Bugging Out - Help with Ideas
Discussion in 'General Tundra Discussion' started by Silv333, Dec 26, 2021.
  1. Dec 26, 2021 at 7:57 AM
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Hey gang, crazy times we are in, so I’m looking at setting up my 18 as a bug-out “if need be”. We have food supplies in a tote, “living supplies” in a tote, and enough fuel to get us by for a while (which would be loaded into the bed). To clarify, totes would go in the cab and fuel in the bed. My truck isn’t a daily driver, so certain things can be kept in the truck since it’s garaged.
    Of course a first option is to just stay home, which we are good to go. The leaving home scenario is where I could use some advice from you overlanders and outdoorsmen.
    The remaining questions I have are the following (feel free to share pictures of your setup);
    - Sleeping; is it best to just pack a tent and sleep on the ground (done this before but need to replace the tent), plan on sleeping in the truck, or buy some bull bars and make a platform over my bed cover to accommodate an overland style/platform tent (most expensive option)?
    - Comms; I wanted to put a CB (hidden) in my truck, reviewed certain Midland models, but wanted feedback on what you guys bought and have used. I’d also buy a few handheld Midlands (or something similar) to be used if someone ventures away from the base.
    - Supplies; we have food, water, fire, firearms. Other than comms and shelter, what else have you all found to be handy? We would also load in my Stihl Farmboss chainsaw, small Honda generator, and a sawzall with a selection of Diablo blades.
    Thanks for any advice, looking forward to the responses.
    AircareTundra and Black@Blue19 like this.
  2. Dec 26, 2021 at 8:23 AM
  3. Dec 26, 2021 at 8:25 AM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    IMO firearms is best to have in addition to the bigger caliber I always have on hand small caliber. 22lr. Pistol and rifle. As if you are forced on foot one can pack many rounds with not a lot of weight. Plus small caliber does have the penetration at close range and rifle for longer range. I have always said in the zombie Apocalypse this would be best. Plus the laws maybe different but if you dig down and read as I have most states 31 rounds are the most you can have loaded on a fire arm, 1 chambered and a mag with 30. Exception for 22 unlimited. So a 100 round mag with 22’s in it is a lot lighter. Live long shoot straight my friend.
    Black@Blue19 likes this.
  4. Dec 26, 2021 at 8:27 AM
    clarkritchie
    clarkritchie New Member
    Lots of good stuff on the Expedition Portal forums.
    Silv333[OP] likes this.
  5. Dec 26, 2021 at 8:28 AM
    AZBoatHauler
    So.Arizona
    For comms, I’ve also been looking into a dedicated truck unit but only have handhelds for now. A couple baofengs.
    For supplies; I’ll throw out what I carry that I didn’t see mentioned:
    • Water filters for purifying
    • Solar generator to be able to silently charge electronics and have a non-fuel based power supply
    • Bolt cutters
    • Air compressor
    • Flat tire repair kit
    • Basic hand tools / hacksaw / dmm
    • Silky saw
    • Hatchet / hammer
    • First aid kit
    • Hi-lift with enough chain and straps for recovery or winching
    • Emergency flares
    • Sillcock key
    • Ratchet straps
    • 550 cord
    • Atlas / topo maps
  6. Dec 26, 2021 at 8:33 AM
    Silv333
    NJ-NC-MD-NC
    Thank you!
  7. Dec 26, 2021 at 8:37 AM
    Silv333
    NJ-NC-MD-NC
    ***Mod edit. You have the freebie today.
  8. Dec 26, 2021 at 8:40 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I would prep for two stages: one is fleeing and limited infrastructure. Have a ham radio, fuel, weapons, etc. And that is to know what's happening and to get you away from the citidiots and whatever shit is going down.
    The second stage would be assuming you run out of food and fuel (and by extension electricity) which wouldn't take very long. Then you need gear to extract resources from nature for the rest of your life. Flint, fire starters, water purifier, compass, pan to boil water, knife, paracord, mirror, shit like that to start.
    First stage of supplies gets you threw the breakdown if society, second stage is survival in the wilderness. Covers the short game and long game.
  9. Dec 26, 2021 at 8:40 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    You mentioned some stuff I was going to throw out there. One thing I’ll add is a way to start fire. You can buy really good fire starting materials from places like Bigfoot Bushcraft, or make your own. I have several kits in each vehicle that are: lighter and cotton balls coated in Vaseline inside an old Altoid tin. Those will fit just about anywhere. Also, 1 is none and 2 is one. Some of those things aren’t really possible to have backups for, but water purification and fire starting materials are easy.
    EDIT: One crucial thing I forgot: booze, for dual purpose use. 1) if that situation happens, you’ll probably need a drink at some point 2) Good for bartering if need be. Bartering still has its place I think.
  10. Dec 26, 2021 at 8:44 AM
    TaquitoBandito
    Joel (AKA Bif)
    I believe you have my address so I'm thanking you in advance for coming down here and picking me up. I'm pretty good at carrying stuff and can make a hell of a smore.
  11. Dec 26, 2021 at 8:50 AM
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd tow package
    Bugging out...
    This is one area where I look at it in the reverse order, first. I keep a "get home" bag in the truck.
  12. Dec 26, 2021 at 9:00 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Have a stack of small denomination bills. $100 in 1's $100 in 5's $200 in 10's and $500 in 20's. When things go weird and you're in a pinch, you don't want to stuck with just big bills and pay $100 for a loaf of bread because you only had $100 bill. Just a quick exaggerated example, but you get the point. I like this thread! Some great ideas!
  13. Dec 26, 2021 at 9:26 AM
    AZBoatHauler
    So.Arizona
    There is the Christmas spirit.
  14. Dec 26, 2021 at 9:36 AM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    I would think one would need several different bug out kits to be prepared for a wide variety of circumstances. I’m just going to stay home where I can fit more stuff, help my neighbors, and wait for government to rescue me. Wait, I am the government. Or am I?
    Also, I can run my generator for a long time on one tundra size tank of gas but I can’t drive it far.
    Edit: can’t drive the Tundra far.
    Cpl_Punishment likes this.
  15. Dec 26, 2021 at 9:43 AM
    2mchfun
    Best to have two bases fully equipped. For example, f5 twister or explosion completely destroys base A. You relocate to base B and immediately restore or replace base A. Keep an old EZ to work on and mostly dependable, fairly popular (ez parts access) vehicle at base B. Whatever you do, have certified copies of all important documents in two locations. Two big things I didn't see in your stuff are paper maps and garden seeds.
  16. Dec 26, 2021 at 9:54 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Beer. Lots of beer.
  17. Dec 26, 2021 at 10:01 AM
    2mchfun
  18. Dec 26, 2021 at 10:11 AM
    Cash
    Guns
    Ammo
    Plenty of filled gas cans
  19. Dec 26, 2021 at 10:17 AM
    Silv333
    NJ-NC-MD-NC
    Have that…
  20. Dec 26, 2021 at 10:21 AM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    We had to go 5 days without services in an ice storm in 96. Brought camping gear inside and went with it. Always kept bulk propane tanks filled and my Camp is set up to run off that. Heat, light, cooking. Had that happened in the Summer, would have lost food, so a generator and 40 ish gallons of Star Tron treated gas have been added. Gas is rotated every 2 years. For water, consider a large gravity flow filter. Fill at nite and let it work.
    If you are looking at the long haul, a couple additional ideas, keep chickens and make sure any seeds are the heirloom variety so you can harvest seeds for the next year. I also keep a supply of curing salt for meat preservation. Canning supplies and a book or three on the “old ways” will come in handy too.
  21. Dec 26, 2021 at 10:25 AM
    Silv333
    NJ-NC-MD-NC
    This is hilarious. You crack one at me, I reply with factual information, and then I get a “freebie”.
    :thumbsup:
    ColoradoTJ likes this.
  22. Dec 26, 2021 at 10:34 AM
    Pmac
    Pmac New Member
    Last I saw fewer than 10 states had magazine capacity limits. Where are you finding the magazine limit info? As a practical matter, more cartridges = more weight to carry, so moderate capacity is probably just fine. I keep 15 ish rounds in a 20 round mag in my home AR and am pretty sure I’m good. But if one is more comfortable with a 60 round drum, go for it.
  23. Dec 26, 2021 at 10:37 AM
    JLS in WA
    Those big drum magazines are stupid and just create more likelihood of malfunctions. You are fire better off having multiple 20 to 30 round magazines than one big one.
    poheller, 2mchfun, 1lowlife and 2 others like this.
  24. Dec 26, 2021 at 10:46 AM
    Have you ever seen Defiance by any chance? Great movie that could shine a little light on what you are trying to do.
    Seen “Defiance” on Netflix yet?
    https://www.netflix.com/us/title/70101696?s=i&trkid=13747225&vlang=en&clip=81030735
  25. Dec 26, 2021 at 10:47 AM
    Well, when you post something that can earn you a vacation...I would call that being more than fair and a freebie.
  26. Dec 26, 2021 at 10:50 AM
    Ho Ho Ho.
    I actually like this topic, but will stay out of it. I went off the deep end and wound up doing something totally different and a lot better approach.
  27. Dec 26, 2021 at 10:53 AM
    Silv333
    NJ-NC-MD-NC
    Got it, one sided trash talking, although factual from my side. What was the violation?
    porkitt likes this.
  28. Dec 26, 2021 at 10:54 AM
    glowblue
    glowblue From time to time
    VA
    If you seriously want a good bug out rig, I’d find a 1960s-1970s pickup, EMP blasts will disable all modern vehicles.
  29. Dec 26, 2021 at 10:54 AM
    Silv333
    NJ-NC-MD-NC
  30. Dec 26, 2021 at 10:55 AM
    I'll PM you.
