Anytime fog lights, kinda...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Chad D., Oct 29, 2021.
  1. Oct 29, 2021 at 8:48 AM
    Chad D.
    Chad D. [OP] New Member
    Western Oregon
    2018 CrewMax Platinum
    Good morning all,
    I've got new fog lights on the way (BD Squadron Pro), and am looking for more flexibility with control than how I understand the standard "Anytime fog light" mod's. If I understand this mod correctly, I would lose the ability to turn off the fog lights if my high beams are on. With over 9,000 lumens in fog lights, I need to be able to control them all the time...
    What are your thoughts on this plan?
    • Wire up the new lights with the factory harness via Baja Designs' pig tails.
    • Tap into the hot wire at the light and feed it from my sPod switch.
    My thought with this plan is that I will have the ability to let the truck do it's own thing with the factory fog light switch, which will shut off the fogs when high-beams are on, as long as the fog light switch is on. My hope is that I can override this by flipping on the auxiliary switch and feed voltage via the sPod.
    My question for those that are more savvy than me is: Will I screw something up by putting power to the factory fog light circuit that would otherwise be "Off"? I can't see an issue, but this is not my field of expertise. I appreciate any constructive input or feedback!
    Thanks,
    Chad
  2. Oct 31, 2021 at 11:37 PM
    Chad D.
    Western Oregon
    Are the factory fogs switched on the negative or positive wire? I can see that standing in my way…
    Anybody have any thoughts or input? Parts are on the way, so hoping to get this figured out soon…. Thanks!
  3. Nov 2, 2021 at 11:26 AM
    jna
    jna New Member
    2016 Limited
    DR132 likes this.
  4. Nov 2, 2021 at 9:22 PM
    DR132
    DR132 New Member
    ALASKA
    2014 Tundra CM Platinum Blue Ribbon Metallic
    AWD Conversion, BAMuffler 8", Custom tuned with HPTuners, 2018+ LED Headlights, TRD front and rear sway bars
    I can confirm that this mod allows your fog lights to be on or off with any light switch combination including high beams (and excluding 'off' of course)
  5. Nov 3, 2021 at 5:09 PM
    Chad D.
    Western Oregon
    Hmmm. If this is appropriate for a 2018 model, then I believe it would be perfect. I understand there were some circuitry changes at the ‘18 model year; anyone able to confirm that this mod works on an ‘18?
    DR132 likes this.
  6. Nov 3, 2021 at 7:38 PM
    DR132
    DR132 New Member
    ALASKA
    Can't help you there unfortunately as my truck is a 14.
  7. Dec 16, 2021 at 11:06 AM
    Chad D.
    Western Oregon
    OK. Here's my plan. Please shoot holes in it if you see something fishy!
    To recap, I want to have 100% control over how my foglights work. If I understand correctly, the factory wiring utilized a switched ground for this circuit, so I think I can use a 5-pin relay to add a switch. This allows me to use my factory FL switch and let it all operate as Toyota intended, but with the ability to override via my sPOD.
    Relay pins configuration:
    85 - Switched +12v from sPOD
    86 - Chassis Ground
    30 - Ground wire to fog lights
    87a - Ground wire at factory light harness
    87 - Chassis Ground
    With sPOD switch "off", the relay will connect the factory harness to the light ground via pins 30-87a. All functions will operate as original.
    With sPOD switch "on", the relay will disconnect the light ground from the factory harness and send it to chassis ground via pins 30-87. This will turn on the lights regardless of headlight operation and keep all sPOD controls isolated from the factory circuit.
    Lika sooo:
    Thoughts? Lights work like factory unless I want them different.
