2015 Tundra Entune no operation
Discussion in 'Audio & Video' started by paleot11, Dec 20, 2021.
  1. Dec 20, 2021 at 1:09 PM
    paleot11
    paleot11 [OP] New Member
    Tony
    2015 Toyota tundra 1794
    none
    My entune system went from back up camera staying on to no operation at all. checked fuse and no problem there now it will not power up at all.Does any body have a solution to this problem?
  2. Dec 21, 2021 at 10:03 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Double check all related fuses, both under dash and under the hood. If that checks out, i would disconnect battery for 20 minutes, hook everything back up and start the truck. If the HU is still dead, it is probably toast. Only other thing I can think of is the wiring came disconnected somehow, or wires chewed by a rodent.
