2015 Tundra, What to Expect 110K+ miles
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraTruck15, Dec 18, 2021.
  1. Dec 18, 2021 at 3:26 PM
    TundraTruck15
    TundraTruck15 [OP] New Member
    2015 Limited 4x4 Crew Max Silver
    OEM Towing Mirrors, TOYTEC Boss Coilovers, 2.5" lift up front and 1" block in the back. Ranch hand grill guard and a B&W Turnover Ball / Hitch
    Any of you guys with over 100K miles have insight as what could I expect to have to replace / repair as this truck gets older? I have never enjoyed a vehicle as much as I do this one and planned on driving until 200K miles, but the last three months I have:
    -replaced lower control arm
    -replaced windshield wiper fluid reservoir
    -replaced sunroof (stuck open)
    -horn component replaced
    -head light assembly replaced
    Should I be concerned that this is a sign of things to come or are these type of issues normal under wear and tear? Have you guys had other issues similar to above? Thanks in advance, first time post.
    Metro14536 and Mr Badwrench like this.
  2. Dec 18, 2021 at 3:53 PM
    NWPirate
    Zach
    WA
    Welcome!
    All depends on how hard someone runs their truck.
    I wouldn't say those are normal items to replace on a '15 with 100k miles.
    Did you just get the truck?
  3. Dec 18, 2021 at 3:53 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Probably nothing, atleast for another 100k
  4. Dec 18, 2021 at 3:58 PM
    TundraTruck15
    Thank you for your response! I run it pretty hard, towing and off road driving. But outside of the lower control arm those other items don't seem to be due to running the truck any certain way. I bought the truck in 2016 with 20K miles on it, so I am responsible for any of that wear and tear. Not sure if this helps....
    blackdemon_tt and NWPirate like this.
  5. Dec 18, 2021 at 4:40 PM
    blackdemon_tt
    I run mine pretty hard as well, but I have a 2nd gen... Don't off road, but besides maintenance items, starter at 209k, and soon front caliper at 250k and water pump, since it is leaking now.
    TundraTruck15[OP] likes this.
  6. Dec 18, 2021 at 4:49 PM
    Mr Badwrench
    Mr Badwrench New Member
    What part of the country are you in? We had a 4X4 rock warrior, 2014 at work that was pretty much neglected and it got 230,000 miles when it went back to the fleet owner to be auctioned, and it still ran great. It went through several Wyoming winters with no issues, and no preventative maintenance.
    I am almost wondering if these trucks go bad from babying them lol.
  7. Dec 18, 2021 at 5:00 PM
    TundraTruck15
  8. Dec 18, 2021 at 5:01 PM
    TundraTruck15
    I tow a lot and when I’m off road it’s usually in NW Texas / West Texas area.
    wexttxco likes this.
  9. Dec 18, 2021 at 6:04 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Ever out to far west texas?
    Actual west TX, as in west of the Pecos.
    Mr Badwrench likes this.
  10. Dec 18, 2021 at 6:15 PM
    Wahayes
    Will
    2017 tundra limited
    Having lived in west Texas, offroading there amounts to not much more than dirt road driving, so it shouldn't be hard on the truck at all. I feel I push my tundra pretty hard offroad and the only issue I've had was a failed blower motor on the climate system, it was covered under my ext warranty though. I have 72k miles , I tow l classic trucks with it and offroad in the mountains of Utah for reference. I think you should be solid
  11. Dec 18, 2021 at 6:21 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    I have a 2017 Limited with 62K on the clock. I tow fairly regularly but I don’t beat on it. Only reason I’m responding is to tell you my plan for long term / high mileage ownership. So far:
    1. Battery crapped out one really cold morning last winter. Put a new one in myself for $150.
    2. Replaced the rotors and pads at all 4 corners with HD premium stuff from NAPA at 56K miles. The OEM front rotors had a little warp and I didn’t want to waste my time pulling them and turning them. The pads were still fine. The rear rotors were fine. They had a bit of rust but honestly didn’t need to be replaced, I just did all 4 corners at once since I had my tools out. Calipers were fine, lubed them up and no issues. I have a connection at NAPA and was able to get all 4 rotors and the premium pads all around for $160 total ($40/corner). These ought to last 100K, they’re much better quality than OEM.
    3. I changed out the F and R Diff fluid and the transfer case with the “proper” fluid. Planning on doing the transmission fluid and coolant this summer as I approach 75K. Will replace the serpentine belt at that time too.
    4. Original tires lasted me about 23K miles. Put on a nice sent of Michelins that will need to be replaced before next winter.
    I’m planning to repeat this routine until about 250K miles before I even start to worry about unscheduled repairs. I’ll keep my eye on the hoses, it other than that, Im not a bit worried. Now maybe I’m overly optimistic, but these Tundras just seem to have the bugs worked out and they keep on running. I couldn’t be happier with mine.
  12. Dec 18, 2021 at 6:24 PM
    Wahayes
    Will
    2017 tundra limited
    I forgot to mention the brakes seem to be a full replacement at around 35k on these trucks. At 72 k I've out two sets of rotors and pads. This time I replaced with drilled and slotted rotors , But again I tow and live in the mountains so brakes are used alot. Even still, I would consider this a maintenance item.
  13. Dec 18, 2021 at 6:52 PM
    TundraTruck15
    Been out there plenty but these days mainly around The Rolling Plains Counties.
  14. Dec 18, 2021 at 6:59 PM
    TundraTruck15
    Thanks a ton for all of the information, based on input from you guys I am going to chalk up these recent issues to standard 100K mile replacements.
  15. Dec 18, 2021 at 7:05 PM
    TundraTruck15
    Thank you!
    Wahayes[QUOTED] likes this.
  16. Dec 18, 2021 at 7:11 PM
    TundraTruck15
    Great information and feed back, thanks a ton. Unless something crazy happens this one will get to 200K miles, at least.
    WNY PAT[QUOTED] likes this.
  17. Dec 18, 2021 at 7:29 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Copy that bud!
  18. Dec 18, 2021 at 7:58 PM
    Wahayes
    Will
    2017 tundra limited
    Also just realized you're new, welcome to the forum. Lots of knowledge and information to be had here. It's pretty active
  19. Dec 19, 2021 at 9:21 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    My truck has 231k. I just replaced the LCA bushings with poly bushings, and replaced the lower ball joints as well. What's crazy, is that none of it had any significant amount of wear. Strange your LCA needed replacing. As far stuff that needed to be replaced due to wear my list is as follows
    Water pump was weeping- 173k
    Carrier bearing chirping- 220k, replaced 231k
    Blower motor went out- 200k ?
    Leaf springs worn and replaced- 231k
    Fuel pump replaced with URD kit-197k
    Things I've done for preventive maintenance because I like to tinker and work on my truck
    Ujoints, during carrier bearing swap- 231k
    Rebuilt brake calipers due to torn boot- 226k
    Probably more I'll add to the list as I think of it
    Landodnal, WNY PAT and Barrett50 like this.
  20. Dec 19, 2021 at 5:43 PM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    I've got 60K just swapped out the tires and did a brake pad check. Will be good till summer time and will clean and lube the calipers and new pads. Rotors look fine. I also plan to change the diff and trans case oil, debating the transmission. Seem to remember a specific routine to do that. On other vehicles, I would disconnect the lines at the cooler, immerse the suction line in a 5 gallon bucket of fresh fluid and run the output to an empty 5 gallon bucket, start the car and let it idle till the fresh fluid came out, button everything up, run trans trough all the gears then check level, but not sure on this beast.
    I have towed a couple times, but not too often, but will be towing a 7K trailer soon, so want to be ready.
