Bilstein 8112 / 8100 are finally out for the 14-21 tundra
Discussion in 'Suspension' started by Flyinryank, Oct 3, 2020.
  1. Oct 5, 2020 at 9:03 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    I don’t believe the 3.0’s are IBP. BP-51’s are I believe.
  2. Oct 5, 2020 at 9:37 AM
    GravityGear
    Aurora, CO
    I believe IBP is a separate shock/option. The base model stuff, even the 3.0, comes with a standard shim stack. The piston configuration will be different with the IBP shocks. There's actually 2 pistons, one bypass and one standard. There's a pin that sticks down from the top which activates the standard stack when the travel gets towards the bump zone. I'm not aware of any bolt-on IBP options from either fox or king. You'd have to run a bucket to eyelet adapter. I might be wrong, but this is the impression I'm getting.
  3. Oct 5, 2020 at 10:10 AM
    Elduder
    Elduder New Member
    In my limited experience with Billies and the Tacoma, I hope the 8112s for the Tundra make a decent deviation from their Tacoma apps. I ran 6112s and 5160s on my Tacoma and it was decent, I really liked them, until I snagged a ride in my friends truck with Kings. He actually had the 8112s on his Tacoma prior to going with Kings.
    Both the 6112 and 8112 rode noticeably stiffer than the Kings. For daily use the Kings were just so much more comfortable. I suppose slow speed off roading, like trails and technical stuff, the Billies might be better suited. They were quite good at stopping rebound.
    Once I moved into the Pro Tundra with the stock Fox suspension I felt the same way my friend did when he switched to Kings. I know they're different trucks but the outcome felt very similar with the change from 8112 to Kings on his Tacoma. The drive home in my Pro was night and day over the 6112s.
    Suspension is very subjective though, it's just that at this price point I recommend people try to get a ride along first.
  4. Oct 5, 2020 at 10:36 AM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    Baja 1000 truck is running Bilstein Blackhawks. Not in even in the conversation of the same product, price or setup. You're talking about $10000+ racing shocks.
  5. Oct 5, 2020 at 11:12 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    Thanks for the info, I was not aware of those shocks.
  6. Oct 5, 2020 at 11:56 AM
    ChillTree
    ChillTree New Member
    2019 Tundra Platinum
    TRD Pro Rims
    the PRO fox shocks are so much sexier lookin tho imo
  7. Mar 25, 2021 at 9:05 PM
    a_double
    a_double New Member
    I just read 1+ pages of this thread and there are more comments about products other than the Bilstein 8k stuff. :)
    I'm interested in 8k feedback as well. The thing that I don't understand, and maybe someone can clarify, they have UCA limitations listed in their install docs. Some UCA's can only run with the 8112's in the highest setting. That's what stopped me from considering these.
    https://productdesk.cart.bilsteinus.com//media/products/bilstein/E4-WM5-Y627A00_1.pdf
    Flyinryank[OP] and AggiePhil like this.
  8. Mar 25, 2021 at 9:11 PM
    a_double
    a_double New Member
    BTW, it looks like the 8112's are being offered at 15% off right now.
  9. Apr 6, 2021 at 3:55 PM
    HuntTruck
    HuntTruck New Member
    Does anyone have these yet? Curious about them...
    Flyinryank[OP] likes this.
  10. Apr 13, 2021 at 8:09 AM
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    That is a bit of a deterrent. Odd that only three aftermarket UCA's (Dirt King, Built Right and Camburg) work with these.
    @eccracer104 thought you would find this interesting as well.
    eccracer104 likes this.
  11. Apr 13, 2021 at 9:27 AM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Thanks for the tag Bob!
    Yes I’ve seen it. Was wagering a gamble opting for MCM arms as opposed to the recommended from Bilstein.
    I’ve got some time before suspension will be upgraded, going to re-evaluate when the time comes but these are still top of the list for now. I really like how they function, and the bump zone will definitely come in handy with the desert driving I do down here: but that’s a moot point if I plan for a secondary (which I am at some point). So many options, all great, but also stressful to get “the right one” haha.
    Drainbung[QUOTED] likes this.
  12. Apr 13, 2021 at 9:36 AM
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
    Understatement for sure!
    eccracer104[QUOTED] likes this.
  13. Apr 14, 2021 at 8:17 AM
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Agri-Cover,RCI skid,ADARAC,Fox 2.0,TruDuals
    Massive shocks and upper tower fabrication and still using what looks like OE UCAs. :cool:
  14. Apr 14, 2021 at 8:52 AM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    Its required to run OEM UCA's per class 8100 rules in SCORE. You can only change the springs and shock. No mods to the major suspension components.
    Torque[QUOTED] likes this.
  15. Apr 18, 2021 at 6:16 PM
    cain0725
    cain0725 New Member
    if the 6100 dont ride good i will be selling and moving to something stupid! I had a raptor and it was the best riding truck i ever had! To bad i hated the V-6 no matter how fast it was.
    2021 Semi Pro likes this.
  16. Apr 18, 2021 at 6:17 PM
    cain0725
    cain0725 New Member
    i probably should have went with something better!
  17. Apr 18, 2021 at 6:20 PM
    akmerle
    akmerle New Member
    Wasilla, AK
    2018 Tundra Platinum & 2024 GX550 OT
    For best ride, I’ve heard the Fox Trd Pro shocks are extremely hard to beat. Have also heard Kings for the best ride.
  18. Nov 6, 2021 at 4:29 PM
    Flyinryank
    Flyinryank [OP] New Member
    Las Vegas, NV
    White 2015 CM 4x4
    I took advantage of the discount
    Order placed. Should arrive mid December.
    https://youtu.be/XqLVRJbJ2vQ
  19. Nov 6, 2021 at 6:14 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Good price
  20. Dec 24, 2021 at 2:39 PM
    #50
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    After waiting almost 2 months I finally got theses beefy mofos
  21. Dec 24, 2021 at 2:46 PM
    #51
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    when is the install ??!!
  22. Dec 24, 2021 at 2:48 PM
    #52
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    After the New Year. I have to have one of my rear ADS shocks rebuilt after Sedona. Gonna do try and do everything at once
  23. Dec 24, 2021 at 4:16 PM
    #53
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
  24. Dec 24, 2021 at 4:33 PM
    #54
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Hell gyeah dude! Excited
    Sumo91[QUOTED] likes this.
  25. Dec 24, 2021 at 5:12 PM
    #55
    Sumo91
    TN
    I plan on hitting some trails in the next couple weeks and will be posting my thoughts as I put some miles on these, we should definitely post both of our results after using them on and off road, I haven't read any real reviews on these for the tundra application yet. I feel it would be very beneficial for our community, and maybe we can convince more people to pull the trigger on these bad boys :fistbump:
  26. Dec 24, 2021 at 6:17 PM
    #56
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    For the Friggen street?
    Really dudes, lay off the wacky weed and start taking some of that stuff that makes you smart....er
  27. Dec 24, 2021 at 8:45 PM
    #57
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    If you're driving on the street then stick with stock. Maybe smoke less and you'll realize what thread you clicked on next time.
  28. Dec 24, 2021 at 10:10 PM
    #58
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    I’ll test mine at T2S 2022 :thumbsup:
    Gee Dub, SAGE63 and Sumo91[QUOTED] like this.
  29. Dec 25, 2021 at 6:30 AM
    #59
    Nowhereman
    Al
    Monterey Bay area
    I know what thread I clicked on, Einstein. Dropping that much coin for a shock that will see the street more often than not is insane. Unless you have someone picking up the bill for you which most do not.
  30. Dec 25, 2021 at 6:54 AM
    #60
    Sumo91
    TN
    Almost every 2nd gen tundra is mainly a street vehicle. They're daily drivers. But when we do take them off road, it's great to have the performance these shocks provide, not to mention the amazing on road ride quality you get from them everyday. They blow away the 6112s in every aspect. Worth every penny imo. I'll be getting the rear shocks to match next year.
    And if most tundras see nothing but street use, why upgrade them at all? Skids? Sliders? Lift? Bigger tires? It's because alot of us use them off road and need a daily driver that is also capable off road. Sure, having a dedicated off road rig is nice, but having one rig to do it all is even better, and cheaper than having 2 trucks.
    I also bought my truck used, for 18k, so if I sank 30k into mods, that brings the price to 48k, which is still cheaper than a new platinum, and I get way more enjoyment and capability than a new stock truck, and my truck will realistically last just as long. I have zero intention of getting rid of this truck in the next 15 years, so I'm making it into what I want it to be, so I can enjoy it for years to come.
