1st Gen Tundra Armor Thread
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, Aug 8, 2019.
  1. Nov 26, 2021 at 7:08 PM
    #241
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I use my CO bumper as a table too lol
    des2mtn and dinosaur like this.
  2. Nov 30, 2021 at 9:50 PM
    #242
    ToyoLife
    ToyoLife New Member
    06 DC Limited 4x4
    Did you go with Steel or Aluminum? I'm debating which route to take. I don't mind spending the extra cash if it's worth it.
  3. Nov 30, 2021 at 11:03 PM
    #243
    TRDGen
    TRDGen Schnooogins
    Travis
    Steel. It's still pretty light (just 23lbs heavier I believe) and will take a beating better than aluminum will
  4. Dec 10, 2021 at 4:55 PM
    #244
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Anyone know what rear bumper this is?
    FirstGenVol[OP] and TRDGen like this.
  5. Dec 10, 2021 at 7:55 PM
    #245
    TRDGen
    TRDGen Schnooogins
    Travis
    Probably custom
    Voss[QUOTED] likes this.
  6. Dec 10, 2021 at 8:07 PM
    #246
    Voss
    Valod
    2003 AC TRD 4x4
    Was afraid of that
  7. Dec 10, 2021 at 8:32 PM
    #247
    FirstGenVol [OP] Check the name tag. You're in my world now.
    I dunno but it looks sexy.
    TRDGen and Voss[QUOTED] like this.
  8. Dec 10, 2021 at 8:34 PM
    #248
    Voss
    Valod
    2003 AC TRD 4x4
    Damn right it does and look at that clearance
  9. Dec 11, 2021 at 8:27 AM
    #249
    Voss
    Valod
    2003 AC TRD 4x4
    alb1k likes this.
  10. Dec 22, 2021 at 5:24 PM
    #250
    daveeasa
    Brute force fab rear bumper, non high clearance model. A bit tight on the right side but likely my bedside is pushed in a bit or something. The mounting holes were just a hair too tight on that side though. A plastic piece up top for the tailgate gap might be nice too. Overall it’s my pick for steel rear bumper, not significantly heavier than stock really.
    40AE3AD5-25DA-42AE-91D0-DABACE47BDDB.jpg 58F63457-2071-4493-A15B-32C069B10CC0.jpg
  11. Dec 22, 2021 at 5:28 PM
    #251
    TRDGen
    TRDGen Schnooogins
    Travis
    Looks great. I painted the tail gate gap black on mine
    daveeasa[QUOTED] likes this.
  12. Dec 22, 2021 at 6:39 PM
    #252
    Looks great. Do you mind sharing what Billy charges for that one? How difficult is it to remove the OEM bumper? I've never looked.
    JustJake likes this.
  13. Dec 22, 2021 at 8:36 PM
    #253
    TRDGen
    TRDGen Schnooogins
    Travis
    Super easy to remove. It's like 6 or 8 bolts iirc
  14. Dec 22, 2021 at 9:38 PM
    #254
    daveeasa
    Removal was easy, hitch first then bumper. Just 3x12mm bolts for my oem bumper. I de-pinned the plate light connectors and replaced them. The alternative is remove the plastic cap to feed them out. Shifty covers that in his DIR install.
    Bumper with PC was near $1k ish? Maybe a tad shy. Better value to get the high clearance option but I didn’t want to cut bedsides nor did I want the look. Given a factory bumper is at least $250, I’m ok with the cost but it wasn’t exactly a great financial move.
  15. Dec 22, 2021 at 9:39 PM
    #255
    daveeasa
    Surprisingly easy with no hitch. I had help from a neighbor but it is doable solo.
  16. Dec 22, 2021 at 10:19 PM
    #256
    TRDGen
    TRDGen Schnooogins
    Travis
    Mine had the hitch integrated into it so it was heavy and took a 2nd person to help me
  17. Dec 23, 2021 at 5:47 AM
    #257
    Same here. I have no desire to cut my bed right now. Beds for these trucks are going to get impossible to find at some point and I don't want to cut a perfectly good one.
    Couple more questions. Can you still use the original hitch or no? Next question and this one is very important. Did you apply fluid film to all critical areas while the bumper was off?
  18. Dec 23, 2021 at 5:57 AM
    #258
    daveeasa
    The design has an integrated hitch and mounts to the sides and bottom of the frame rails. You might be able to bolt a hitch below it with proper length bolts. My Curt used three bolts per side while this design only uses the rearmost two. So you would need a spacer of similar thickness if your hitch needs all 3 spots, or you might be all set if you just need 2? And your hitch would be lower than before by the thickness of the metal.
    I’m not sure if the holes were drilled or present from the factory. Only one is threaded, the other two are just open.
    I did not use any fluid film.
    I can post photos from the undercarriage to illustrate what I describe.
  19. Dec 23, 2021 at 6:09 AM
    #259
    :notsure:
    Darkness likes this.
  20. Dec 23, 2021 at 6:10 AM
    #260
    daveeasa
    I do not own any fluid film.
  21. Dec 23, 2021 at 2:20 PM
    #261
    You live in CA. The air is magic and has fluid film in it!
    DesertRoads and Darkness like this.
  22. Jan 16, 2022 at 9:14 AM
    #262
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    This is why I got one as well. Every Tundra I've ever seen with a rear bumper collision had also damaged the bed substantially.
  23. Jan 16, 2022 at 2:22 PM
    #263
    Voss
    Valod
    2003 AC TRD 4x4
    I wouldn’t say completely defeats the purpose. I haven’t hit my spare tire from what I know but I’ve hit my hitch receiver and bumper countless times. That section is considerably higher than my current stock setup.
    FrenchToasty, Darkness, alb1k and 2 others like this.
  24. Feb 6, 2022 at 8:48 AM
    #264
    Casper421
    In the woods
    06 DC
    @FrenchToasty whats the heaviest you’ve towed with your coastal rear? Would you be comfortable towing 7k? CO says tow rating all depends on the welders skill or some release of liability bs.
  25. Feb 6, 2022 at 8:51 AM
    #265
    daveeasa
    I’ve been wondering the same for my BFF.
  26. Feb 6, 2022 at 9:12 AM
    #266
    Haha maybe 1000 lbs? Just this 12’ aluminum boat loaded the eff down with wood and other camping stuff.
    If I were to tow something heavier, I would have boxed in the bumper and maybe added gussets from the hitch out to the frame rails. I feel like there would be a lot of deflection in the steel with to much tongue weight, but I guess it could handle towing weight just fine. BF13BFC2-6790-4872-92CF-BEB482C996F6.jpg
    805Tundra and Darkness like this.
  27. Feb 6, 2022 at 9:42 AM
    #267
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup. Plus you can easily toss the spare in the bed whenever you hit the trails.
  28. Feb 6, 2022 at 10:02 AM
    #268
    daveeasa
    Is that what your hooks are for? I was thinking through this as a potential backup plan if I can't fit my 285 underneath. Seeing as how I have a fair bit of bed space. I might try to rig something up...
    Darkness[QUOTED] likes this.
  29. Feb 6, 2022 at 10:09 AM
    #269
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Originally yes. I mounted d rings to my bed using the bed bolts near the tailgate. The trouble with that was the tire being in my way when loading anything into the bed. It works well to make the tire easy to access but it got annoying to live with.
    Eventually I put a tire mounting plate towards the cab and use that instead. It still eats space but I can load stuff in the bed without trouble. At some point I will reconfigure my exhaust so that I can put my spare under the bed for daily driving.
  30. Feb 6, 2022 at 10:13 AM
    #270
    daveeasa
    Thanks. I'm hoping I can stuff mine but we'll have to see. I would be 100% OK re-routing the exhaust if it passes smog.
