  1. Dec 15, 2021 at 8:48 AM
    That's one way to use your ramps, I guess.
    Voss, Darkness and NWPirate like this.
  2. Dec 15, 2021 at 8:48 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    What the sam hell is going on here? (aside from the obvious)
    bmf4069, Voss, Darkness and 2 others like this.
  3. Dec 15, 2021 at 8:53 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    just eyeballin some ideas in case i build a bumper.
    plus, who doesnt like hard corners?
    abcinv, bmf4069, TRDGen and 3 others like this.
  4. Dec 15, 2021 at 11:44 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    :101010::rofl::rofl::rofl:
    Voss and Darkness like this.
  5. Dec 15, 2021 at 12:06 PM
    kb7
    kb7 New Member
    USA
    2003 Tundra SR5 TRD 4x4
    What fog lights are those
  6. Dec 15, 2021 at 12:15 PM
    Openbaffle
    Openbaffle New Member
    Baja Designs squadron SAEs.
    kb7[QUOTED] and TRDGen like this.
  7. Dec 15, 2021 at 12:17 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    What front bumper is that and do you know what their lead time is???
    bmf4069, Tundra2, NUDRAT and 5 others like this.
  8. Dec 15, 2021 at 12:22 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    i think its called a pitterpaddy, but couldnt find a website. And its taken me 2 months to get this far…so…
    CodyP[QUOTED] likes this.
  9. Dec 15, 2021 at 2:13 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    She’s off to the shop. $1,500 to fix it “the right way” and to repaint my roof. Not bad considering I had a quote of $800 from another spot to paint the roof.
    Fingers crossed it all turns out well.
    Darkness, bmf4069, NUDRAT and 5 others like this.
  10. Dec 15, 2021 at 4:58 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Twins kinda
    Darkness, Voss and Openbaffle[QUOTED] like this.
  11. Dec 15, 2021 at 5:03 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Paging @empty_lord, how would you go about opening a front passenger door (2000 AC) that is locked, and neither fob, key, nor interior switch will unlock. The window operates no problem. Its not an electrical issue, I believe the gears in the motor are broken/jammed, and not allowing the rest of the assembly any movement. I've removed the inner window weatherstrip and pulled the top of the panel away from the door, which gives me a bit more access, but can't remove it entirely with the door closed as you know, nor can i get to the 3 torx bolts to remove the entire latch assembly. My next move will be to somehow disconnect the motor from the latch while inside the door. probably just break off the actuator arms from the motor so everything else can move freely. So my questions to you (or anybody else that has the answers)
    Am I on the right path?
    Or is there a better way?
    Please and Thank You
  12. Dec 15, 2021 at 5:11 PM
    Openbaffle
    Looks like it! Nice to see the black wheels on Phantom Gray. I see you went the opposite of me and blacked out the grill and left the chrome on the bumper. Like the hood lights as well. Short antenna. I like the way that looks. Clear corners. Nice truck!
    I received a small baggy of green gels for my LEDs. Will install tomorrow.
    bmf4069, TRDGen and daveeasa like this.
  13. Dec 15, 2021 at 5:17 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Mine did that when the window track came loose and wedges on the lock mechanism. I had to brute force in by removing the door panel. It wasn’t pretty
    Darkness likes this.
  14. Dec 15, 2021 at 5:18 PM
    daveeasa
    Nice gels. I have my green LED’s but haven’t installed yet. Tomorrow is a trip to Clovis for my bumper. Hope to have some spare time for truck mods so taking some extra tools and gear.
  15. Dec 15, 2021 at 6:19 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    well, my motor is locked up internally, not from the window track. I've got the top of the panel peeled back, I was just hoping there was a trick and thought I'd ask before i started the rippin and the tearin. So no easy way. Gotcha. Thanx
  16. Dec 15, 2021 at 6:27 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Damn, San D to Clovis is a trek. Gonna have the bumper installed up there?
  17. Dec 15, 2021 at 6:35 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Brute Force Baby! Get my sliders! :)
  18. Dec 15, 2021 at 7:10 PM
    daveeasa
    I certainly can fit some extra stuff. If you authorize me as your courier I can do it. Heading to San Carlos for the evening and Monterey on Friday for Mr Marv visit then Palm Desert for family time.
  19. Dec 15, 2021 at 7:11 PM
    daveeasa
    I’ll see how busy they are. Planning to GTFO at oh dark 30 to maximize the possibilities.
  20. Dec 15, 2021 at 7:26 PM
    alb1k
    Left Coast
    It's good
    Thanks @daveeasa! I don't think they are done. Just move them to the front of the list...:)
  21. Dec 15, 2021 at 7:28 PM
    Tell Josh Homme I said WHAASSUP MF!
    daveeasa[QUOTED] likes this.
  22. Dec 15, 2021 at 7:29 PM
    Henry1stGen
    Henry1stGen New Member
    Henry
    2002 Tundra AC TRD
    Headlights, audio, interior, suspension, bed lights, and more
    Installed the SmartTap by Diode Dynamics. Thanks for the recommendation. I like the features. Just wished the Arrival/Departure feature worked with my factory alarm on my 02 Tundra AC.
    Diode Dynamics SmartTap CF18 LED Flasher Module https://www.amazon.com/dp/B085B9PLHF?_encoding=UTF8
    This weekend I need to do a drain and refill on my Transmission. Dealers want between $195 and $285 to do a drain and refill without the T-tech. It used to cost $80 to do the job. Why so much now?
    I just need 3 quarts of Transmission oil and a new crusher washer? Drain Nut needs to be torqued to 10ft lbs? Put in the same amount that was taken out? Warm up transmission and check levels at normal operating temperature? Anything else?
  23. Dec 15, 2021 at 7:40 PM
    '06 guy with same beef as you on this one....
  24. Dec 15, 2021 at 8:05 PM
    empty_lord
    05 rollover special
    My Avalon departure works. Arrival doesn’t. Toyotas flash hazards twice with unlock so it won’t work. Subaru is the only one that works 100%
    shifty` likes this.
  25. Dec 15, 2021 at 8:16 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Added some ATP at-205 to my oil and power steering fluid this morning. Then treated her to a new front windshield. I was rolling with the original Yota one and it was hard to see out of it in certain lights. Made a huge difference!
    FrenchToasty and RUSTYNUTS like this.
  26. Dec 15, 2021 at 10:50 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Anyone with a 3 4L v6 want my Dirty Deeds 16 hole 5vzfe injectors? New in package still. I paid $350, but I'm selling my t100 and I will pay to ship em to you for $300.
  27. Dec 15, 2021 at 11:04 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Guess I didn’t need Diode Dynamics to send me another module as warranty. Bummed I won’t get arrival/departure to work.
  28. Dec 15, 2021 at 11:33 PM
    empty_lord
    05 rollover special
    double cab should flash the hazrads i think since it uses a BCM AC and Reg cab flash the parking lights. you should have departure lights. unless the DC flashes park lights too (aka does you license plate lights flush with the lock and unlock?)
  29. Dec 16, 2021 at 12:44 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    They do indeed, at least on the 04
  30. Dec 16, 2021 at 4:11 AM
    What made you change your mind?
