Official 2022 Tundra 3rd Gen Thread
Discussion in '3rd Gen Tundras (2022+)' started by ColoradoTJ, Oct 13, 2021.
  1. Dec 21, 2021 at 1:17 PM
    #2671
    Hextorm
    Hextorm New Member
    Blake
    White 2022 Tundra TRD Sport CrewMax
    My sheet says 18R265 for tire size, also have a Sport. I think that is for a base SR5 though and is incorrect.
    Boerseun likes this.
  2. Dec 21, 2021 at 1:20 PM
    #2672
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Congrats I guess. I wouldn't expect much hate, I think the majority of this forum has blocked you at this point.
  3. Dec 21, 2021 at 1:24 PM
    #2673
    Dav123
    Dav123 New Member
    Is there anything under there to wrap a strap or winch cable to pull out without damaging something. I don’t get stuck very often but it does happen when your at the hunting club or fishing spots. How is someone supposed to get pulled out if the get stuck if the rear is not an option. Kind of ridiculous. I think every truck for the last 20-30 yes has had tow hooks. I know most folks that never leave the pavement will say the hooks are no big deal, but if you get stuck out in the middle of nowhere, you need some way of pulling out without ripping the front end apart. I can count on 1 hand how many times I’ve used my tow hooks in the last 10ys, so it’s not often, but I like to know I have them if I need them. Just like I haven’t had a flat in those 10yrs either but it’s still good to know I have a spare just in case.
    jpod and Acedude like this.
  4. Dec 21, 2021 at 1:36 PM
    #2674
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I haven't heard that any 2022 trims will have anything other than 32s but I haven't investigated fully.
  5. Dec 21, 2021 at 1:51 PM
    #2675
    OnThaLake
    OnThaLake New Member
    The problem with front recovery is the Tundra has a lot of plastic hanging down low, even lower than the skid plate.
    So, even if you could tie off to a bracket or control arm behind the bumper, the moment the recovery strap is pull taught, which will cause it to be horizontal or slope upwards away from the Tundra, the strap will begin displacing the lower plastics of the front bumper.
    Tundra'25, Acedude and Toyota1234 like this.
  6. Dec 21, 2021 at 2:10 PM
    #2676
    Dav123
    Dav123 New Member
    At first I thought I could live without them but the more I think about it, it’s a pretty big deal. I mean we’ve all been there. Going across what looked like damp dirt, only to sink down and start spinning. Before, someone could just hook up and pull you out, and 5 min later, your on your way. With this truck, you could do serious damage. Now I’m second guessing getting the tundra because a simple thing like tow hooks.
  7. Dec 21, 2021 at 2:10 PM
    #2677
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    thanks for posting this. have not been able to find any good pics of silver. secured a platinum last night in silver so i'm psyched.
  8. Dec 21, 2021 at 2:16 PM
    #2678
    OnThaLake
    It's interesting, Toyota added availability of rear locker. Which, to be honest, makes it more likely (for me) to get into trouble. I'd definitely push my luck with rear locker.
    Even if someone were to make peace with attaching a tow strap under the bumper, it's quite common to get the truck into such a situation that attaching a recovery strap to something behind and below the bumper would be impossible. So, I don't get it.
    Acedude and 1UP like this.
  9. Dec 21, 2021 at 2:23 PM
    #2679
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    32.6” is stock tire size, 265/60r20,
    I feel if I’m ever stuck so bad I need pulled out I will sacrifice “hopefully only the bumper” and replace it with a after market bumper assuming that can even be done…
    but what if you break a cv axel or something that leaves you on the side of the rode. Is there a way to safely pull the truck onto a flatbed tow?
  10. Dec 21, 2021 at 2:26 PM
    #2680
    Totherion
    Totherion New Member
  11. Dec 21, 2021 at 3:19 PM
    #2681
    ColumbiaGorge
    ColumbiaGorge New Member
    Joe
    Columbia Gorge
    24 Limited
    Thank you! I don’t like that the sport is slightly lowered in the front. May get spacers and go just a bit higher in the front with bigger tires. I wish the off-roads didn’t come with the chrome mustache only in SR5s which is why I went with a sport.
    OnThaLake likes this.
  12. Dec 21, 2021 at 3:30 PM
    #2682
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    The more videos I've seen of the under carriage, the more I think the tow hooks will need to stick out of the bumper. May even end up being a removable screw in recovery hook like is found on a lot of suvs and even cars.
  13. Dec 21, 2021 at 3:55 PM
    #2683
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Lack of tow hooks is mind-boggling stupid. They crow about MTS, Crawl Control, rear locker, Fox shocks, yet no front tow hooks. F'n stupid.
    jpod, RavingOx, OnThaLake and 3 others like this.
  14. Dec 21, 2021 at 4:00 PM
    #2684
    Totherion
    I have to admit I am very defensive of my next pickup truck and boy does that 'Yota Kool-Aid tastes good.
    But no tow hooks is driving me nuts. I really hope Toyota comes up with an accessory soon.
    Was wondering if I bolt a tow ring on somewhere under the skid plate. One will do
  15. Dec 21, 2021 at 4:22 PM
    #2685
    Toyota1234
    Jack
    Sure but again plan on ripping off your bumper if you use it. Let’s just hope there some good front bumper after market options. I haven't heard any fabricators chiming in on a positive solution.
    Totherion[QUOTED] and OnThaLake like this.
  16. Dec 21, 2021 at 4:32 PM
    #2686
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    The big 3 all have tow hooks because they need them to get pulled onto the tow truck!
    If you want em? Sweers said they would be an option. I can’t remember which video? Someone will find it?
  17. Dec 21, 2021 at 4:35 PM
    #2687
    bsktball55
    Missouri
    16 Tundra TRD Pro
    I think it was one of the original interviews that Andre from tfl interviewed him during the release. Haven't heard anything about them since though and they are not an option yet.
  18. Dec 21, 2021 at 4:52 PM
    #2688
    Totherion
    If I get stranded in a blizzard and it's -50F, I will not care if I lose the bumper :D
    We'll see what Toyota comes up with.
  19. Dec 21, 2021 at 5:36 PM
    #2689
    Dav123
    Dav123 New Member
    He probably said that on the fly thinking no big deal, then he got back to the office and they said, “you shouldn’t have said that, we’ve been up all night looking at this thing up and down and there’s just no way without redesigning the whole front end.” Lol
    Acedude, Cpl_Punishment and OnThaLake like this.
  20. Dec 21, 2021 at 5:39 PM
    #2690
    Dav123
    Dav123 New Member
    That’s a good question, if one of these trucks ever needs to get towed for whatever reason, how will they hook and drag it onto the flatbed without ripping the bumper off?
    Toyota1234[QUOTED] likes this.
  21. Dec 21, 2021 at 5:41 PM
    #2691
    OnThaLake
    There's no problem towing a new Tundra when it's on a/side of the road. Recovery/tow companies can retrieve the truck, and anyways if the truck had recovery hooks, tow companies rarely utilize them, they generally go for the frame or lower control arms.
    Recovery hooks are a convenience for someone if they get stuck off-road.
    They need to be durable enough to survive use by amateurs without any damage to the truck. On most trucks the recovery hooks are very solidly mounted.
    I think Toyota had a priority with the new Tundra to meet various current and future crash regulations, therefore there's a foot of soft plastic and deformable aluminum directly behind the front of the truck. We can't attach recovery hooks to any of that, you could deform the soft crash structure.
    Obviously, someone's going to make tough bumpers that will require losing the soft plastic and aluminum crash structure, and bolts directly to the frame. Then you'll have tow hooks. And the truck will perform differently in some crashes, but fortunately we don't need to maintain original crash performance when modding.
  22. Dec 21, 2021 at 6:29 PM
    #2692
    OppoMojo
    OppoMojo New Member
    Congrats! Hope you like it…..what color?
  23. Dec 21, 2021 at 7:00 PM
    #2693
    1UP
    1UP Truck Gang
    He told TFL during the 30 min 1 on 1 I believe.
  24. Dec 21, 2021 at 7:10 PM
    #2694
    1UP
    1UP Truck Gang
    Yeah aftermarket will fix this. But... it's a shame that for cost of these itrucks the solution for something so basic will be to spend a considerable amount MORE and cut up their truck. All for a basic run of the mill blue collar standard truck feature.
    I use mine all the time in heavy snow.
    OnThaLake[QUOTED] likes this.
  25. Dec 21, 2021 at 7:20 PM
    #2695
    Breathing Borla
    Northern Illinois
    the whole big three needs tow hooks and Toyota doesn’t , really doesn’t taste to well.
    It’s a half ton pick up truck , tow hooks need to at least be an option. Right now they aren’t , I think they were full of bs when they said it would be an option.
    let’s see what happens but it doesn’t look well
    Doofus, 1UP, OnThaLake and 1 other person like this.
  26. Dec 21, 2021 at 7:26 PM
    #2696
    18" TRD Off Road Wheels
    Congrats on the truck. I'm excited for everybody getting the new trucks on the forum. Can't wait to see how all the owners deck them out, modify them, and to get some real world experience and pics of them.
  27. Dec 21, 2021 at 7:33 PM
    #2697
    Dav123
    Dav123 New Member
    I’d be willing to bet that they never thought about the tow hooks or were planning on doing that towards the end since it’s such a basic item, then after they finished the front design, they realized it couldn’t easily be done without Going back to the drawing board, so they went with the mpg line.
  28. Dec 21, 2021 at 7:45 PM
    #2698
    Xspurt
    Xspurt New Member
    How is it Toyota has the worst designers and engineers but has the track record for reliablilty that they have?
  29. Dec 21, 2021 at 7:46 PM
    #2699
    Because the first portion of your statement is based on your opinions and the latter portion is based on verifiable data?
  30. Dec 21, 2021 at 7:50 PM
    #2700
    Xspurt
    Xspurt New Member
    LOL, no there is bravery for admitting what many here refuse to recognize and a whole lot of fact too!! They do some of the dumbest things like the remote $tart or the remote $tart that shuts off when you open the door or the no auto 4wd and of course the subject of this conversation - tow hooks ... but sure, opinion ... let's go with that !!! :rofl::rofl:
    Doofus likes this.
