Engine oil pressure psi
Discussion in '2.5 Gen Tundras (2014-2021)' started by MadMaxCanon, Dec 10, 2021.
  1. Dec 10, 2021 at 9:48 PM
    MadMaxCanon
    MadMaxCanon [OP] New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I haven't been able to find a true answer for this anywhere. What is the typical, warm oil pressure of the 5.7? I'm guessing around 60 psi?
    I will be installing a Masterlube pre oiler soon and I need to know for the calibration to make it go faster.
    Gunship Guy likes this.
  2. Dec 10, 2021 at 10:32 PM
    MadMaxCanon
    Yeah after I get the pre oiler I'm planning on running a real electronic oil pressure guage, possibly also extend the guage for the oiler itself so I know when it's time to recharge.
  3. Dec 11, 2021 at 7:25 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    5.7 warmed up
    Idle 70 kPa (0.7 kgf/cm 2 , 10.1 psi) or more
    2500 rpm 220 kPa (2.2 kgf/cm 2 , 32 psi) or more
    plumber802 likes this.
  4. Dec 11, 2021 at 8:26 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yep. What's often referred to as: a low pressure system.
  5. Dec 11, 2021 at 8:30 AM
    MadMaxCanon
    Awesome good info. Is this info in any Toyota documentation?
  6. Dec 11, 2021 at 8:54 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    What does the pre-oiler do?
  7. Dec 11, 2021 at 9:28 AM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    pumps engine oil pre-start to reduce cold start wear.
  8. Dec 11, 2021 at 10:17 AM
    Gunship Guy
    Gunship Guy New Member
    Rick
    Really interested in this system. Curious about one on the new V6 TT as well. Please share what you learn from the research, install and results.
    My understanding is that once the engine is running it recharges the static pressure in the unit from oil pressure. That it needs charged from an outside source initially. Could have totally missed the boat with that assumption.
  9. Dec 11, 2021 at 5:08 PM
    MadMaxCanon
    That is 100% correct. Actually the better oil you use the more often you need to recalibrate the system since good oil additives take crap out of air. But it should only be once at most between oil changes.
    I am planning on doing a full write up about it when I do it. I ordered it a few days ago. I got the 3 quart system and plan to plug into oil sending unit port.
    Gunship Guy[QUOTED] likes this.
  10. Dec 11, 2021 at 5:59 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Minimum spec is usually pretty low, around 10psi. I like to see 30-40psi at warm idle on a healthy engine.
    Tundratoofun likes this.
  11. Dec 11, 2021 at 6:47 PM
    MadMaxCanon
    I'm going to call it 40. Then add 10 more for speed of system. So I'll set it for 50 psi and see how long it takes. Can always add more later or just wait a few seconds longer. System max is 100 psi.
  12. Dec 11, 2021 at 8:10 PM
    2mchfun
    Good stuff, just talked to Kerry last week at Masterlube myself. Also doing the 3 qt here. I think the best way to determine pressure is with an accurate guage installed. Gonna be $500 very well spent since my truck is not driven very often.
  13. Dec 11, 2021 at 8:20 PM
    2mchfun
    You will know when it is working by watching the guage on the dash. Turn it on and the guage will climb, then fire up the truck. Then shut it off and it will refill to the set pressure.
  14. Dec 11, 2021 at 9:06 PM
    MadMaxCanon
    Yes but guages are awesome and fun and let me see the EXACT number lol
    2mchfun[QUOTED] likes this.
  15. Dec 11, 2021 at 9:07 PM
    MadMaxCanon
    Same. Mine sits a minimum of 3 to 4 days a week, usually in a row.
  16. Dec 12, 2021 at 4:34 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    From TIS
  17. Dec 22, 2021 at 6:48 AM
    Gunship Guy
    Rick
    Apologies up front. Still an old keyed ignition guy.
    How does this setup work with push button start?
    I’m thinking about the 2022 and this approach for the turbos.
    For all who posted pictures, thank you very much!
  18. Dec 22, 2021 at 6:55 AM
    MadMaxCanon
    I am pretty old school myself and did not want the push button start so i still use a key. Ignition does not play a factor at all in this system. The way it works is there is a separate switch for the pre oiler. You put the truck in the on position without cranking, so your gages light up. You flip the switch for the oiler and the pressure of the system squirts the oil in your galleys and you can see your stock oil pressure gage rise. After about 5 seconds, you turn the oiler switch off and crank the truck.
    The only way ignition would play a role, is if you specifically wanted to wire it to your ignition, so it would lag while the system squirts before cranking. I wouldnt do this though since you really dont need to preoil every time you start the truck. For me, this system is good because my truck typically sits for 3-5 days at a time before I drive it and I do go up in the mountains with snow at every opportunity.
    Not sure how it will work for turbos, I imagine pretty much the same way, maybe would need a higher PSI to help push the oil more. I would call Kerry at Masterlube, he is the owner and main developer, dude has an entire solar system of knowledge and experience in this, and he WILL talk your ear off about it, you can tell he is very passionate about his business and since he picked up on the fact that I am an engineer, he dove into about 30 minutes of technical details and ideas.
  19. Dec 22, 2021 at 7:40 AM
    And what do we believe is the benefit of this system? Pumping oil onto the valvetrain accomplishes what? Most startup wear would be vertical surfaces like piston walls which wouldn't be lubricated using the pre-oiler. To me, adding this into the system introduces a possible failure point to what is currently a reliable setup. The previous 4.7 million mile Tundras had little to no wear observed on tear down. What is this fixing?
  20. Dec 22, 2021 at 8:06 AM
    2mchfun
    The million mile truck wasn't parked for days or weeks at a time frequently. Huge difference!
    MadMaxCanon[OP] likes this.
  21. Dec 22, 2021 at 8:14 AM
    Have you ever parked your truck in your garage for days or weeks, while you worked on it? I have. If you take the valve covers off and touch anything in the valvetrain, it's coated in oil. Just not sure what this is solving. My 1st Gen Tundra sits for days at a time, has 270k miles on it, starts right up, runs like a top and doesn't smoke or use oil between changes. Sometimes the theory of something exceeds it's practical use. I get the idea, but is it worth it? And does it introduce a rick of failure that wasn't present before?
  22. Dec 22, 2021 at 8:21 AM
    2mchfun
    With the 5.7, many have timing chain tensioner(s) wear, and that is both expensive and a PITA to deal with. I keep vehicles for 20+ yrs. So, for me the cost is peanuts.
  23. Dec 22, 2021 at 8:29 AM
    MadMaxCanon
    I cant argue that there is a potential failure point introduced, but the risk and severity of the failure is very small. It is only an extra 1.5 quarts of oil and the system itself, through physics, makes it near impossible for there to be and issue. the owner of masterlube said that in 25 years, he has not had a single reported failure. Usually in systems like this, the failure point is the can itself, which would eventually rupture since competitors typically use a fire extinguisher type canister for this setup, whereas Masterlube uses an overkill container that is rated for much more psi than the 100psi limit that is set with the system. It is designed so that the weak point of the system is the valve so if there was a catastrophic issue, it would just blow the valve and mitigate any severe engine damage.
    While you are correct about the vertical wall wear, having oil prefilled through the galleys, reduces the time it takes for coating everything on a dry start, thereby reducing the potential for damage.
    Gunship Guy and KNABORES like this.
  24. Dec 22, 2021 at 8:32 AM
    MadMaxCanon
    I think the missing peice of information on those super high mileage tundras was that they were driven continuously for long periods of time and likely had much less heat cycles than their mileage would suggest, relative to the average user.
  25. Dec 22, 2021 at 8:33 AM
    The vertical surfaces of the cylinder are lubed by crankshaft lobe lash. Only way to lube em is start the motor. Not sure if failure of timing chain tensioner is lube related or not, but that's a decent argument if so.
