Freedom Off-road UCA bent my spindles?
Discussion in '1st Gen Tundras (2000-2006)' started by Barblagon, Dec 18, 2021.
  1. Dec 19, 2021 at 5:28 AM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    My freedoms, (while not uninall) have the same gap. Mine were a snug fit to the bushing. I’m leaning towards either over torque of the long bolt, or they used a little to much heat to remove the old ball joint.
    chrisb and Sirfive like this.
  2. Dec 19, 2021 at 5:41 AM
    OP still a no show since opening post.....
  3. Dec 19, 2021 at 9:01 AM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    That truck has seen some air time.
  4. Dec 19, 2021 at 11:59 AM
    Is there a limit to the angle the upper ball joint can move that might cause that? Kinda like trying to compress a turkey wishbone but instead of breaking, it bends?
    Darkness and FrenchToasty like this.
  5. Dec 19, 2021 at 12:12 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    A hard landing at a hard stop for a uca would twist the skinny bit, and wouldnt do ?both?, folding so the spindle moved up and in? Thats a square looking bend. Im also thinking too much heat.
    Jack McCarthy likes this.
  6. Dec 19, 2021 at 12:48 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Plot twist: OP works for spc :rofl:
  7. Dec 19, 2021 at 1:06 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Really?
    Darkness[QUOTED] likes this.
  8. Dec 19, 2021 at 1:33 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    ftfy.
    FirstGenVol and Darkness[QUOTED] like this.
  9. Dec 19, 2021 at 1:35 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    When the knuckles bend, that’s not normally how they bend. Bent knuckles look like you have massive Camber.
    The knuckles are cast steel I believe and I could see them being over heated with a torch trying to remove the old ball joints, and possible weakening the steel.
  10. Dec 19, 2021 at 1:50 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    No, but it would be pretty funny if he did
    alb1k likes this.
  11. Dec 19, 2021 at 2:33 PM
    JLS in WA
  12. Dec 19, 2021 at 7:37 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Bump to remind us this will be the least satisfying thread ever.
    chrisb, Jasont, bmf4069 and 1 other person like this.
  13. Dec 20, 2021 at 10:45 AM
    My vote is for jumped with no bumpstops.
    TRDGen, chrisb, joonbug and 4 others like this.
  14. Dec 20, 2021 at 10:58 AM
    My guess is OP is too embarrassed to admit he doesn't have said bump stops. Hence, the ghosting. :rofl:
    TRDGen, chrisb, bmf4069 and 1 other person like this.
  15. Dec 20, 2021 at 11:05 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    In this picture the arm is clearly contacting the shock tower. If it's the same case with OPs arm then that would stop the arm moving up and effectively turn it into a bump stop creating a compression force on the spindle and bending the top.
    None of OPs photos look like there'd be a contact issue, but interesting that this photo clearly shows that. Add tolerancing or improper installation or other things and that arm might be slapping the shit out of the shock tower.
    Darkness, Rodtheviking and Sirfive like this.
  16. Dec 21, 2021 at 1:43 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  17. Dec 21, 2021 at 8:54 PM
    alb1k
    Left Coast
    It's good
    This was not a jump or a one off. It was a problem at install. Look at the rust pattern.
  18. Dec 21, 2021 at 9:05 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  19. Dec 21, 2021 at 9:09 PM
    alb1k
    Left Coast
    It's good
    Do you think the person capturing the video was initially thinking, wow he's so smart? Or, this looks bad? :laughing:
    JLS in WA and Darkness[QUOTED] like this.
  20. Dec 21, 2021 at 9:10 PM
    #50
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    They probably thought it was brilliant... until...
    JLS in WA and alb1k[QUOTED] like this.
  21. Dec 21, 2021 at 9:49 PM
    #51
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  22. Dec 22, 2021 at 5:32 PM
    #52
    shifty` Animals and insects don't do drugs
    People too often underestimate the weight of loads ...
  23. Dec 22, 2021 at 7:16 PM
    #53
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Darkness and dinosaur like this.
  24. Dec 22, 2021 at 11:41 PM
    #54
    Aerindel
    Aerindel New Member
    Montana
    At least he put down a pallet before dropping a two ton boulder in the back of the truck.
  25. Dec 23, 2021 at 12:17 AM
    #55
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    What coilovers are you using and do you have extended bumpstops? I doubt the UCAs are to blame...
