2006 V8 Headers/Exhaust dyno
Discussion in '1st Gen Tundras (2000-2006)' started by Riverdale21, Dec 8, 2021.
  1. Dec 8, 2021 at 2:03 PM
    Riverdale21
    Riverdale21 [OP] Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Those of you have been following my threads know I've designed my modifications to increase low end torque and a quiet exhaust. Today is the dyno after some basic mods anybody can perform. Headers, air filter, injectors, and exhaust.
    The headers that are installed are no longer available. Stan, who built these headers, has retired. That being said, my dyno numbers may not be 100% repeatable. All of this was done to be informational. To help others gauge whether bolt-ons are worth the budget. You will see respectable gains using JBA or Dirty Deeds 4-1 long tube headers. You will certainly see bigger gains at the top end using 4-1 headers. I'd love if other members with shorty headers or 4-1's can get to a dyno near them.
    Looking at the dyno chart you can see I've reached my goals. Emphasizing low end torque using try-Y headers, a 2.5" single exhaust, and not much else. Peak increase of 5HP/6TQ is kind of weak for the cost of entry, but where we do most of our driving is the low end. Below 4,000 RPM you can see there are increases of almost 20HP/30TQ. This is where it counts. The truck is so much nicer to drive now, even at part throttle.
    Today's dyno pull mods: (red HP/TQ lines)
    Ambient temp 56*F, at 788ft above sea level in NW Georgia. 0 dyno correction factor.
    Stan's Tri-Y headers (no longer available)
    Dirty Deeds 12 hole injectors
    AEM drop in dry air filter
    2 x 2.5" high flow cats
    Custom y-pipe
    2.5" x 10" Borla resonator
    2.5" x 14" Borla sport muffler
    October 19th dyno pull: (blue HP/TQ lines)
    Ambient temp 72*F, same dyno at 788ft above sea level. 0 dyno correction factor.
    Previous threads:
    00-04 header install onto 05-06 motor
    https://www.tundras.com/threads/how-to-00-04-headers-onto-05-06-motor.97796/
    Base-line dyno
    https://www.tundras.com/threads/06-baseline-dyno-done.96901/
  2. Dec 8, 2021 at 2:36 PM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    i clicked on yer base line dyno link and see you put in some dirty deed injecters on. i’m planning on getting a early gen and wonder how these add to to your truck?? might get them if its worth it. some say it is and others are skeptical..
  3. Dec 8, 2021 at 2:43 PM
    Riverdale21
    OTP ATL
    I didn't put them in expecting the moon but it did help with fuel mileage. Averaging about 15 city and 19 highway. My mileage has been going down since the headers and exhaust, hard to keep your foot out of it when it sounds so nice screaming. Don't know how much power that mod alone gave but the truck felt smoother running and seemed to help partial throttle driving.
    TRDGen likes this.
  4. Dec 8, 2021 at 2:46 PM
    Riverdale21
    OTP ATL
  5. Dec 8, 2021 at 2:48 PM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    Punk1974 likes this.
  6. Dec 8, 2021 at 3:15 PM
    Punk1974
    J.P.
    thanks that is what i’ve read a smoother engine and better gas miles but some say gas miles stays equal but a different shift point on transmission feel. also read oside injectors sells them. this toy tech guy lord dan on hear says you can grab some off a coroola.
    vids not loaded?.
  7. Dec 8, 2021 at 3:45 PM
    SeanL
    SeanL New Member
    2002 Supercharged Beauty
    I've gots a supercharged Truck and have always wanted to do a Dyno test on it to actual see if the supercharger adds any hp. I did some personal 0-60mph drags and averaged about 8seconds which according to google was the 0-60mph times of stock NA trucks. :3
    Riverdale21[OP] and Punk1974 like this.
  8. Dec 8, 2021 at 3:51 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    They're loaded but either need to be unlocked (default setting is private) or they're on the hold (youtube has a setting that holds videos for 24 hours before making viewable).
    When you see manufacturers claims about adding horsepower, if you watch the detail they never say "adds 20 peak horsies". They say "adds 20 horsies" and that can be anywhere along the band. Roughly a 10% gain in low range is great.
  9. Dec 8, 2021 at 4:17 PM
    Riverdale21
    OTP ATL
    New to the whole Youtube thing. I've made the videos public so they should be viewable now.
    dinosaur and Darkness[QUOTED] like this.
  10. Dec 8, 2021 at 4:18 PM
    Riverdale21
    OTP ATL
    Made public on youtube. Try it now, let me know if there are any issues. I'm not very youtube savvy.
    dinosaur[QUOTED], SeanL and Punk1974 like this.
  11. Dec 8, 2021 at 4:57 PM
    I'm confused I don't see any green lines.
    Do we know if injectors alone really helped?
  12. Dec 8, 2021 at 5:05 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    They cant hook up a tach to the dyno? I guess 5252 rpm is @ 84 mph. Pretty impressive. How many $$ per hp/lb.ft.?
    ColoradoTJ likes this.
  13. Dec 8, 2021 at 5:32 PM
    Riverdale21
    OTP ATL
    My bad. Edited post to say blue line.
    Don't know how much of a power improvement the injectors did, they were installed prior to the base dyno.
    FirstGenVol[QUOTED] and Darkness like this.
  14. Dec 8, 2021 at 5:35 PM
    Riverdale21
    OTP ATL
    Too much. Hahaha. Injectors, Hewitt Gen 1, air filter, headers, cats and exhaust... about $112 per tq and $166 per hp.
    dinosaur and Darkness like this.
  15. Dec 8, 2021 at 5:41 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    No problem at all. That exhaust sounds wicked on the first video.
  16. Dec 8, 2021 at 5:42 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    I've also seen graphs from manufacturers where the x axis begins at 4000 rpm and the curve looks great and their claims are amazing. But I never drive at those rpms. Why do they hide the 1200-3500 where these trucks do most of their bidness?
    dinosaur and Punk1974 like this.
  17. Dec 8, 2021 at 5:56 PM
    Riverdale21
    OTP ATL
    Thank you. I'm happy with how it turned out after the resonator was installed. When the engine is loaded or if you romp the throttle it gets a nice aggressive roar at a tolerable volume. Normal cruising it's as quiet as the stock exhaust.
    Darkness[QUOTED] likes this.
  18. Dec 8, 2021 at 6:20 PM
  19. Dec 8, 2021 at 6:42 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    its hard to get a slushbox to hold 3rd way down there. Id like to know what a dyno says im putting down when im holding the pedal as much as i can before it downshifts.
  20. Dec 8, 2021 at 11:10 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the down low gains are totally worth the price of admission. thats the most useable spot power-wise for a truck. 0-60 times are a decent way to gauge gains too. most trucks with the long tubes seem to put a solid 1 second or 1.5 second faster 0-60 time down
  21. Dec 8, 2021 at 11:10 PM
    empty_lord
    05 rollover special
    thats the downside to an automatic.
  22. Dec 9, 2021 at 12:26 AM
    empty_lord
    05 rollover special
    Keith’s daughters truck is around 6 seconds 0-60 with the JBA long tubes, 12 hole, and full exhaust. VF tuner is going to support the 4.7 vvti soon so more power should be doable once that’s out
  23. Dec 9, 2021 at 12:45 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Damn. Nearly 300 to the wheels is impressive and right about what I would expect. Hopefully I can dyno mine once I get everything installed for comparison. You may want to keep an eye out for the VFTuner coming soon for our trucks to push it to or over that 300whp mark
  24. Dec 9, 2021 at 9:39 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Vht and a bug sprayer.
    bmf4069 and FrenchToasty like this.
  25. Dec 9, 2021 at 1:45 PM
    SeanL
    SeanL New Member
    Guess I'm upgrading the exhaust after all. From what I read the biggest upgrade really does seem to be a full exhaust with long toobies. Christmas list it is
  26. Dec 9, 2021 at 5:18 PM
    Riverdale21
    OTP ATL
    The stock manifolds are very restrictive. I'd be interested in seeing how even a shorty performs. Our exhausts are relatively free flowing and of a decent diameter stock. Not many ponies to be gained by a y-pipe and/or cat-back, just sound change.
    If you just go with 4-1 headers Dirty Deeds does offer a bolt on solution. You can't modify your stock cats to mate to their long tubes but they sell a reasonably priced set of catted mid pipes to bolt to their headers and connect to the factory exhaust.
    dinosaur and SeanL[QUOTED] like this.
  27. Dec 9, 2021 at 6:24 PM
    Riverdale21
    OTP ATL
    Only down side to headers on these engines is the increase in valve noise. I don't know if anybody has mentioned this in the forum. These motors are almost as noisy as an LS with headers. It's been about 15 years since I had an engine with long tubes on it, I had forgotten.
    The thick factory manifold and heat shield really helped quiet that down. With the thin wall stainless headers you can hear a valve tick noise under load. But for the power increase I can ignore the occasional tapping.
    TRDGen likes this.
  28. Dec 9, 2021 at 10:51 PM
    empty_lord
    05 rollover special
    yea thats unavoidable with the valve train design of our engines. the 3.4l is VERY ticky with headers since the stock crossover is dual wall. the headers are.. uh. it sounds loud lol
  29. Dec 10, 2021 at 5:24 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Interesting thread. I have been slowly getting things done on my truck and I have the 12 hole injectors. They don't really add power but make the truck run and drive better plus you get a small increase in mpg, worth the money and install time. From what I understand, the shorty headers don't really give any performance gains but do sound good. Long tubes are the way to go and either eliminate the cats or go with a high flow performance cat. Dirty Deeds full exhaust with long tubes is on my list and I should be able to seriously make that happen this summer.
    bmf4069 and Punk1974 like this.
  30. Dec 12, 2021 at 8:45 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    You ever seen anyone take a 3.4 and instead of routing the the crossover pipe behind the block, do it under the vehicle?
