North West BS Thread
Discussion in 'North West U.S.' started by JAMMDOGG, Jan 6, 2014.
  1. Dec 21, 2021 at 2:11 PM
    #6151
    Blue Thunder
    Washington
    Trip was great. Snoqualmie Pass was covered, but got thru without any drama. Has to shorten/adjust my trip a bit due to weather but it was a nice 9hr drive.
    Somewhere in the Hanford DMZ headed North to Moses Lake
    2FA3B2A8-DF84-43EA-B4C3-1C9B89C50BD2.jpg B093FC2F-1C09-48FA-A70C-75D664FCB4DE.jpg
  2. Dec 21, 2021 at 2:15 PM
    #6152
    Blue Thunder
    Washington
    I’m just going to keep posting to get caught up on a few things…
    @NWPirate I checked my oil fill cap. All looks good. No build-up or milk. Here’s a chitty pick of the dip stick and a wipe from under the cap. Color is about that I’d expect for 3k miles on the oil
    I’m guess some moisture collected in the catch can and discolored the collection. Still need to check the return hose to make sure it is tight. Thoughts?
    jewsNbrews, NWPirate and Kratos like this.
  3. Dec 21, 2021 at 2:17 PM
    #6153
    Blue Thunder
    Washington
    Since we talk trash about Les Schwab, I think it is only fair to post a recent experience.
    I needed chains for my Corolla. Discount Tire doesn’t carry chains anymore. You can order them online and they will ship from MI. Phuk that. Les Schwab had 13 in stock! Pretty nice give the time of year.
    Hat tip to LS
    jewsNbrews, NWPirate, gosolo and 3 others like this.
  4. Dec 21, 2021 at 2:29 PM
    #6154
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    And they will refund you if the chains go unused. Might be doing that if I end up changing my tire size next spring.
  5. Dec 21, 2021 at 3:31 PM
    #6155
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Used to do that with my chains for my 35’s…till I had to use them for a stupid situation. Probably my favorite part about LS.
    NWPirate and Blue Thunder like this.
  6. Dec 21, 2021 at 3:35 PM
    #6156
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    Here in Wenatchee les schwab has a pretty good reputation. I wouldn’t go to discount tire here if they gave me the tires for free.
  7. Dec 21, 2021 at 3:47 PM
    #6157
    Gumbeaux
    Gumbeaux The new guy
    Chip
    Southern Washington
    Black 2010 Tundra Limited Crewmax TRD
    4 inch lift 20" Moto Metal Wheels 33x12.5x20 Duratracs Hooke Road Front Bumper with Bull Bar and LED Lights Smittybilt GEN 2 XRC 9500 Winch Black Fender Flares LED Headlights With Black Housing LED Taillights With Black Housing Pioneer DMH-WT8600NEX Digital Multimedia Receiver Boyo Front Camera Mounted In The Grill Toyota Logo K&N Cold Air Intake Tiger Tonneau Cover
    I wanted to get chains from LS, but they didn't have any for 35's - none of the local shops had them that big. I had to order them online :frusty:
    EDIT: 33's, not 35's
    jewsNbrews and Blue Thunder like this.
  8. Dec 21, 2021 at 3:53 PM
    #6158
    Juanjoolio007
    Oregon
    That sucks. Mine stocked them. They were pretty spendy. Probably $100 bucks like 4 years ago. Now they are probably pushing $500-600 due to…well you know.
    jewsNbrews, gosolo and Blue Thunder like this.
  9. Dec 21, 2021 at 4:02 PM
    #6159
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yeah - I do still end up getting chains there for most of our rigs
  10. Dec 21, 2021 at 4:05 PM
    #6160
    Gumbeaux
    Chip
    Southern Washington
    Wow! I won't complain about ordering online, then. I ordered them direct from Security Chain Company, and only spent $180 bucks - and they fit both my Tundra (33's) and Jeep (35's)
  11. Dec 21, 2021 at 4:09 PM
    #6161
    Gumbeaux
    Chip
    Southern Washington
    Speaking of chains - which tires should I use them on? The front?
    jewsNbrews and gosolo like this.
  12. Dec 21, 2021 at 4:13 PM
    #6162
    RainMan_PNW
    Casey
    Clark County, WA
    Rear. Those are your primary drive wheels. If you’re running in 4wd, you could conceivably run a set front and back, but normally just the rear
  13. Dec 21, 2021 at 4:15 PM
    #6163
    Gumbeaux
    Chip
    Southern Washington
    Awesome; thanks! Glad I asked. I assumed the front because of steering, but the rear makes sense because of traction.
  14. Dec 21, 2021 at 4:19 PM
    #6164
    RainMan_PNW
    Casey
    Clark County, WA
    You’ve got more weight up front, which aids with traction for steering. The chains on the rears will give you traction to get moving.
    And know that 4WD won’t help you STOP. That’s usually most people’s first mistake
  15. Dec 21, 2021 at 4:24 PM
    #6165
    Gumbeaux
    Chip
    Southern Washington
    Yes, I learned that a long time ago. Also learned 4WD doesn't help with ice!!
  16. Dec 21, 2021 at 5:52 PM
    #6166
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I have sets for front and rear. If you do plan to run chains on the front, make sure you have tried them in your garage. Mount them and spin the wheels to make sure they do not hit the upper control arm
  17. Dec 21, 2021 at 5:56 PM
    #6167
    Gumbeaux
    Chip
    Southern Washington
    Thanks for the advice, but after @RainMan_PNW comments, I'll just run them on the rear tires.
  18. Dec 21, 2021 at 6:10 PM
    #6168
    NWPirate
    Zach
    WA
    Glad you had fun, I love a good road trip.
    Would be worth checking hoses for tight but I'm betting it's just motor condensation from short trips. No biggie :thumbsup:
    gosolo and Blue Thunder[QUOTED] like this.
  19. Dec 21, 2021 at 6:13 PM
    #6169
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Depending on the conditions, the rear wheels pushing you may only be “just so useful” if your front wheels are just sliding. Does that make sense?
  20. Dec 21, 2021 at 6:46 PM
    #6170
    Juanjoolio007
    Oregon
    And this is why I had to use my chains for like twenty feet. Ice coupled with me trying to be a nice guy and help some young stuck people up on Timberline road caused me to get stuck on ice up hill before the 4wd engaged.
    Which brings me to my next point. Cheapo traction boards off Amazon may just be a better first line of defense instead of throwing chains somewhere you don’t want to.
  21. Dec 21, 2021 at 7:18 PM
    #6171
    NWPirate
    Zach
    WA
    Need to throw my IM traction boards in the truck :thumbsup:
  22. Dec 21, 2021 at 8:13 PM
    #6172
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    Hey Oregonians, is anybody familiar with Sunset Bay State Park? Gonna check it out next week. I can't wait.
    gosolo, Gumbeaux and jewsNbrews like this.
  23. Dec 21, 2021 at 8:32 PM
    #6173
    Dsptundra
    Austin TX Area
    Yep. My sister lives in that part of the state. Sunset Bay, Shore Acres, and Cape Arago are all next to each other down there. Very cool area to explore and visit.
  24. Dec 22, 2021 at 7:26 AM
    #6174
    Gumbeaux
    Chip
    Southern Washington
    oh yeah; that makes perfect sense! Thanks! :fistbump: So depending on conditions, I may need to get a set for the front too. Now I understand.
    This cold I caught has me a bit foggy. Brain is running a little slower than normal - which means it went from turtle speed to snail speed :rofl:
  25. Dec 22, 2021 at 6:27 PM
    #6175
    Juanjoolio007
    Oregon
    I’m taking my wife’s out of the garage and putting them in her 4Runner. I keep my set in my Tundra year round. The next week plus is about to get sketchy. I’m not panick buying but getting prepared. Told my wife to fill up today. Get the essentials at the grocery store and should be ok.
  26. Dec 22, 2021 at 6:34 PM
    #6176
    Dsptundra
    Austin TX Area
    Yep, need to throw my traction boards in and fill up with gas in the morning. I expect the stores will be crazy tomorrow with the holiday and panic buying.
  27. Dec 22, 2021 at 6:35 PM
    #6177
    Gumbeaux
    Chip
    Southern Washington
    I'm hoping it doesn't get too crazy because I'm driving out to the peninsula tomorrow and coming back Saturday.
    Blue Thunder, gosolo and NWPirate like this.
  28. Dec 22, 2021 at 6:45 PM
    #6178
    Juanjoolio007
    Oregon
    I can only assume you are correct. I stopped by my local Costco to fill up. It took longer to get out of the gas station then it did to wait in line to fill up. I had 6 miles to empty. I like to live dangerously lol(yes I know about the magical remaining gas keeping MR Pump under fuel).
    You should be good. The potential starts Saturday and goes from there. Luckily I took Sunday off weeks ago. Unfortunately I may end up spending way longer at work then I should if this happens.
    Edit: for the Portland area. Not sure about up there.
    Gumbeaux[QUOTED], NWPirate and gosolo like this.
  29. Dec 22, 2021 at 6:54 PM
    #6179
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    We might run into town for some garlic and eggnog. Other than that we’re good for weeks!
  30. Dec 22, 2021 at 6:55 PM
    #6180
    Dsptundra
    Austin TX Area
    Adding eggnog to the list! Thanks for the reminder @gosolo! Love that stuff.
