.
  5. Dec 25, 2021 at 12:01 PM
    #1505
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    How much fluid? Just till it comes out the fill port?
  6. Dec 25, 2021 at 12:08 PM
    #1506
    empty_lord
    05 rollover special
    Just like a diff
  7. Dec 25, 2021 at 12:08 PM
    #1507
    Yep. My manual says 1.1 quart.
  8. Dec 25, 2021 at 12:08 PM
    #1508
    empty_lord
    05 rollover special
    Only Toyota t cases that took atf were 2nd gen 4runners with the 3.0 slow
  9. Dec 25, 2021 at 12:34 PM
    #1509
    Tundra2
    Noah
    Western Kentucky
  10. Dec 25, 2021 at 1:31 PM
    #1510
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Could use new crush washers on fill and drain plugs although many swear you don't really need to change them. Just something to think about.
    Here's the how to thread from tundra solutions. One of these days I'll figure out how to hyperlink a word instead of posting the whole thing.
    Tundra2[OP], dinosaur and NUDRAT like this.
  11. Dec 26, 2021 at 1:32 AM
    #1511
    Tundra2
    Noah
    Western Kentucky
    Updated plan to combat the P0125 code... First verify readings are in spec from the oxygen sensors. I will do that today.
    Assuming everything is in spec, I will then order another T-stat and test it with vibeos.
    Assuming that doesn't fix it, the only other thing is the ECM...
    Filthyphil and NUDRAT like this.
  12. Dec 26, 2021 at 2:17 AM
    #1512
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Some mfgs. design their transfer cases to use the same lube as the ATF, just in case the seal between the two fails, and oil gets into the ATF fluid, or verse visa. Other mfgs design a seal that never fails (at least I'v never heard of this), and so gear lube can be used in the transfer case with low risk.
  13. Dec 26, 2021 at 4:31 AM
    #1513
    Tundra2
    Noah
    Western Kentucky
  14. Dec 26, 2021 at 3:41 PM
    #1514
    Tundra2
    Noah
    Western Kentucky
    So... did some more live data viewing and figured out why the fuel trims from the Oxygen sensors weren't reading earlier. It was because I was in open loop. The fuel trims only register when in closed loop.
    https://youtu.be/6zGs-PXFtsQ
    In this video I wrote on the screen when I noticed something I thought was interesting. At one point I pulled off the road, and turned the truck off. That put the fuel system in closed loop so I could see if all the sensors were reading fuel trims. They were not all reading.
    I restarted the truck around the 4:30 mark in the video. As soon as Bank 2, Sensor 1 Fuel Trim went positive (4:36) the truck switched from open loop to closed loop.
    The RL Bank 1, Sensor 2 never read any values for the Ms which can be seen around the 5:30 mark.
    All of the sensors are reading voltage. Bank 2, Sensor 1 needs more review. I think its a little sketchy...
    I might be looking in the wrong spots, or drawing inaccurate conclusions based on a lack of information about how the system operates as a whole.
    TL;DR: B1,S2 never read a Ms value when in closed fuel system. Need to check B2,S1 wiring...
    NUDRAT likes this.
  15. Dec 26, 2021 at 3:42 PM
    #1515
    Tundra2
    Noah
    Western Kentucky
    NUDRAT likes this.
  16. Dec 26, 2021 at 6:29 PM
    #1516
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    It looked like the fuel trims varied some between the two banks in closed loop. Also, what does the RL abbreviation mean?
  17. Dec 26, 2021 at 6:42 PM
    #1517
    Tundra2
    Noah
    Western Kentucky
    Rich Lean. I mean, given the history of this truck, I'm expecting some variance. I'm just not 100% sure what to do with this information...
    I'm expecting some variance given the history of this truck. Just unsure of a direction to pursue...
  18. Dec 26, 2021 at 7:34 PM
    #1518
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    Ah, thank you. After the engine went into closed loop, bank 1 is negative and bank 2 is positive. So the ECM is reading one bank too rich and the other bank too lean. That jumped out at me that it might be important. The sensor 2 downstream positions just check catalyst efficiency, so the B1S2 0 ms issue may not be a huge deal.
  19. Dec 27, 2021 at 2:01 AM
    #1519
    Tundra2
    Noah
    Western Kentucky
    Is it possible that the manifold are just a hair loose on either side? Could that be a potential cause of the too lean on one side?
    Also, according to the FSM page posted up above there are two B1,S2s. I'd be willing to bet that both front (upstream) oxygen sensors are Bank 1, and both the rearward (downstream) are Bank 2.
    Perhaps this is another typo like the amount of transmission fluid.
  20. Dec 27, 2021 at 3:18 AM
    #1520
    Tundra2
    Noah
    Western Kentucky
  21. Dec 27, 2021 at 5:35 AM
    #1521
    Tundra2
    Noah
    Western Kentucky
    @tvpierce, hoping to get your input on these issues, or at least advice.
  22. Dec 27, 2021 at 4:17 PM
    #1522
    Tundra2
    Noah
    Western Kentucky
    Been driving crackie since Saturday when I picked up the shell. Total of approximately 11 hours of driving time. I threw a worm drive hose clamp on my coolant leak before leaving to pick up the caaaaaappp.
    Hasn't dripped a drop, and the over flow reservoir is a little above where I had marked. Engine is hot, and I marked it cool. Normal.
  23. Dec 27, 2021 at 6:26 PM
    #1523
    Congrats on the 4WD working again.
    Don't have any input on the O2 stuff, sorry to say.
    Does your truck have the 1st gear / SHIFT L option you can combine with 4LO?
    https://www.youtube.com/watch?v=1znZ1lrqrDk
  24. Dec 27, 2021 at 7:06 PM
    #1524
    His is a 2000. So the shift options are different. Limited to the 4 speeds available. Can select maximum gear, 1-4 (OD)
  25. Dec 27, 2021 at 7:09 PM
    #1525
    Tundra2
    Noah
    Western Kentucky
    Thanks! @KNABORES is correct.
    I thought that shift L was a double cab only option.
  26. Dec 27, 2021 at 7:38 PM
    #1526
    empty_lord
    05 rollover special
    no, its a 05-06 thing with the 5 speed... was cheaper to do than designing a whole new shifter column to handle another gear option
  27. Dec 27, 2021 at 7:57 PM
    #1527
    Tundra2
    Noah
    Western Kentucky
    Can officially rule out coolant leaks as a cause of P0125, including the coolant sensor.
    dbittle likes this.
  28. Dec 27, 2021 at 8:35 PM
    #1528
    Tundra2
    Noah
    Western Kentucky
    Also, since we're still over 100 posts away...
    Post number 1,666 is reserved for whatever @w666 wishes to put there.
    RainMan_PNW and w666 like this.
  29. Jan 1, 2022 at 12:46 PM
    #1529
    Tundra2
    Noah
    Western Kentucky
    My new high mount stop light assembly finally showed up for the camper shell. I could tell it wasn't sealed worth a damn just like the reviews said.
    Drilled two holes in the back of it, and then filled that dude up with flex shot.
    The lighter grey line between the black back plate, and the silver reflector is all flex shot.
    It even smooged itself around the ends!
    Hoping to install on the next dry day...
    bmf4069 and shifty` like this.
  30. Jan 1, 2022 at 3:08 PM
    #1530
    daveeasa
    That's smart. I was dumb and didn't do that for mine. But it's cheap enough and not too hard to replace.
