Front Speaker information re 2006 DC Non-JBA
Discussion in '1st Gen Tundras (2000-2006)' started by Zippy0n, Dec 25, 2021.
  1. Dec 25, 2021 at 3:02 PM
    Zippy0n
    Zippy0n [OP] New Member
    2006 Tundra DC
    Hello all and MERRY CHRISTMAS!
    What better way to spend Christmas than to consider which front speakers in install into your Tundra.
    Please note, I have searched extensively to establish what route to take, but to no avail since all other rite-ups are JBL related.
    I have a Non-JBL Double Cab (2006 model). I have already installed an aftermarket Sony XAV-AX1000 Double din unit into the truck of which I absolutely love and highly recommend to anyone looking for a touchscreen stereo.
    Has anyone got any advice which speakers and or mounting bracket work for this? I'm aware of Crutchfield but have heard that people have had to modify what Crutchfield had sent them...
    Thanks in advance and hope you are having a blessed time.
    Dave
    TRDGen likes this.
  2. Dec 25, 2021 at 4:59 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I highly recommend Kicker or Rockford Fosgate speakers. I had em in previous trucks and loved em. I cheaper out this time with Walmart Sony speakers and I'm not impressed despite powering them with a 5 channel amp instead of my pioneer screen. I will likely replace with kickers in the front doors at least, when I upgrade the stock tweeters.
    Riverdale21 likes this.
  3. Dec 25, 2021 at 6:19 PM
    growit
    growit New Member
    2006 Dbcb SR5
    I used Kickers for my 2006. The mounting brackets Crutchfield sent did not work and I just ended up cutting out original speakers and reused the brackets.
    Had to do some minor soldering for wiring on the brackets. Everything worked out well and sounds great.
    TRDGen likes this.
  4. Dec 25, 2021 at 6:42 PM
    There should be a window track mod that sets the window back 1/4-1/2 inch in the event the speaker you want is slightly too big(deep). Ive heard it being done on a 2000-2003 Tundra AC cab. I'm not so sure about 2005-2006 DCs.
  5. Dec 26, 2021 at 5:57 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    I've got the same non-JBL 2006 DC with 5.25" 2 way Kickers up front, but it looks like the front doors could have fit 6.5". And 6.5" 2 way kickers in the rear. I've also got a 900w 4 way amp to power the door speakers and a 300w self powered Rockford 8" sub under the front passenger seat. If I ever change out my door speakers for Rockfords I will try to go 6.5" component up front, but this system came from my old 4Runner and I'm satisfied with the sound quality.
    I used wiring adapters and speaker mounts front/rear. The physical mounts I got from Crutchfield, the wiring adapters from Amazon.
    (2) Pair of Metra 72-8104 Speaker... https://www.amazon.com/dp/B01GEIP7RW?ref=ppx_pop_mob_ap_share
    https://www.crutchfield.com/p_142SAT6/Scosche-SAT6-Speaker-Mounting-Brackets.html?tp=2824
    https://www.crutchfield.com/p_120828153/Metra-82-8153-Speaker-Mounting-Brackets.html?tp=2824
    I don't remember exactly which model Kickers I have, they were purchased from Best Buy years ago. I remember there being plenty of room behind the magnet where nothing would collide. The adapters fit without interfering with the door panel.
    Zippy0n[OP] and Darkness like this.
  6. Dec 27, 2021 at 10:53 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I replaced all of the JBL stuff in my 06 DC I bought everything from Crutchfield and it worked great! By replacing all of the JBL stuff it basically turned it into what you have so the brackets and everything should work fine.
    I put the crutchfield brand components up front and memphis coaxial in back. It's a budget system, but sounds pretty good to me I do have a JL sub sitting on the back seat also.
  7. Dec 27, 2021 at 1:26 PM
    Zippy0n
    2006 Tundra DC
  8. Dec 27, 2021 at 2:58 PM
    rock climber
  9. Dec 27, 2021 at 3:08 PM
    Zippy0n
    2006 Tundra DC
    yes, but i assume that the new 2 way speakers will overide the stock tweeter already installed? (or am i talken outta my arse)
  10. Dec 27, 2021 at 3:19 PM
    fighthedude
    fighthedude New Member
    Id buy some tweeters. They should have an inline filter to only give you highs! I just put a set of infinity reference series in my honda and it was noticeable over stock. All my speakers had already been replaced but those. Or return the kickers and buy a component setup. Your doing all the work so go the extra step and do it right. Just my thought.
    Zippy0n[OP] likes this.
  11. Dec 27, 2021 at 3:27 PM
    Zippy0n
    2006 Tundra DC
    I could install these speakers coming in the rear, then install a component setup in the front? (if that is possible)
  12. Dec 27, 2021 at 5:22 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Installed Rockford FG all around my access cab a few years back. The slight mod needed with the factory speaker holder was pretty minimum. Hardest part was getting the door panels off. Toyota made the install process simple.
  13. Dec 27, 2021 at 6:39 PM
    If you want concert level sound, great repro, best bang vs. buck is JBL's "Club" series which can be had at Crutchfield all day long and they'll send the adapters also. Comes as tweet/mid separates with crossovers.
    There's a reason JBL's stuff is used for so many live events. Haven't seen Kicker or Rockford monitors at any live music or club venue in my lifetime. But I see you bought the Kickers, and I'm sure you'll be happy with those, I'd put in rear and get JBL separates (Club series) up front. You want to keep your kids and tweets up front paired if possible.
    I'll use Kicker or Punch subs in my vehicles all day, actually have 2 Kicker DVC 8's in my AC (though I prefer JL), but for anything in the highs and mids, and higher lows, JBL all the way.
    And JL amps :D
  14. Dec 28, 2021 at 8:14 AM
    rock climber
    I would. You already have a tweeter location up front and components aren't much more than coaxial.
    You'll need new brackets for the rear speakers
