Switching to 5w30?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Klowry97, Mar 23, 2020.
  1. Dec 9, 2021 at 6:56 AM
    #121
    tundraiggy73
    tundraiggy73 New Member
    2021 Cement Crewmax Trail Edition
    The 5.7 is a great engine and I've never had one apart for issues related to lubrication (except for external leaks such as cam towers). If you're worried about proper lubrication, use what Toyota recommends.
    I'm on my 4th Toyota 5.7L engine (2 Sequoias and 2 Tundras). I change my oil every 5,000 miles with the manufacturer recommended oil and never lose a minute sleep over this subject.
  2. Dec 9, 2021 at 7:20 AM
    #122
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    My first foray into synthetic oils was with a 2002 Honda Goldwing motorcycle. I was running at the time a 10w40 conventional oil and, since it saw mostly highway use, I changed it ever 6000 miles. A friend had convinced me to try a full synthetic, so I gave it a try. The bike took a gallon at changes, so it was convenient to put the used oil back in the gallon container the new oil came out of. I poured the used conventional, with 6000 miles on it, back in the container the new synthetic came out of and set it on the "Used oil" shelf where it'd sit 'til I made a run to the recycle place.
    At the next 6000 miles (I wasn't convinced yet) I changed it again and repeated the process. I set the now-used synthetic on the shelf next to the used dino oil, and it looked cleaner. I could put a drop of either on a white paper towel, and the dino oil was noticeably darker. A few days later a friend was over, and I showed him. We then flipped both bottles on their side, so we could see what was in the bottom of the bottles, and the used dino oil had a thin layer of dark gunk on the bottom. The synthetic didn't have that layer. The bottom of the bottle was darker than the sides, but there was no layer of dark gunk. It was the same bike, same oil filter, virtually the same mileage under virtually identical conditions, and the conventional developed noticeable gunk, and the synthetic didn't. Go figure. He suggested that the dino oil had been sitting there longer, so I shook them both up and set them there again, and a week later the gunk had settled back.
    I've since done the same kind of experiments with a high-mileage Cavalier that I bought as a commuter car before retiring. The Cavalier also conveniently took a gallon at changes. I could run a conventional oil for 6000 miles and change it, and after setting on the shelf for a few days then conventional would develop more gunk on the bottom than the synthetic that I was running for 12,000 miles. I decided I'd pay, at the time, twice as much for the oil and use it twice as long and spend half the time on the ground under the car :)
    It's not only the fuels we use in internal combustion engines that contaminate the oil. Heat is a big factor, and synthetics handle heat better than conventional.
    R65 likes this.
  3. Dec 9, 2021 at 7:44 AM
    #123
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    What a lovely topic you decided to choose. I’m not trying to advocate for or against conventional oil. Have you tried to heat up base stock Dino oil vs base stock PAO? Both look and behave pretty much like oily water and withstand any reasonable amount of heat without a hint of deterioration. The same can be said about most base oil stocks. The remaining retail oil properties determined by the additives package.
    My guess is that the gunk you had with your Dino oil was kept in solution and removed when you drained your oil.
  4. Dec 9, 2021 at 7:50 AM
    #124
    sd172
    sd172 New Member
    South Dakota
  5. Dec 9, 2021 at 7:50 AM
    #125
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Boy howdy is it ever.
    Saltyhero13 and hagrid like this.
  6. Dec 9, 2021 at 7:51 AM
    #126
    68rs75z28
    68rs75z28 New Member
    2020 tundra sr5 dc
    Ahh someone with some common sense.
    I have made those same arguments on a camaro forum and there is a guy there that swears synthetics cause engine failures. It's like for the LOVE OF GOD stop what you're doing because you have no clue what you're talking about.
  7. Dec 9, 2021 at 7:59 AM
    #127
    Kentuckytundra
    Kentuckytundra I love spam calls, we talk for hours
    :D
  8. Dec 9, 2021 at 8:01 AM
    #128
    68rs75z28
    2020 tundra sr5 dc
    Reading back through this, I am on the 0w-20 side of things. I know many fords that use 0w-20 that have 250k on them(f250) that have never had engine or trans problems... On a ford its just everything else that falls apart.
    Cpl_Punishment and Oey12 like this.
  9. Dec 9, 2021 at 8:03 AM
    #129
    sd172
    sd172 New Member
    South Dakota
    Here’s an easy solution for everyone. Get yourself a vibration activated engine hour meter and never go over 200 hours between oil changes.
    OHwendTrd and Sumo91 like this.
  10. Dec 9, 2021 at 8:06 AM
    #130
    Kentuckytundra
    Interesting, never seen one before.
  11. Dec 9, 2021 at 8:08 AM
    #131
    sd172
    sd172 New Member
    South Dakota
  12. Dec 9, 2021 at 8:09 AM
    #132
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Warmer climates, 5/30.
    Cold climates 0/20
    Done.......
    Alex38, WILLINH and Gunship Guy like this.
  13. Dec 9, 2021 at 8:59 AM
    #133
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    Thank you. I thought it a lovely topic as well. :cool:
    Maybe it's the synthetic that holds it in solution since it doesn't seem to settle out.
    But whatever ....
    I've already said in another oil thread that I've been seeing oil arguments in motorcycle and car forums for some 25 years, and if there's one thing I've learned it's that virtually everyone is absolutely certain that he's right and everyone who disagrees is wrong. :) I was a hard sell on synthetics at first. When I switched, both my wife and I commuted a lot for work and were doing 20,000+ miles annually. I also toured on a motorcycle and was putting 12,000+ on my touring bike and another 4000 on my "angry" bike. :) It seemed that I was under something changing oil most every weekend. I doubled the change interval on both our cars and both bikes and everything's done fine for the last 15 years or so.
    I do appreciate the fact that higher viscosities are acceptable in other countries. I've got my next couple of oil changes sitting in my shop now, but after they're used, considering my planned use for this truck, I'll likely go up a but. I sure won't do 20w50, but maybe there's some 5w30 in it's future :)
    sd172[QUOTED] likes this.
  14. Dec 9, 2021 at 9:12 AM
    #134
    sd172
    sd172 New Member
    South Dakota
    You have probably the best possible conditions to run an extended OCI - lots of highway driving.
    In Europe, the push for synthetics in late 1990s - early 2000s (aka Long Life oils) plus extended drain intervals made so many engines looking like this:
    https://www.bimmerfest.com/threads/so-much-sludge-pictures.901315/
    That is why I make an argument that your oil viscosity and oil type are not as important as a reasonable OCI. :cheers:
    Nowhereman likes this.
  15. Dec 9, 2021 at 10:07 AM
    #135
    68rs75z28
    2020 tundra sr5 dc
    Definitely not a good representation.. here is a comment from the thread of part of the reason why that happened:
    Yeah there is a valve in the valve cover that I know was not operational, could have been compounding the issue. So that is sorted now that the valve cover has been replaced. I also put new VANOS solenoids in it after I bought it. I want to try to clean things out now and keep it from building up any more. I think I am going to go with this oil. Or the dealer oil, depending on what they say tomorrow.
    If PCV isn't working you're not able to remove water/vapors form the oil which causes sludge.
    I do agree with you though, long oil change intervals are NOT Good for an engine. Oil is cheap... an engine rebuild isn't
  16. Dec 9, 2021 at 10:15 AM
    #136
    sd172
    sd172 New Member
    South Dakota
    This engine looks like a typical Euro engine running on synthetic oil with an extended OCI. The PCV failure might have contributed to the buildup, but I doubt that was the main culprit.
  17. Dec 9, 2021 at 10:17 AM
    #137
    68rs75z28
    2020 tundra sr5 dc
    It was 100 percent the culprit lol
    Some engines you can change the oil every 1k and it will build sludge.
    I have friends who are dumb enough to go 25k on an oil change and never build sludge.
    The CCV or PVC whatever you want to call it, remove water which will directly cause sludge.
  18. Dec 9, 2021 at 10:25 AM
    #138
    sd172
    sd172 New Member
    South Dakota
    Sure, PCV it is. I don’t want to try to reproduce this mess in my engine though, even for the scientific accuracy.
  19. Dec 9, 2021 at 1:17 PM
    #139
    Chip_Tundra
    Chip_Tundra New Member
    A lot of people seem to be on board with 10K OCIs or 1 year which ever comes first. I'm not one of them. Might as well add this vid to every oil thread out there.
    https://www.youtube.com/watch?v=v4JS7PybV2k
    I'm sticking to 5K or 6 months.
    I'd rather not have scored cylinder walls.
  20. Dec 9, 2021 at 2:23 PM
    #140
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    Definitely at the time. Not so much now. I do still do a lot of miles on one bike, but the car and "angry" bike are back to at least annual changes. The intended purpose of the Tundra is to pull a 6000-pound trailer, and it'll probably be pulling it 90% of its life. I'll change the oil around trips but shoot for 5000 miles.
    I think that's the catch in the extended oil change intervals touted by some synthetic manufacturers. Mobil 1, for instance, says their Extended Performance is good for 20,000 miles or 12 months. Well, common sense suggests that someone who does 20,000 a year does primarily highway miles. It's a safe bet for them.
  21. Dec 9, 2021 at 2:49 PM
    #141
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I can say with certainty that forum people worry more about their engine oil than the people that design and make it.
  22. Dec 9, 2021 at 6:36 PM
    #142
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Very telling video.
    Catch cans, yes or no?
    Gunship Guy likes this.
  23. Dec 9, 2021 at 7:07 PM
    #143
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    Maybe we should start a list of states with the recommended oil weights.
    I’ll start...
    NJ/NY: 5w30 all year - Amsoil SS
    Punisher1 and Trust86 like this.
  24. Dec 9, 2021 at 7:11 PM
    #144
    AZBoatHauler
    So.Arizona
    AZ: 5w30 - Mobil1 way quieter than 0w-20.
    Trust86 and TundraTed[QUOTED] like this.
  25. Dec 10, 2021 at 2:51 AM
    #145
    sd172
    sd172 New Member
    South Dakota
    SD/MN/NE/IA
    Summer - Chevron Delo SDE 15w40 / Castrol GTX 10w40
    Winter - Castrol GTX 10w30
    Diesel tick? Lol
    Trust86 likes this.
  26. Dec 10, 2021 at 4:13 AM
    #146
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    PA: Rape Seed oil, exxxtra virgin. Smell distracts from catastrophic transmission temps.
    Ericsopa, WILLINH, Sumo91 and 7 others like this.
  27. Dec 10, 2021 at 4:55 AM
    #147
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    I panned ahead in the video. Stopped at about the 6:50 mark. Heard Duuuuuuude saying "so we should check our oil every fill up. But we don't. I don't. I don't expect you to. But at every oil change were down about a quart....." Aaaaaaaaaaaaaaaand that's enough of that video.
    Say the phvck what???? Huh? I've owned SEVEN new-from-the-dealer Toyotas and have done every single oil change myself. Close to 300 of them. I have NEVER been down a quart at a Toyota oil change. I'm seven oil changes into the Tundra doing them at 10K and, again, never. What a crock of bull dung.
  28. Dec 10, 2021 at 5:01 AM
    #148
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I concur. I've never had a Toyota that consumed oil. i have had 6
    my 3 honda's...never.
    my 84 monte carlo....well....i had the 3.8 with the bad valve seals.
    Sumo91 and Cpl_Punishment like this.
  29. Dec 10, 2021 at 5:26 AM
    #149
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
  30. Dec 10, 2021 at 5:32 AM
    #150
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Honestly it sounds like he was referring to owners that do extremely low mileage annually. Maybe he should have clarified. While it sounds like you drive many more miles that that annually on your Toyota’s. The higher the annual mileage the better off you are sticking to the 10k OCI UNLESS you are doing extreme off-roading or towing at max constantly, etc etc. So in your case I do agree with you but I also like and enjoy a lot on his content.
    On the flip side I have seen an elderly relative blow a brought from new Toyota Camry 4 cylinder and a brought from new Honda V6 engine with very low mileage but both over 7 years old but less than 9. He wouldn’t change the oil unless he hit the recommended mileage (it was a waste in his opinion) despite us telling him otherwise. He only did short runs and barely any highway. So unfortunately I have to disagree and say there is VALIDITY to what he is saying BUT not to whether it’s losing a quart, but instead to the fact that not all vehicles are treated the same. And should be cared for accordingly…but again HE SHOULD CLARIFY THIS.
    omgboost likes this.
