General Supercharger Thread
  1. Dec 8, 2021 at 9:16 PM
    #1021
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    What's the definition of no lugging ? Planning a long trip with a camper next year, and I know for a good stretch 91 is going to be hard to come by, camper will probably be 5k loaded.
  2. Dec 9, 2021 at 3:22 AM
    #1022
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I'll try this one..
    low rpm's with high load.
    don't be in 6th with a high load
    mustang67408 and snivilous[OP] like this.
  3. Dec 9, 2021 at 4:18 AM
    #1023
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    2019 platinum 4x4 magnetic gray
    I feel that all of @snivilous comments are spot on with my less quality fuel issue that I have noticed. When I would try WOT, it would cut out at the high speed. At first I just thought my foot slipped off the pedal. But after more fill ups of same gas, the pinging knocking started showing up at lower acceleration speeds.
    I bought some octane booster in my last fill up and added it to the same gas I was buying and it took about 100 miles before noticing all of the knocking go away.
  4. Dec 9, 2021 at 4:22 AM
    #1024
    nobodyintexas
    nobodyintexas What?
    South of Houston
    pardon if we covered this in the past:
    have you tried to tune it to this socialist grade of gas?
  5. Dec 9, 2021 at 4:25 AM
    #1025
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    I haven’t yet tuned my truck yet. It’s in the plan!
  6. Dec 9, 2021 at 4:26 AM
    #1026
    nobodyintexas
    nobodyintexas What?
    South of Houston
    once their thing-a-ma-jig comes in,
    I have asked D3 Performance to make me 3 tunes. 87, 91 & 93 octane tunes.
    exactly in line with what @snivilous said. to detune the engine in emergency cases when I have to run lower octane.
    I'll probably never use the other tunes, but I will have them.
    Saltyhero13 and Platinum714 like this.
  7. Dec 9, 2021 at 4:29 AM
    #1027
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Ah!
    then I know EXACTLY what you are experiencing.
    yes, the motor is hamstringing you. for safety.
    now imagine...breathe deep...a tune that will harden up the go pedal and correct the timing pulls.....breathe out.
  8. Dec 9, 2021 at 4:36 AM
    #1028
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    I am waiting for successful tuning from another local tundra owner @vq35721!
  9. Dec 9, 2021 at 4:52 AM
    #1029
    nobodyintexas
    nobodyintexas What?
    South of Houston
    not a day passes that I am not grateful that I have awesome shops near me. D3, Prospeed, Pietz
    to have your truck dialed in on a dyno a la carte' is the bee's knees.
    if you have to do it remotely choose a seasoned pro.
    my truck had a BUNCH of nuances that needed to be dialed in - mainly the larger fuel injectors.
  10. Dec 9, 2021 at 5:23 AM
    #1030
    nobodyintexas
    nobodyintexas What?
    South of Houston
    pure gangster. We will have to pressure Chris to the tundra model.
  11. Dec 9, 2021 at 5:35 AM
    #1031
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Since it’s what this thread is all about, I’d just like to say I love my Harrop supercharger even as a stage 1. Aside from the ludicrous acceleration of a 5500+ lb truck, highway driving is so much improved over stock. Highways in eastern PA aren’t flat, lots of grades on most of them. On a few recent highway trips I’ve enjoyed how I can just set my cruise at 70-75 and when I hit the hills the truck just holds my set speed like a honeybadger and doesn’t have to come out of top gear. It’s fun watching the boost gauge when I hit the the hills go from a vacuum to 0psi, and it almost never has to get into any more boost than that and it’s happy holding my speed. And the difference when pulling my travel trailer is also night and day. This stage 2 upgrade is gonna be amazing, a whole additional 50 to 70hp! Hard to imagine. Best Mod I’ve ever done on any vehicle I’ve owned.
  12. Dec 9, 2021 at 6:31 AM
    #1032
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Forced induction is awesome. My wife’s twin-charged XC90 with a 2 liter engine just chugs along and almost never downshifts on grades even at 80 mph.
    Saltyhero13 and Silver17 like this.
  13. Dec 9, 2021 at 6:34 AM
    #1033
    snivilous
    SW UT
    300k+ Supercharged 2008
    What @nobodyintexas said is what I'm referring to, keeping it in a high gear at lower rpm. If you watch your timing advance, as the engine loads up it'll retard the timing (like when you go WOT and it drops to like 15deg of advance). In my experience the engine will retard timing as load goes up and as boost increases. For example I can climb a hill near my house in 6th and timing will drop into the teens and it'll add in a couple psi of boost (just holding speed with cruise control) or I can prematurely downshift to 5th, and then it will never touch boost but be at a higher rpm with less engine load and running like high 20s for advance.
    So the engine is capable of pulling the truck at the speed you want in both gears, but a lower gear means the engine isn't working as hard. Same logic as regearing, you spin a higher rpm but that's not a bad thing because the engine is fine at higher rpm and it's happier because it's not working as hard. Personally, if I see the truck has to use more than 2psi (which is exactly what @Silver17 is saying above) then I usually downshift even if the truck hasn't yet just since I get paranoid of the engine running for a long time in boost and downshifting and adding 500rpm will make it not need any boost and now have excess power instantly on tap.
    I'm probably talking in circles now and this post is getting long, so hopefully that clears anything up. The take away should be, lower gears and higher rpm means less engine load which means less likelihood of knock. Don't be afraid to rev the engine out.
  14. Dec 9, 2021 at 6:42 AM
    #1034
    Downytide
    GTA
    makes sense, this will be my first s/c vehicle, while most of them were turbos, where most knock happen at high gear low rpm full boost pulls, glad to know that can avoid going into boost even on the roots.
  15. Dec 9, 2021 at 6:48 AM
    #1035
    Silver17
    Eastern PA
    Is this you!? I was listening to some TRD dual exhaust clips on YouTube, I picked up a used system for mine (I’ve had it once before too). If it’s your truck, that sounds amazing with those headers. I take it the headers are responsible for that glorious sound. So are those long tubes with cats built in? I’ve only had the trd duals on a NA truck before so I’m excited to see how the sounds changes being supercharged. The trd system isn’t the loudest but the tone is just perfect. https://m.youtube.com/watch?v=IQ8odt8on7M
  16. Dec 9, 2021 at 7:02 AM
    #1036
    Downytide
    GTA
    Yes sir, that's mine.
    In that clip, its just stainless works headers with aftermarket cats connect to stock TRD exhaust, so it remain true dual from headers to tail, it sounds great, but two things the video does not convey is how loud and stinky it is, at idle the smell is unbearable if you have windows open, and at 3500rpm its impossible to hear any conversation inside the cabin, in cold start it'll set off car alarms next to me.
    You can see how it was mounted up to stock rear section, note the 3"-2.5" step down on the connectors
    I've since then had custom mid pipes made with OEM cats made and custom x pipe, now it sounds like a stock AMG v8 at low idle, at full throttle it roars, also using v-bands through out.
    Silver17[QUOTED] likes this.
  17. Dec 9, 2021 at 7:13 AM
    #1037
    Silver17
    Eastern PA
    That’s awesome. I’d love to hear how it sounds with your new setup. I will say that your previous setup as shown in the video is the best sounding tundra I’ve ever heard right alongside the Harrop supercharged Kanoo Racing tundra with ARH headers and their custom exhaust. The TRD duals apparently sound a lot louder and better without the cats, its unfortunate it gets unbearably stinky without them.
  18. Dec 9, 2021 at 7:23 AM
    #1038
    Downytide
    GTA
    Keep in mind that I ask a lot in terms of comfort/compliance on this vehicle, I also had an issue with CEL, I couldn't disable it no matter what I tried, tried to make 4 different foulers, etc and none would disable the CELs, it was not until I put stock cats back on it was gone, but this was before 2020+ ecus were cracked, I've heard on pre 19 trucks its easier to fool the o2 sensors.
    If you can live with volume, I'd say go for it, it sounded like a dohc nascar at wot.
    Silver17 likes this.
  19. Dec 9, 2021 at 7:38 AM
    #1039
    Silver17
    Eastern PA
    Yes if I ever went longtubes I’d have to disable the O2 sensor codes through the tune. But like you said, I’m not sure I want to deal with the nauseating smell without the cats. The most id do to try and improve the sound would be remove the rear cats and leave the front ones. I’m hoping the addition of the supercharger increases the aggressiveness of the trd duals enough that I will be satisfied.
  20. Dec 9, 2021 at 9:20 AM
    #1040
    Saltyhero13
    Saltyhero13 Throbbing Member
    Sad panda for me. Looks like LTH are off the menu. Moving could solve my problem.
  21. Dec 9, 2021 at 11:17 AM
    #1041
    nobodyintexas
    nobodyintexas What?
    South of Houston
    how are y'all monitoring boost?
  22. Dec 9, 2021 at 11:41 AM
    #1042
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    snivilous[OP] likes this.
  23. Dec 9, 2021 at 11:47 AM
    #1043
    nobodyintexas
    nobodyintexas What?
    South of Houston
  24. Dec 9, 2021 at 12:33 PM
    #1044
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
  25. Dec 9, 2021 at 1:10 PM
    #1045
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    I’m still waiting for my CARB Legal sticker from Harrop so I can smog her lol. Once that’s done, it’s gonna go down lol LT, injectors and smaller pulley. I have 2 yrs to worry about the smog haha
    Platinum714[QUOTED] likes this.
  26. Dec 9, 2021 at 1:15 PM
    #1046
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Weird you mention that because, when I was at the install shop yesterday they gave me all the stickers that came with mine but they insisted on keeping that sticker. Must be some sort of liability if they don't hang on to it? Guess I don't understand who needs the sticker for what, since I don't live in Cali...Maybe Colorado has similar regulations I didn't know about.
  27. Dec 9, 2021 at 2:17 PM
    #1047
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Oh wow, yah that’s kinda weird.. it might’ve been CO law? Here in Cali, lot of folks are just too paranoid that they might be doing something illegal lol
    boostedtrdpro[QUOTED] likes this.
  28. Dec 9, 2021 at 2:42 PM
    #1048
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'm intrigued by these restrictive laws.
  29. Dec 9, 2021 at 3:13 PM
    #1049
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Oh BTW, our kit didn’t come with the CARB stickers lol
  30. Dec 9, 2021 at 4:37 PM
    #1050
    Silver17
    Eastern PA
    My kit didn’t come with the carb sticker either. I forgot about that too. I should ask Harrop about getting one. My kit also didn’t come with a minimum octane sticker, I ordered one of those off Amazon.
