If You Drive in Snow. DONT BUY A TUNDRA
Discussion in 'New Member Introductions' started by Bmfsonn, Dec 23, 2021.
  1. Dec 23, 2021 at 1:24 AM
    Bmfsonn
    Bmfsonn [OP] New Member
    Have a 2021 Tundra. All things about its traction control and ABS make it one UNSAFE winter truck.
    Toooooo much Computer Control. Its pathetic.
    Mr Badwrench and 16CMTXED like this.
  2. Dec 23, 2021 at 1:51 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Search around the 2.5 gen section for what they call "beast mode" you can disable every bit of the traction control system. Have to push the button a certain way and it will disable all. Heck someone makes a harness so it disables everything everytime you get in the truck.
    As far as ABS goes; not sure about anything to do with that. Pull ABS fuses maybe.
  3. Dec 23, 2021 at 2:46 AM
    CMikeB
    CMikeB New Member
    It's also pretty pathetic to 'free-wheel' around in overdrive in slippery conditions, instead of "daring" to use the Sequential Shifter and choosing a lower gear, to help stay in control. The Owner's Manual can help too but just like learning about the Sequential Shifter, it takes Effort.
  4. Dec 23, 2021 at 2:59 AM
    Burdturger
    Burdturger New Member
    Welcome and thanks for the tip. I'll guess I'll have to pass on the 21 and keep my 19. My 19 doesnt have problems in snow. Maybe you should have gotten a 19. maybe they replaced the drivers intelligence module in the 21 and therefore its unsafe. Yeah thats probably it.
  5. Dec 23, 2021 at 3:01 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Is it Friday already?
  6. Dec 23, 2021 at 3:15 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  7. Dec 23, 2021 at 3:19 AM
    Ó Brádaigh
    Ó Brádaigh New Member
    S. Polychronopolous
    21MGT
    Patiently waiting...
    Dont drive in the snow...
    Half Assed, T500, Baja Mike and 7 others like this.
  8. Dec 23, 2021 at 3:20 AM
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    Welcome to the forum OP:thumbsup:
    Drivermcgyver likes this.
  9. Dec 23, 2021 at 3:24 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Welcome! One of the best introductions around here in a long time. You will fit right in around here!
  10. Dec 23, 2021 at 3:25 AM
    Adam New Member
    Did you hit a mailbox and almost go careening off a cliff?
  11. Dec 23, 2021 at 3:29 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Bear, RainMan_PNW, ToyoMafia and 4 others like this.
  12. Dec 23, 2021 at 3:41 AM
    PermaFrostTRD
    Northern NY
    *laughs in Lake Effect*
    WFD473, T500, sf319 and 5 others like this.
  13. Dec 23, 2021 at 3:43 AM
    Earthsurfer
    Earthsurfer Randyman the Handyman
    Randell
    Edwards, CO
    21 Tundra limited
    Rear sway bar, trd air filter, running boards, sound deadener in doors, upgraded speakers, cargo glide, topper, Roof racks, overland awning.
    I live in the mountains of Colorado and I drive in the snow all the time.
    Sure if you expect a 4wd truck to perform well in snow and ice get yourself some good snow tires and it’s night and day difference.
    I have Blizzak snow tires and I only use 4wh dr when I have too.
  14. Dec 23, 2021 at 3:54 AM
    CMikeB
    CMikeB New Member
    Yep, I knew it; we're TWINS!:D
    07DCLimited and Bobbyd like this.
  15. Dec 23, 2021 at 4:09 AM
    mikesTundra77
    mikesTundra77 BRAAAAP BRAAAP
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
    4 " ready lift kit General grabbers 35" Rock warrior wheels 17" Leather Clazzio seat covers KN intake StartX remote starter HRS sequential tails Custom grille+badge ME-SO map lights+dome light Lots of CHROOOOME
    I live in Canada and drive a 2018 sr5 tundra. (Enuff said) So.... not sure what all this *whinging* is about.
    Mobeyk, coldcanuk, jpod and 20 others like this.
  16. Dec 23, 2021 at 4:13 AM
    thedonn
    thedonn New Member
    have you read the manual to see how to turn everything off? also in a high snow area get some specialty tires on take off wheels
  17. Dec 23, 2021 at 4:18 AM
    Wahayes
    Will
    2017 tundra limited *sold*
    Does fine for me, and we get a "little" bit of snow where I live lol
  18. Dec 23, 2021 at 4:24 AM
    Welcome to the site.
    Well, guess Alaska is pretty extreme at times for snow….
    What is the truck doing specifically?
    jewsNbrews, WILLINH, sf319 and 6 others like this.
  19. Dec 23, 2021 at 4:29 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Imagine driving on melted snow!
  20. Dec 23, 2021 at 4:30 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I had this same problem. It's your tires, not the truck. I put BFG KO2's on and it solved the problem. Put a 3 peak snow rated tire on your truck and you'll be good to go.
  21. Dec 23, 2021 at 4:36 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    It's not just Tundra...what was your last vehicle?
    Cpl_Punishment likes this.
  22. Dec 23, 2021 at 4:44 AM
    timsp8
    NY
    Right there with you. Only problem I have is stopping because the truck weighs so much. I do like others said though and ride a lower gear.
    Winter driving isn’t all on the vehicle. Alot is on the driver too.
    bjp, sf319, Wallygator and 6 others like this.
  23. Dec 23, 2021 at 4:50 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    The 2019s use transmission heat to melt the snow in front of the truck.
  24. Dec 23, 2021 at 4:58 AM
    CMikeB
    CMikeB New Member
    WHAT?:eek: You mean the "operator" has some remote responsibility regarding safe driving? Why doesn't the truck know what it's doing?:lalala:
    RCwyoming, sf319, PG94 and 5 others like this.
  25. Dec 23, 2021 at 5:04 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome.. We will try our hardest to not make this another UGLEE roast... Again welcome to the Tundra family.
    jewsNbrews, sf319, PG94 and 2 others like this.
  26. Dec 23, 2021 at 5:10 AM
    Kung
    KG, VA
    Thank you for this in-depth objective review. :bored:
  27. Dec 23, 2021 at 5:16 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Hmmm that’s a strange review. My Tundra did amazing in the snow.
    Saltyhero13, WILLINH, sf319 and 6 others like this.
  28. Dec 23, 2021 at 5:19 AM
    Kung
    KG, VA
    Same. Both our vehicles (2020 Tundra and 2020 Highlander) have been great.
  29. Dec 23, 2021 at 5:23 AM
    Burdturger
    Wait wait wait, no one has asked OP what color his tundra is. This could be the source of his problem. He just got the wrong color. We all know Cav blue tundra's were born for the snow. Heh.
    D4x4TRD, jewsNbrews, Mike59 and 6 others like this.
  30. Dec 23, 2021 at 5:32 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Really OP? It’s a rear wheel drive pickup with a large V8…with that said I have zero problems in the snow with mine. Oh by the way welcome…
