2020 tundra 3”-1” lift will these tires fit
Discussion in 'Wheels & Tires' started by Bucs5fan5, Dec 15, 2021.
  1. Dec 15, 2021 at 4:30 PM
    Bucs5fan5
    Bucs5fan5 [OP] New Member
    Gary
    2020 tundra
    I have 2020 tundra with a 3” lift I want to put 305/65/18s will the fit with out rubbing ? Please help no one has an answer for me
  2. Dec 15, 2021 at 4:40 PM
    2mchfun
    Go to tire comparison calculator and wheel offset calculator and compare the data to your current set up, don't forget the front tire positions change when steered and the suspension flexes. Lots of if, ands, or, and buts to consider. Google tire size comparison calculator and you can find the wheel offset calculator attached to page 2 iirc. Good place to at least start.
  3. Dec 15, 2021 at 5:18 PM
    As mentioned, wheel offset is a big factor in this.
  4. Dec 15, 2021 at 5:27 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Those should fit. You might need to do a little persuading based on alignment. I would guess it would be mostly plastic.
  5. Dec 15, 2021 at 5:30 PM
    Bucs5fan5
    Gary
    2020 tundra
    Called my dealership and that’s what they recommended for my lift and truck thanks for the input
