  1. Dec 14, 2021 at 10:30 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Post that onto the ride height ?sticky?.
    hub center to fender numbers.
    Openbaffle likes this.
  2. Dec 14, 2021 at 10:34 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Did these tires get you better MPG vs the MT's?
  3. Dec 14, 2021 at 10:45 AM
    Openbaffle
    Openbaffle New Member
    About 2-3 MPG increase is what I'm seeing. They are still big, heavy and e-rated, however. I've not been through a tank of gas yet however.
    2006Tundra[QUOTED] likes this.
  4. Dec 14, 2021 at 10:56 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I have the exact same kit on my truck, except I have Freedom Offroad UCAs.
    My LF corner is down a bit compared to the RF. I'm hoping with some more time and maybe some shims, I can level the front. (L to R)
  5. Dec 14, 2021 at 11:05 AM
    Openbaffle
    These were my post-lift, post bumper/camper install measurements. I'm down a little bit in the front left, too.
    Post-Lift Measurements:
    1. Front L: 22”
    2. Front R:22.5”
    3. Rear R: 22.5”
    4. Rear L: 22.75”
    chrisb[QUOTED] likes this.
  6. Dec 14, 2021 at 4:39 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Today I hit a hidden wall in a parking lot. Turned out of a parking spot and didn’t notice the 2 1/2’ high wall which had clearly been hit Numerous times. It hurts. Specially since I’ve had metal sitting in the garage for sliders for a few months now.
    Darkness, oscardog86 and dinosaur like this.
  7. Dec 14, 2021 at 4:45 PM
    Oh man, that sucks. The door skin and step bar can be replaced. I'm not sure how much work it'll take to fix the door sill.
    Darkness, dinosaur and Voss[QUOTED] like this.
  8. Dec 14, 2021 at 4:48 PM
    Voss
    2003 AC TRD 4x4
    I'm good with driving it as is but I'm concerned about water coming into the cab over water crossing. what a bummer!
  9. Dec 14, 2021 at 4:55 PM
    daveeasa
    I felt a punch to the gut looking at that, @Voss
    condolences
    Darkness, oscardog86, bmf4069 and 3 others like this.
  10. Dec 14, 2021 at 5:01 PM
    Voss
    2003 AC TRD 4x4
    This feels worse than when I caught my girlfriend cheating on me lol
  11. Dec 14, 2021 at 5:04 PM
    lowell66dart
    lowell66dart New Member
    lowell
    South Louisiana
    2001 Tundra 4WD
    Rough Country level, RAS rear springs, Magnaflow, custom front bumper
    You mean your ex-girlfriend……
    Darkness, RUSTYNUTS, TRDGen and 5 others like this.
  12. Dec 14, 2021 at 5:11 PM
    Voss
    2003 AC TRD 4x4
    I stand corrected, X girlfriend
    Darkness, RUSTYNUTS, TRDGen and 3 others like this.
  13. Dec 14, 2021 at 5:52 PM
    Openbaffle
    Done.
  14. Dec 14, 2021 at 5:54 PM
    Openbaffle
    Sorry :( This sucks.
    Darkness and Voss[QUOTED] like this.
  15. Dec 14, 2021 at 6:23 PM
    Voss
    2003 AC TRD 4x4
    Seems it may not be too bad. The bottom is lined up well and I see no gaps…
    Only gap I see…
  16. Dec 14, 2021 at 6:27 PM
    lowell66dart
    lowell
    South Louisiana
    2001 Tundra 4WD
    I did the same once driving my company truck only a lot worse. Passenger side also. It’s hard to avoid something you can’t damn well see.
    Darkness and Voss like this.
  17. Dec 14, 2021 at 6:30 PM
    kb7
    kb7 New Member
    USA
    2003 Tundra SR5 TRD 4x4
    Hood was repainted due to the clear coat goin. Got an offer of $25k for my truck from one of the guys at the shop. Really made me consider
    NUDRAT, Darkness, TRDGen and 5 others like this.
  18. Dec 14, 2021 at 6:47 PM
    FatBuddy92
    FatBuddy92 New Member
    Athens, GA
    @kb7 what are the stats for someone to offer $25k for it??
  19. Dec 14, 2021 at 7:10 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Curious as well........
  20. Dec 14, 2021 at 7:39 PM
    Low mileage?
  21. Dec 14, 2021 at 8:00 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Only thing I've run high pressure valves on was our prototype airbag setup. I don't recall the lbs for the regular, but it seemed like it was pretty high. The e rated I ran were just regular rubber stems.
    Darkness and chrisb[QUOTED] like this.
  22. Dec 14, 2021 at 8:01 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Standard stems usually are fine to 60psi. I just use broke TPMS sensor stems for most of my cars… they hold a lot of pressure and they’re free for me because lubetechs break sensors a lot
  23. Dec 14, 2021 at 8:25 PM
    daveeasa
    I've done 80psi w shraders on my bicycle. Granted not at 80mph. I shoulda saved my 4 steel wheel tpms stems but the guy said removing them destroys them or something? I wasn't really buying that, but I do have my TMPS' ready to rock on my sr5 wheels.
    Thinking I may stay 16" wheel-wise after all, which means no giant tires. Maybe that's OK though, how much height do I really need?
    Darkness likes this.
  24. Dec 14, 2021 at 8:44 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Don't ask the guy who either bought a used truck or just moved in around the corner. I'm sure he thinks his truck is awesome. It's a suburban or something that may be on 35's. I'm guessing it's a bracket lift because their is a 12" spacer thing up front with some logo cut into it. Stupid ass truck, embarrassing really.
    Voss, Darkness, NWPirate and 3 others like this.
  25. Dec 14, 2021 at 9:04 PM
    kb7
    kb7 New Member
    USA
    60k mi.
    Had timing belt, water pump replaced at 40k along with any rubber in the engine bay. Upgraded rims/tires, oem Toyota touchscreen and master tailgaters back up camera. New 2k camper. Roof, hood, doors repainted at this shop, the owner always wants to take it off my hands.
    NUDRAT, hammeron, oscardog86 and 7 others like this.
  26. Dec 14, 2021 at 9:11 PM
    alb1k
    Left Coast
    It's good
    That does suck, sorry buddy.
  27. Dec 15, 2021 at 2:45 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I always tell the dealership salesmen they can have it for $100k when they try to get me to sell my 06 :laugh: they get the hint after that ... Til the next time I'm there.
    Why would I sell the best truck I've ever owned? And after modding the hell out of it, spending countless dollars and hours working on it and making memories with it
  28. Dec 15, 2021 at 8:10 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  29. Dec 15, 2021 at 8:13 AM
    Openbaffle
    I don't think I posted a picture with my lights on yet after upgrading everything.
    abcinv, bmf4069, TRDGen and 7 others like this.
  30. Dec 15, 2021 at 8:44 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
