Power loss on 35s?
Discussion in '3rd Gen Tundras (2022+)' started by cementsharktrd, Dec 16, 2021.
  1. Dec 16, 2021 at 11:59 AM
    cementsharktrd
    cementsharktrd [OP] New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    My truck is sitting on 22 inch wheels with some 35s and there is significant power loss. My question is, is there significant power loss if you keep stock 17 inch wheels and pair them with 35inch tires?
    Sirfive likes this.
  2. Dec 16, 2021 at 12:05 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Weight plays a big factor overall. Try to see what your wheel/tire weight is and go from there. Maybe even consider a little narrower 35’s if you’re running 12.5’s to further help with the loss of power.
  3. Dec 16, 2021 at 12:09 PM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    Wheel size has very little to do with power loss (other than the weight of the wheel). The diameter/width and composition of the tire will have more affect on your power loss. With an identical tire brand, a 35" tire on 22" wheels will be the same as a 35" tire on 17" wheels. However, if you went with a narrower, lighter tire, you might see an improvement.
  4. Dec 16, 2021 at 12:11 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    i'm running 275/65/20's which is about a 34.5x11.2" tire and came from 285/55/20 which are about the same width but 33". its modestly different but nowhere near what i'd consider requiring regearing or anything like that. As mentioned above, weight is going to be a factor to pay attention to as well.
  5. Dec 16, 2021 at 12:32 PM
  6. Dec 16, 2021 at 12:32 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    your engine has not lost power, you have lost mechanical leverage moving to a larger diameter tire. Tundras have 430 gears and 32 inch tires stock. Increase to 35 inch tires is similar to reducing the gearing, so with 35s it feels like driving a stock tundra with say, 3.50 gears. And as mentioned, weight of the wheels and tires has a huge impact and can be much heavier than the stock setup.
    Many with 35s regear to 4.88 or 5.29 to bring back the performance.
  7. Dec 16, 2021 at 12:42 PM
    ToyotaG
    ToyotaG New Member
    Currently running 35s (heavy duratracs) on 17in wheels. On the low end you can sort feel a difference. Sometimes on the highway it hunts for gears a little bit depending on speed.
  8. Dec 16, 2021 at 1:44 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    We would need to know how much the 22" wheel and tire package weighs vs a 17" wheel and tire package. Generally speaking a 22" wheel is going to be significantly heavier than a 17" wheel, and since aluminum alloy is heavier than rubber (by a lot) a 22" wheel and tire package is going to be heavier.
    For example a quick search on Tirerack yields the following numbers:
    BF Goodrich All Terrain T/A KO2 35"X12.5"X17" = 66lbs per tire.
    BF Goodrich All Terrain T/A KO2 35"X12.5"X22" = 67lbs per tire.
    Alpha Equipt "Command" 17" wheel = 26.7lbs per wheel.
    Fuel Off-Road "Assault" 22" wheel = 51.9lbs per wheel.
    So with that in mind a 17" wheel and tire package weighs 92.7lbs per wheel and tire. While a 22" wheel and tire package weighs 118.9lbs per wheel and tire package.
    That's a significant difference in case you didn't know, 26.2lbs of unsprung rotational mass difference is HUGE when you figure that is 104.8lbs of extra rotational unsprung mass on the vehicle you can probably see why acceleration, braking, handling, fuel economy, and ride quality take it right in the ass. Rotational mass takes a ton more energy to get rolling, takes a lot more braking force to slow down, and change directions. Further that extra unsprung weight takes a lot more capacity to dampen motion up and down for the shock absorbers.
    There's a reason automotive engineers often go to extreme lengths (depending on application) to reduce unsprung rotational mass on a vehicle.
    Then you make it worse by increasing the diameter of that rotational mass, because you increase the leverage arm of that mass on the axis of that rotation. The heavier 22" wheel has more mass in the rim itself than a 17" wheel and it is further away from the axis of rotation increasing that undesirable leverage.
    The moral of this story is that only stupid people voluntarily put 22" wheels and big heavy tires on a truck and expect the wheel and tire package to do anything useful or good.
    Then there is the issue of reducing your wheel torque by increasing the diameter of your tire and decreasing the relative leverage of your axis of rotation over the tire, albeit not by a tremendous amount on jumping from a 32.1" to a 35" tire. It's within a few pound-feet of wheel torque of the stock tire diameter, but it is a bit less.
    AggiePhil, Darkness, Bobbyd and 7 others like this.
  9. Dec 20, 2021 at 1:43 PM
    1SikhTRDPRO
    1SikhTRDPRO New Member
    Think it would be possible to take a trd pro (2022) and move up from the 32.6" setup it has to a 35" with lightweight wheels (assume 8-10lb savings per wheel) and achieve the same fuel economy ?
  10. Dec 20, 2021 at 1:54 PM
    Coal Dragger
    Kung Fu Dick
    Probably not.
    You also have to factor in raising the truck increases aerodynamic inefficiencies. Plus the tires still have some mass, and moving that mass further from the axis of rotation still has an effect.
    That said being careful about saving weight will help. I doubt you will find a wheel lighter than the stock forged BBS on the Pro that’s anywhere near as strong.
    AggiePhil and Toyota1234 like this.
  11. Dec 20, 2021 at 2:06 PM
    1SikhTRDPRO
    Ah that makes sense, thought I found a loophole for a second. I dont know what the strength comparison is like but I was looking at TE37XT, about 17-19lbs per wheel.
  12. Dec 20, 2021 at 2:36 PM
    rothmigo
    rothmigo New Member
    DFW TX
    2020 Tundra Crewmax Platinum
    7" BDS/Fox, 5.29, 37x13.50 Nitto, 22x12 Hostile Rage,BAM
    What he said! Regeared to 5.29 with the 37x13.5 on mine -brought the beast back...and then some! You could try a Pedal Commander to customize your throttle response so you don't perceive you are lagging so much. I felt like with the 37's I wanted the regear and not a bandaid...but I did keep the Pedal Commander, just to take the edge off a lil! After the regear the truck gets going with ease and can't imagine towing without the regear...but again running the 37's vs. 35's so my issue was more pronounced.
  13. Dec 20, 2021 at 2:42 PM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    There is a little button called “Tow/Haul” push that.
  14. Dec 20, 2021 at 3:06 PM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    Every time you get into the truck? That would get old
  15. Dec 20, 2021 at 3:12 PM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    There are mods for auto on. But no I don’t think the “power loss” is significant enough. Point was, if OP is worried about it there is a $free.99 fix for that.
    I’m on 35s and don’t think there is anything to worry about it, after the first day you don’t even feel the difference. But I’m on 18’s.
  16. Dec 20, 2021 at 3:14 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Could always do what them Supra guys do and swap out your turbos day 1.
    :turtleride:
    boostedtrdpro likes this.
  17. Dec 21, 2021 at 3:34 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Does anyone know the offset of the current wheels (SR5 off-road in particular) or point me to a thread with it?
    the bolt pattern is 6 X 1.39 correct?…or am I off there too?
    Really want to know if a SR5 off-road (with whatever offset it has) and a level kit like the new rough country at 1.75 will rub if I put on some 295/70/18s from my current 2.5 gen.
  18. Dec 21, 2021 at 4:07 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    I have seen lots of photos of lifted 3rd gens with 35x12.5's and no modifications done to the plastics. The stock wheels I have no clue what the offset is, ideal offset for the new truck is 18-35mm
    bigjuice and TK1979 like this.
  19. Dec 21, 2021 at 4:31 PM
    defaint
    defaint New Member
    Jeremy
    Innawoods
    2021 MGM Tundra TRD Sport
    You sure about that? I thought all things being equal other than tire diameter, a larger tire lowers your gearing. Again, all things being equal, lower gearing will mean slower acceleration but more top speed if your limiting factor is transmission.
  20. Dec 21, 2021 at 4:45 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Or just do what I did, and fit a blower and call it a day. It’s waay faster now than it was before the lift and tires :rofl:
    Oh wait, is he talking about an actual 22’ or the truck in his profile?!?
    1UP[QUOTED] likes this.
  21. Dec 21, 2021 at 4:48 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    That’s not going to change your gear ratio or make the tires lighter.
    TK1979 likes this.
  22. Dec 21, 2021 at 6:06 PM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    Agreed.
  23. Dec 23, 2021 at 5:19 AM
    Netmonkey
    Georgetown, TX
    Yes, a 35” tire on 22” wheels is the same diameter as a 35” tire on 17” wheels. They will both equate to the same gearing. However, those 2 tire and wheel combinations will have different weights. I am not sure which combination weighs more, but the weight will affect acceleration, mpg, top speed, etc.
    1UP likes this.
  24. Dec 23, 2021 at 9:00 PM
    DexterL
    DexterL New Member
    99% of the time the larger the wheel the heavier it is and a lot of times the larger diameter rim’s tire is heavier as well. Small wheels, big tire gang
    RainMan_PNW likes this.
  25. Dec 23, 2021 at 9:34 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Coal Dragger is exactly right. When I was in school a teacher had this spinning wheel. It was like a record player that you could stand on with a weak electric motor. You hold a pair of 10lb weights, hold them against your chest and you spin fast. Hold them outward and your rotation slows down. It was entertaining that 20lbs was there no matter what, but moving it outward put strain on the motor.
    A 22" wheel puts the barrel out further than a 17" wheel. The barrel is the heaviest part of the wheel. The further out the weight is pushed the harder it will be to get it spinning. Hard to know what kind of difference was made without knowing exactly what wheels and tires you picked.
    In general, an OEM 17 will be much lighter than an aftermarket 22. When looking at two of the same kind of tire, both 35s but one is lower profile than the other, surprisingly there isn't a lot of weight difference. Much like with wheels, the bulk of the weight isn't in the sidewall but in the tread. A taller tire will slow you down by gearing, but the big wheels adding rotational mass are whats kicking your truck in the balls.
    Will a 17" wheel take less of a hit? Yes. Is it worth the cost of selling your wheels/tires and going to stock wheels with new tires? Maybe not. If you choose to do it, go with a skinny 35.
    Coal Dragger likes this.
  26. Dec 23, 2021 at 9:41 PM
    Coal Dragger
    Kung Fu Dick
    The real question is what does the OP want out of his 35”s? Looks or actual performance off road.
    If he just wants bling to impress low IQ chicks at the mall then by all means rock those 22” wheels on your wheel and tire combo. It’s going to have a look that fits in with a flat brim hat, white framed sunglasses and a robot dick in the mouth (aka vape pen).
    Otherwise go with the 17” wheel, the truck will perform a lot better and if you wheel it that sidewall height is gonna make life way easier soaking up abuse and not having issues like a low profile tire will.
    Darkness likes this.
  27. Dec 24, 2021 at 4:15 AM
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    You must regear your truck to counter the rotational drag from pushing larger tires! It will change your life! You can run 4.88 or 5.29. I went with nitro 5.29 after complaining of the same thing. Wow!’ What a difference it made. The truck is tuned to cruise at 1700rpm doing 65mph. I could even spin my tires and do some burnouts!
    https://m.youtube.com/watch?v=mHAbztz5Irc&t=445s
    Here is a simple conversation about the importance of regearing your truck after modification.
