What size lift do I have?
Discussion in 'Suspension' started by Tundra2Yak, Dec 21, 2021.
  1. Dec 21, 2021 at 7:34 PM
    Tundra2Yak
    Tundra2Yak [OP] New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Picked up a new to me Certified 2016 1794 4x4 a couple weeks ago and am curious what size lift it has. My suspension knowledge is nearly zero. Pic of the front shows 5" bracket. Rear has 3" blocks. Components are Pro Comp. Am I correct in assuming this is a 5"/3" or is there more to it than what I measured. Will snap some more pics tomorrow.
    Also trying to resolve a slight shudder I'm feeling at low speed acceleration. From searching on the forum, it sounds like a CB drop may be in order. The truck does not currently have one installed but it is oriented properly with the single hole down.
    Since the powertrain is still under warranty for another 1.5 years or so, should I inquire with the dealership about the shudder or just try out the CB drop kit to see if it resolves the issue?
  2. Dec 21, 2021 at 7:52 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The 5” bracket won’t tell you. The 3” block tells you your rear was lifted 3”, but your leafs could have sagged since the install. For current actual lift, measure from the center of the wheels to the fenders. Someone here will have stock numbers.
    Black Wolf and Tundra2Yak[OP] like this.
  3. Dec 21, 2021 at 8:12 PM
    Tundra2Yak
    2016 1794 4x4 CM
    Thanks @joonbug . Front looks to be around 28.75" and rear 28.25". I did see a thread comparing heights from stock, I'll try to find it again.
    The in-coil spacer is 1.25" thick and the above coil is 4.5" inside flange to inside flange, ~5" outside to outside.
    joonbug likes this.
  4. Dec 21, 2021 at 9:38 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Looks like the 7 inch kit.
    And it looks scary, that's a lot of spacers.
    I would try the carrier bearing drop kit, easy to do. I used an Ironman kit, took about 10 minutes to install.
    Black Wolf, AggiePhil and 1lowlife like this.
  5. Dec 21, 2021 at 9:40 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    wait... they certified that with that lift? thats not a certifiable truck... assuming its Toyota. They cut the frame for those kinds of lifts
  6. Dec 21, 2021 at 9:47 PM
    Tundra2Yak
    2016 1794 4x4 CM
    I thought the same thing when I saw it listed as CPO.
    The lift was the only exception that wasn't covered in the CPO paperwork.
  7. Dec 21, 2021 at 9:50 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    So they certify the truck minus the suspension? WTF?
    Black Wolf, 1lowlife and JLS in WA like this.
  8. Dec 21, 2021 at 9:51 PM
    empty_lord
    05 rollover special
    yea.. i DONT believe thats how it works.. any time we have these things at work they cannot be certified.. because the frame cut is the big problem
    they might be offering some kind of third party certified deal? not sure honestly
    1lowlife, alb1k and JLS in WA like this.
  9. Dec 21, 2021 at 9:58 PM
    empty_lord
    05 rollover special
    oh but to answer the question it looks like your standard 6" procomp lift
    alb1k likes this.
  10. Dec 21, 2021 at 10:26 PM
    Tundra2Yak
    2016 1794 4x4 CM
    Just reviewed the warranty paperwork again. Says it's between me and Southeast Toyota Distributors with Fidelity Warranty Services as the administrator.
    And the exclusions section is pretty extensive, but typical. Has 21 line items of which most exclude damage resulting from accidents or improper use and then line 21 states: "lift kits are excluded."
    Curious to see what they say since "center support bearing" is specifically listed as covered in the drive line section. I doubt installing the drop kit would be covered but I also don't want that to void it's future coverage of it's not already excluded due to the lift.
  11. Dec 21, 2021 at 10:27 PM
    empty_lord
    05 rollover special
    unfortunately with aftermarket lifts it usually nulls the warranty on differentials, CV axles, and drive shafts in my experience working for a dealer. but each warranty company is different
    hell one refused to replace the transmission on a tundra because the larger tires were "the problem" (we all know that isnt the case.. but they make the rules)
  12. Dec 22, 2021 at 1:48 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome....Nice Rig
  13. Dec 22, 2021 at 2:22 AM
    AggiePhil
    College Station, TX
    Damn, those pics made me cringe. :eek2:
    JLS in WA likes this.
  14. Dec 22, 2021 at 3:49 AM
    Tundra2Yak
    2016 1794 4x4 CM
    Yikes, I didn't realize it was that bad. Again, very limited knowledge about suspension mods but I'll learn more. What specifically gives you cause for concern? Reduction in travel given all the spacers?
    Not Planning to throw a bunch of money into upgrades right now but it will be nice to know what I should look into.
  15. Dec 22, 2021 at 4:28 AM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    Is it 2wd? Looks like a lift spindle in the front as well.
  16. Dec 22, 2021 at 4:40 AM
    Tundra2Yak
    2016 1794 4x4 CM
  17. Dec 22, 2021 at 5:59 AM
    The 2 things that I see......I don't know if having an in-coil spacer and a lift spacer above the coil is correct, and those rear blocks highly increase the chances of axle wrap.
  18. Dec 22, 2021 at 6:15 AM
    Tundra2Yak
    2016 1794 4x4 CM
    Thanks @Tundra234 . Does the bottom leaf look stock or aftermarket? I'm assuming a new leaf pack would be the ideal setup in the rear?
  19. Dec 22, 2021 at 6:37 AM
    That is a stock leaf spring. With that much lift, a custom built pack would be the way to go. Alcan springs are pretty popular as they can build them with the lift. Some of the guys use Deaver as well.
  20. Dec 22, 2021 at 6:47 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Seriously, that lift is terrifying, I am just picturing hitting a pothole at highway speed and the truck doing the wave.
    AggiePhil[QUOTED] and JLS in WA like this.
  21. Dec 22, 2021 at 7:04 AM
    Tundra2Yak
    2016 1794 4x4 CM
    It seems like a typical pro comp 6" or 7" lift based on pics I've seen of their kits. Is the combination of in spring and above spring spacers the main concern?
    What components would you target to improve concerns. Sounds like a leaf pack would improve the rear end, what about the front?
  22. Dec 22, 2021 at 7:08 AM
    MadMaxCanon
    Do you want a lift that is that high? If so, I think some other guys can help with advice on a lift that size. If it were me, I would ditch all that and go with a coilover kit or a complete lift kit from old man emu or ironman or something around the 3" lift area.
    AggiePhil likes this.
  23. Dec 22, 2021 at 8:25 AM
    Tundra2Yak
    2016 1794 4x4 CM
    I appreciate the responses so far as it certainly gives me things to look into and points out the limitations of the truck. Keep them coming.
    Is the lift way overkill for my needs? Absolutely
    Would I have installed the same size if I bought the truck new? No, probably closer to 3"
    Alas, it was on it when I bought it and it had the trim level, mileage, and consistent service history I was looking for. Really not looking to dump thousands into making it more functional for offroad but if there are things I should plan for to avoid future damage given my typical driving conditions below, I'm all ears.
    My typical driving conditions are:
    • 99% street in city with little traffic, limited highway
    • No towing
    • ~7k miles per year
    • Daily driver but SUV is the family hauler
    Ted4311 likes this.
  24. Dec 22, 2021 at 8:28 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    This. Eibach is a great option as well.
  25. Dec 22, 2021 at 8:33 AM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Once the sub frame is cut, I don't think you can go back.
    You could get some full length shocks, like the Fox ones from BDS Suspension?
  26. Dec 22, 2021 at 8:41 AM
    MadMaxCanon
    Good point. Shows how much i know about lifts like this.
  27. Dec 22, 2021 at 9:06 AM
    Tundra2Yak
    2016 1794 4x4 CM
    Holy :censored:! Just crawled under the truck and saw the sub frame cut. I still don't know what I'm looking at but it definitely does not look reversible.
    Anyone have pictures of what a normal sub frame cut looks like that I can reference?
  28. Dec 22, 2021 at 9:14 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    A competent welder can weld it back together if you ever need to. But in your case I’d just leave it and enjoy the truck. You’ll be fine.
  29. Dec 22, 2021 at 9:26 AM
    Tundra2Yak
    2016 1794 4x4 CM
    Thanks. It seems to ride fine for what it is other than the slight shudder at takeoff. The original plan was to wait for a 2022 but the pricing is absurd. I'll most likely baby this one for a few years and wait for the dust to settle (and hopefully the prices) on a 3rd gen.
    Rodtheviking likes this.
  30. Dec 22, 2021 at 9:40 AM
    Tundra2Yak
    2016 1794 4x4 CM
    @empty_lord you were right. Sub frame is definitely cut. No idea how they certified it although there is a standard exclusion for mods not performed by a manufacturer authorized installer that meet mfr specs so that gives an out for them.
    Will report back with what I learn after first trip to the dealer.
