2017 SR5 crewmax tpms bypass
Discussion in 'Wheels & Tires' started by derkdontcare, Dec 19, 2021.
  1. Dec 19, 2021 at 3:16 PM
    derkdontcare
    derkdontcare [OP] New Member
    I've found other threads on the subject but when I locate the harness to the tpms module, I'm seeing different wiring. Other threads talking about which yellow wire are you using and I only have 1 yellow wire. Has anyone figured this out?
  2. Dec 20, 2021 at 8:35 AM
    mossmanfj40
    mossmanfj40 New Member
    Craig
    Pittsburgh, PA
    2014 Tundra CM 1794 version
    Toytec/Eibach 3/1, Vector 5 wheels with 295/70/17 Coopers
    I've done this to my 2014............it is the light green wire and the yellow wire next to it. Pin 5 and 6 I believe.
  3. Dec 21, 2021 at 7:01 PM
    derkdontcare
    Do you have a picture of your harness?
  4. Dec 22, 2021 at 7:03 AM
    mossmanfj40
    Craig
    Pittsburgh, PA
    Did not take a picture of the harness. Sorry.
