'06 Baseline Dyno done.
Discussion in '1st Gen Tundras (2000-2006)' started by Riverdale21, Oct 19, 2021.
  1. Oct 19, 2021 at 1:27 PM
    Riverdale21
    Riverdale21 [OP] Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Baseline dyno done today before headers and exhaust.
    2006 DC Toyota Tundra V8 TRD Off-Road 2WD, 130k miles.
    Maintenance:
    -New plugs
    -New o2 sensors
    -RedLine 75w90 LSD rear diff oil
    -Recent oil change with Mobil full synthetic 5w20 and larger 51515xp Wix oil filter
    Mods:
    AEM drop in dry air filter
    Dirty Deeds 12 hole injectors
    Ambient temp 72*F, 788ft above sea level in North West Georgia. DynoJet dyno with no correction factor.
    Tried to upload a video, will try again later.
    Was only expecting around 200hp/210tq at the wheels, it being a 15 year old truck.
    Will upload second dyno run after headers/exhaust installed.
  2. Oct 19, 2021 at 8:44 PM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    Nice results!
  3. Oct 19, 2021 at 8:50 PM
    Casper421
    In the woods
    06 DC
    You’ve got my attention! What headers and exhaust are you going with again?
  4. Oct 20, 2021 at 5:09 AM
    Would've loved to see a snapshot from before the DD injectors, but should be interesting to see gains from exhaust mods for sure.
    If anyone is too lazy to look up, stock specs for the '06 w/4.7 are
    Horsepower 271 hp @ 5,400 rpm
    Torque 313 lb-ft @ 3,400 rpm
    Not surprised to see it exceeded 240 on both. I wouldn't expect a 30%+ decline in HP/TQ on a well-maintained drivetrain. Current decline is 10% on HP, 12% on TQ.
    I'd also be interested to see what it's capable of with the stock filter, given what has been shown in videos comparing stock to no filter to AEM/K&N style filters, wet and dry.
    Tundra2 and ryanwgregg like this.
  5. Oct 20, 2021 at 5:21 AM
    Riverdale21
    OTP ATL
    Stan's tri-Y headers and custom exhaust.
    dbittle likes this.
  6. Oct 20, 2021 at 7:06 AM
    Riverdale21
    OTP ATL
    My long term goal is building a bottom end with stronger rods and head studs, then installing a roots style supercharger with 12-15psi of boost. But that is still a couple years down the road.
    The same information you reference is why I haven't done much to the intake tract. And the air intake will probably be replaced or modified with the supercharger.
    I'm aware of the stock intake's design efficiency and ran a stock paper type filter up until recently. Also not a fan of the oiled K&N type filters. When I installed the AEM dry filter I also removed the factory charcoal activated air filter at the same time. While I can't verify my claims with actual numbers the truck seemed the respond positively to the change. It would have remained a stock paper filter had I not aquired the AEM for basically free.
  7. Oct 20, 2021 at 9:59 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm excited to see this. Thanks for taking the time and spending the money to show us real data.
    :hattip:
    Punk1974 and Riverdale21[OP] like this.
  8. Oct 20, 2021 at 10:26 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Actually, I think his numbers are at the wheel vs. the factory numbers which are at the crank. So they are inline with what I would expect to see, given drivetrain losses.
  9. Oct 20, 2021 at 10:32 AM
    You can upload the video to YouTube, then link it here.
    Punk1974 likes this.
  10. Oct 20, 2021 at 10:39 AM
    Riverdale21
    OTP ATL
    I've tried, whenever I try to publish it gives me an error. It's pretty standard video. A 7 second pull at wide open throttle. Not really missing out on anything special.
    Darkness likes this.
  11. Oct 20, 2021 at 12:00 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Solid numbers, I'd be happy with those.
  12. Dec 8, 2021 at 3:44 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Try again!
  13. Dec 8, 2021 at 4:20 PM
    Riverdale21
    OTP ATL
    dinosaur and Darkness[QUOTED] like this.
  14. Dec 8, 2021 at 6:45 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    Did they give you an estimate of RPM at TQ peak? Seems like it may have peaked lower than stock, which is a plus in my book.
  15. Dec 8, 2021 at 6:55 PM
    Riverdale21
    OTP ATL
    No clue unfortunately. I'm not certain what gear was used, otherwise I could try to match speeds and observe RPM on the street.
  16. Dec 8, 2021 at 7:03 PM
    10 blue trucks
    04 4WD RCLB
    They did it in 4th on your 06 I would guess. which 65mph would be low 3000s somewhere, but on the road you are fighting bumps and wind drag, so a dyno mph is not a direct correlation it doesn't have to work as hard to spin the rollers.
  17. Dec 8, 2021 at 7:07 PM
    10 blue trucks
    04 4WD RCLB
    if you hop on a freeway, hold 65, and hit the tow/haul button, it will give you a 65mph reference rpm that will be likely slightly higher than the dyno rpm, but we'll never know by how much.
  18. Dec 9, 2021 at 4:59 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    HP = (RPM x torque) divided by 5252
    FACT: When the horizontal axis of the graph is RPM (vs MPH), the HP and Torque lines always cross at 5252 RPM.
    QUESTION: So given that, can it be inferred that the RPM at 84 MPH (where the lines cross) is 5252? :monocle: I don't know. Maybe someone who's better at math can confirm.
    Darkness and Punk1974 like this.
  19. Dec 9, 2021 at 5:26 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    based on bubbles postulous could it be that peak hp is 248??
  20. Dec 9, 2021 at 9:57 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Tire size and rear end gearing is also a factor.
    265/75r17 & A750 trans, at 84mph (approx.):
    5th = 2675rpm
    4th = 4075rpm
    3rd = 5425rpm
