Lift height help
Discussion in 'Suspension' started by mcclain61, Dec 20, 2021.
  1. Dec 20, 2021 at 7:22 PM
    mcclain61
    mcclain61 [OP] New Member
    2007 tundra sr5
    Just bought this 07 tundra as a company truck. It’s not stock height but I don’t know how much lift it has. Looks like
  2. Dec 20, 2021 at 7:33 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    1 1/2" spacers it looks like. 3" at the wheel?
  3. Dec 20, 2021 at 7:36 PM
    mcclain61
    2007 tundra sr5
    Ok wasn’t sure if the 2plates on top of the spacer were factory or not they are 1/4” each.
    thanks for the reply I appreciate it
  4. Dec 20, 2021 at 7:49 PM
    alb1k
    Left Coast
    It's good
    I don't think Gen 2 had spacers up there. But the spacer would be the two 1/4" plates with the inch or so high round tube between them. All the paint is the same. Dealer install?
  5. Dec 21, 2021 at 7:52 AM
    mcclain61
    2007 tundra sr5
    I think it was a dealer install
  6. Feb 17, 2022 at 12:20 PM
    mcclain61
    2007 tundra sr5
    Just so I don’t start a new thread I know 33s will fit any recommendations? Or other tire sizes recommended? I don’t off-road a ton mainly mountain trails maybe some farm land
  7. Feb 17, 2022 at 12:30 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    if its a 3" 35s should fit in most configurations if you don't mind trimming some bumper or if you have a after market bumper, but if you go to aggressive you'll need to do a BMC.
  8. Feb 17, 2022 at 12:31 PM
    NueveTundra
    Planet Earth
  9. Feb 17, 2022 at 12:32 PM
    mcclain61
    2007 tundra sr5
    Thanks I have stock bumper for now plan on changing it for a winch bumper later this summer
  10. Feb 17, 2022 at 1:56 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    curious if your truck has a differential drop since that lift is around 3 inches. want to know if a dealer thinks diff drop is necessary.
  11. Feb 17, 2022 at 2:02 PM
    mcclain61
    2007 tundra sr5
    Doesn’t look like it all stock except the lift
    MadMaxCanon likes this.
  12. Feb 17, 2022 at 4:32 PM
    poop_bubbles
    poop_bubbles New Member
    Those are stacked spacers. Looks like 2x ¼" and 1 big 1-½".
    I wouldn't trust the judgment of anyone that stacked spacers to create a "lift" so take anything else you find with a grain of salt.
    First thing I would do is get a real lift and toss those spacers in the trash. All they are doing is reducing your suspension travel.
