Red oil drip from skid plate
Discussion in '2nd Gen Tundras (2007-2013)' started by TundayFunday, Dec 22, 2021.
  1. Dec 22, 2021 at 2:19 PM
    TundayFunday
    TundayFunday [OP] New Member
    2007 Tundra SR5 5.7
    Is this transmission fluid? Please god no. It’s at the front, so I have no clue what’s dripping. Just noticed.
  2. Dec 22, 2021 at 2:20 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Power steering perhaps.
  3. Dec 22, 2021 at 2:22 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    sure it is oil? the coolant looks red/pink when dripping. And then PS, trans fluid are possible.
  4. Dec 22, 2021 at 2:34 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Usually antifreeze from the water pump. But just climb under and follow it up.
  5. Dec 22, 2021 at 4:35 PM
    TundayFunday
    2007 Tundra SR5 5.7
    Drip there after removing skid plate. I think a watery drip? But sorta has a goop to it. Awesome stuff after blowing cash on Christmas gifts.
  6. Dec 23, 2021 at 1:46 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    You may have a water pump that isn't 100% sealed, or you may have a coolant leak in the valley. Neither of these problems is the end of the world, especially if you are willing to work on your own rig. You can pressure test the system to see how bad it is with the engine not running. Toyota has a document somewhere about what normal water pump leakage looks like, but I would err on the side of caution and just plan on replacing it if that's where the drips are coming from.
  7. Dec 23, 2021 at 3:57 PM
    audiowize
    Paul B.
    I think this is what I remember seeing. You're not necessarily supposed to replace the pump for #3, but I sure would.
    JLS in WA likes this.
