Squeal on start up til warm. Thoughts?
Discussion in '1st Gen Tundras (2000-2006)' started by fighthedude, Dec 8, 2021.
  1. Dec 8, 2021 at 12:07 PM
    fighthedude
    fighthedude [OP] New Member
    Truck has a newer (last couple months) when starting up. I cant tell if it is belt or idler pulley etc. got an automotive stethoscope but still can't pinpoint. I have will try and attach video. All service is up to date. Thanks for any advice.
    well i cant upload video ... suggestions
  2. Dec 8, 2021 at 12:10 PM
    shifty` You can call 1 (800) PP5-1-DooDoo
  3. Dec 8, 2021 at 12:11 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    usually its the belt itself when it squeals like that. Do you notice any excessive wobble in the pulley on cold startup? does the best seem tight enough?
  4. Dec 8, 2021 at 12:13 PM
    Get a replacement belt. This has been a long time issue with Tundras. The fix was a Gatorback belt which is now branded under the "Elite" brand of Continental as I recall.
    You can pick them up at your local Autozone for around $30.
  5. Dec 8, 2021 at 12:35 PM
    fighthedude
    Ill try belt first I guess. No wobble. Its not the high pitch like you mentioned @shifty` It usually last a few minutes. Dont get oem belt? Something else is better in this situation?
  6. Dec 8, 2021 at 12:36 PM
    fighthedude
    My thoughts it might be the idler pulley bearing or maybe fan bearing but it always goes away.
  7. Dec 8, 2021 at 1:49 PM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    in the past on some of my cars its and old belt that needs replaced. since i’ve studyed a lot around here lately some have gone with a new green gates hd belt and in addition upgraded to the newer style acc belt tensioner made by toyoda. amazom reviews look good. some say its way thicker and heavyer.
    a test is squirt some belt dressing on the fan belt while its running making sure not to chop yer fingers. if sound instantly goes then its a new belt needed. bonus points for tensioner upgrade. might help with better boltage at alternater to..
    bmf4069 likes this.
  8. Dec 9, 2021 at 4:50 AM
    bmf4069 Captain wtf
    Put the video on you tube then post a link here.
    Punk1974 likes this.
  9. Dec 9, 2021 at 5:11 AM
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd
    I have a 2000 Tundra. Mine did the same several years ago. I diagnosed the source of the noise by purchasing a can of CRC belt conditioner. After a squirt the noise went away. I drove for another 30k-40k miles until it was time to replace the timing belt, then replaced the serpentine belt at that time. IIRC, I might have given the belt another squirt during the 30k-40k. The can still sits ready and alert... just in case.
    NewImprovedRon and bmf4069 like this.
  10. Dec 9, 2021 at 5:14 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    A quick check (not fix) would be to spray some belt conditioner on the belt and see if it goes away. If the rubber is hard, glazed or cracked it will make the sound go away temporarily. Then I would get a new belt and set aside some time to change it. Good luck!
  11. Dec 9, 2021 at 5:15 AM
    Punk1974
    J.P.
    fightdude brought up a good point about the fan pulley. had a crunchy bearing one on my 2000 when after did the timing belt.
    bmf4069 likes this.
  12. Dec 9, 2021 at 5:26 AM
    ChattanoogaPhil
    2000 4.7 AC SR5 4wd
    Unrelated to belt noise, the Chattanooga Toyota dealer told me I needed a new alternator in my 2000 Tundra about 100,000 miles ago. Apparently, they forgot to tell the alternator.
  13. Dec 9, 2021 at 5:50 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    There's a TSB about this...
    Jack McCarthy likes this.
  14. Dec 9, 2021 at 6:01 AM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    Bar of soap > Belt dressing
    kletzenklueffer and Punk1974 like this.
  15. Dec 9, 2021 at 3:31 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Mine was doing the same thing, chirping bird sound that went away after I drove it a bit. I thought it was a pulley gone bad because when I checked the belt it looked great. There were no signs of cracking or anything. Pulled it off and the tensioner worked well, spun the pulleys and they sounded good. Put a New OEM Toyota Dayco belt on it and it fixed it completely. Real head scratcher. I am an OEM who-uh like many others on this forum, but wish I would have got a different belt. I was looking for the gator back, and didn't know about the continental deal. Bando makes a really good belt as well that can be had for dirt cheap on rock auto.
  16. Dec 9, 2021 at 3:43 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Belt is cheaper than pullys or an alternator.
  17. Dec 16, 2021 at 10:13 AM
    I went through 3 OEM belts under regular and extended warranty. OEM is just a temporary fix. The right aftermarket is the one you want.
  18. Dec 16, 2021 at 5:50 PM
    I actually need to replace mine soon. Curious your thoughts on this topic.
  19. Dec 16, 2021 at 5:58 PM
    I would just go with everyone's recommendation on the Continental Elite belt which is supposedly a rebranded Gatorback belt. I haven't tried it myself but I can let you know when I do.
    shifty`[QUOTED] likes this.
  20. Dec 16, 2021 at 11:29 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Inspect tensioner pulley, is it spinning? If not then it’s seized and will make the serpentine belt squeal.
  21. Dec 17, 2021 at 8:29 PM
    fighthedude
    Got a call from the mechanic. Just the belt! Also said brakes were good and put new boots on upper ball joints! Back in business.
    bmf4069, Jack McCarthy and Aerindel like this.
  22. Dec 17, 2021 at 9:48 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    A lot of em squeal till they get warmed up, lol
    fighthedude[OP] likes this.
  23. Dec 17, 2021 at 9:52 PM
    fighthedude
    Agreed. Its been colder here and thats how it started. However last week it never stopped. Wanted to get it addressed incase it was something more. I would have rather done it myself but two small kids and endless mandatory at work prevented that. Thanks for everyone input. I also got an automotive stethoscope out of it. Cheers
    gosolo[QUOTED] likes this.
  24. Dec 17, 2021 at 10:03 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’m completely sympathetic with your situation my friend. Very glad you got it figured out and resolved. My apologies for my comment which was actually intended to be a little bit humorous with some light innuendo.
  25. Dec 17, 2021 at 11:05 PM
    fighthedude
    Now I see. I wasnt paying attention. No apologies needed. Cheers
  26. Dec 18, 2021 at 1:04 PM
    Fyi...if you got the OEM belt, don't be surprised if it happens 30k-40k miles from now. You can change it yourself in about 5 minutes though.
  27. Dec 18, 2021 at 5:53 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Gates has a pully, tensioner and belt kit for like $80 on RockAuto. They are easy to replace, so I went Gates (made in Mexico) over OEM.
  28. Dec 30, 2021 at 1:36 PM
    nickrick78
    nickrick78 New Member
    Pittsburgh PA
    2004 DC
    Replace the belt, and spin all the pulleys while the belt is off and check for bearing noise/wobble.
