Bed Bounce Fix?
Discussion in 'General Tundra Discussion' started by Rica25, Feb 24, 2018.
  1. Jun 21, 2021 at 12:51 AM
    #121
    Lvtrd4x4
    Lvtrd4x4 New Member
    Charles
    09 White DC TRD Offroad
    Road sign skid plate Eibach pro shocks and struts Boxed frame
    Ive lurked high and low for an answer to the bed bounce phenomenon and honestly the best i seem to have found is to put a bed cage in or box the frame. I tried a make shift bed cage and that didnt work but i just finished boxing the back half of my frame. It still is not completely gone in my head but man is it much more tame.
  2. Jun 21, 2021 at 7:36 AM
    #122
    W3agle
    W3agle New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
    “Box the frame” - take the open channel steel frame members and weld a cover plate on? I’ve never heard this term before.
    I am hoping that some added weight on the bed helps my bed bounce. 250lb camper shell + some weight inside eventually for my camping buildout.
  3. Jun 21, 2021 at 10:01 AM
    #123
    Lvtrd4x4
    Lvtrd4x4 New Member
    Charles
    For me it was weird. Weight got rid of one of 2 vibrations for me. It fixed the vibrating/rough feeling from the suspension itself, but the bed still bounced with 500 lbs of concrete and lighter duty springs. The shell itself should act like a stiffer structure for the bed which should help the bounce as well.
    Hbjeff likes this.
  4. Dec 21, 2021 at 6:47 AM
    #124
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I just tried 250lb of sandbags in various configurations in the bed, no difference. I’ll take them back to Lowes and try something else. Was really hoping the $20 I spent on sandbags would help. Oh well.
    Hbjeff and DeesCrewMax like this.
  5. Dec 21, 2021 at 12:23 PM
    #125
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    the 99-04 taco had very weak frame rails as well. Fab places used to sell plates to weld to the sides to stiffen them up. I would bet that would help us as well. Easier than boxing the frame from a labor perspective
  6. Dec 21, 2021 at 5:33 PM
    #126
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Yea boxing the frame looks extremely labor intensive. It's just weird that there nothing consistent across the board that's worked. Some people get shackles and it solves the problem. Some used weight in the bed and were good. Maybe the roads here in CO are extra worse, I don't know. There are some that are almost nauseating to drive on.
  7. Dec 21, 2021 at 5:44 PM
    #127
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    I did not enjoy reading that new 22 owners have found the ride “bouncy” at times. I really hope what they are referring to is NOT what we have experienced. Some stretches of roads are perfectly fine, but then I encounter 80 miles of the perfect harmonic storm and I become reluctant to road trip the Tundra as its a uncomfortable for everyone . If a $65k coil sprung rear tundra still does this that would be disappointing to say the least.
    AggiePhil likes this.
  8. Dec 21, 2021 at 5:57 PM
    #128
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    This looks like and old thread and maybe I didn't read enough. But is anyone actually modifying their truck to deal with highway construction?
    Darkness likes this.
  9. Dec 21, 2021 at 8:14 PM
    #129
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    my guess is that the shocks are too soft and the bouncing is likely just actual suspension travel.
    the bed bounce of the gen 2 is not suspension travel. It is the frame flexing as you drive.
    Shackles do help a lot, but its not perfect. A stiffer frame, better shocks, and shackles would all work together
  10. Dec 22, 2021 at 5:35 AM
    #130
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I guess shackles and shocks are in my future.
  11. Dec 22, 2021 at 5:41 AM
    #131
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    My bed frame is cast iron from the late 1800’s, and i had to weld some steel bracing to protect the corners from vigorous bouncing. Electrical tape helped with the squeaking.
    B.Ross, Sumo91 and Darkness like this.
  12. Dec 22, 2021 at 5:44 AM
    #132
    DeesCrewMax
    Deric
    5160 shocks, topper, 240lb of sand, shackles with poly bushings and it still is awful in mine (on certain road types) if my tire pressure is at 40psi. At 34 psi it’s better, but still terrible.
    For those thinking this is in our heads or is just the bed moving, if you whistle on one of these stretches of hwy and just hold a solid note you sound like someone is smacking you on the back every 1.5 seconds.
    I’ve considered pro suspension or AccuTune’s adventure tune in some fox 2.5 with DSC, but I’m not convinced the design flaw can be fixed so easily.
    Skew12 likes this.
  13. Dec 22, 2021 at 6:28 AM
    #133
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    True Bypass shocks would probably cure 99% of it but now you’re spending a shitload of money. If i ever can stop working so much OT at work im gonna have a fab shop make some frame stiffeners
    Darkness and DeesCrewMax like this.
  14. Dec 22, 2021 at 7:52 AM
    #134
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I just avoid the highway.
    alb1k[QUOTED] likes this.
  15. Dec 22, 2021 at 7:58 AM
    #135
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Anybody try the willy bar? This video is suspect because he installed it in a Dodge and made his wife pretend to be two different models, but maybe it worked?
    AnonVet, DeesCrewMax and alb1k like this.
  16. Dec 22, 2021 at 8:49 AM
    #136
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I don't think so. I think it's a combination of the stiffness of the frame (natural frequency) and wheelbase and spacing of the concrete on the road. Everything is perfect to hit the resonance of the chassis. Tweaking the shocks might help but any energy imparted into the chassis (ie suspension motion) would still cause it to resonate. This explains why there's no real cure, and that stiffening the frame has had (some) success since it changes the frequency enough to move it out of the range that the concrete blocks are spaced.
    Hbjeff[QUOTED], DeesCrewMax and alb1k like this.
  17. Dec 22, 2021 at 5:22 PM
    #137
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I realize I likely won't get rid of the bounce completely. I'd just be happy to find a way to mitigate it some.
  18. Jan 3, 2022 at 7:49 AM
    #138
    mustangr2
    mustangr2 New Member
    I have experienced this. I understand it will never go away but it shouldn't be this bad. I am guessing this is primarily due to the winter hitting but it’s lately it’s pretty awful. I can watch the bed bounce horribly in the side mirror. I dropped the pressure in the tires because I usually run a little extra pressure. That helped slightly. I am going to throw a little weight it and see what happens. I might take it in and see what Toyota says. I don’t recall it being that bad when I was testing driving trucks. Now granted the Utah highways are not the greatest but still it shouldn’t be that bad. I love the truck and but the ride is pretty terrible so far. My only major other dislike with the truck is the stupid Toyota remote start.
  19. Jan 27, 2022 at 6:04 PM
    #139
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Has anyone tried lowering the tire pressure, to a reasonable level, and had luck mitigating the bounce?
  20. Jan 28, 2022 at 6:21 AM
    #140
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Toyota already calls for a really low tire pressure at 33lbs. I would definitely not go lower than that.
  21. Jan 28, 2022 at 9:17 AM
    #141
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Noted, thanks. I think mine are at 35 right now, I’ll have to look. No point in going to 33, won’t make any difference.
    Hbjeff[QUOTED] likes this.
  22. Jan 28, 2022 at 1:21 PM
    #142
    mustangr2
    I lowered my to low 30s and it helped. Also it’s seems to help slightly is the my tonneau cover is covering the bed instead of leaving the bed open.
  23. Feb 2, 2022 at 5:49 PM
    #143
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Ive heard the poly bushings with the shackles help. I do not have them installed but when I road trip with weight in the bed the bounce is minimal. Its funny to watch my G baby in her car seat when I roll on concrete portions of highways locally. The bounce sucks, but its a truck...embrace the suck.
    batman900 likes this.
  24. Feb 2, 2022 at 6:19 PM
    #144
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Hahaha. I hear ya man. This is the first one that has bounced for me as well- I have crewmax. fuck it.
    Terndrerrr likes this.
  25. Feb 2, 2022 at 6:24 PM
    #145
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Coachbuiler shackle helps a ton. E rated tires might make it worse as well, I haven’t noticed it as much going back to p rated.
  26. Feb 2, 2022 at 7:34 PM
    #146
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    i go back and forth. P rated tires handle my trailer just fine, however it was nicer to not need to air the e rated to the max every trip. (Trailer isnt crazy heavy)
    batman900[QUOTED] likes this.
  27. Feb 7, 2022 at 7:27 AM
    #147
    Legbuh
    Legbuh New Member
    2019 Crewmax Limited
    Ya, I experienced this last night on the highway for the first time. Then my flashbacks to my 08 tundra came rushing back. I can't believe the 2019 CM still does it. Cmon, Toyota... And mine even came with TRD pro front suspension and upgraded Fox BDS in the rear.
  28. May 20, 2022 at 8:56 PM
    #148
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Experienced this on the trip back from the cabin tonight. Never had it on the same stretch in my taco and was surprised by it. Hopefully the sos drop kit, sway bars, air bags, and new shocks help. Looking into cb shackles and probably custom leaf pack now
  29. May 21, 2022 at 6:13 AM
    #149
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Only things to fix the bounce for me is higher ambient temperatures or speeds under 65mph.
  30. May 21, 2022 at 7:00 AM
    #150
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I think I posted this before. I had an 15 SR5 Double Cab, and now a 19 Pro Crewmax. The Pro cured 99 percent of the violent bounce I would get on segmented concrete highways. Not sure if it's the cab configuration, the shocks or both, but I barely notice anymore. On the old truck, my wife would have to wear a sports bra on road trips.
