How to: 00-04 headers onto 05-06 motor
Discussion in '1st Gen Tundras (2000-2006)' started by Riverdale21, Nov 6, 2021.
  1. Nov 10, 2021 at 4:03 AM
    bmf4069 Captain wtf
    I stand corrected. :hattip:
  2. Nov 10, 2021 at 4:49 AM
    Riverdale21
    Riverdale21 [OP] Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    I've seen it but it never clicked, but yeah. Dirty Deeds does use x-pipes.
  3. Nov 10, 2021 at 4:58 AM
    Filthy Feats Fab did a great job on my exhaust, hours of research, engineering and experience went into the build, high and tight and sounds great!
  4. Nov 10, 2021 at 5:05 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Plus it's black! :cheers:
  5. Nov 10, 2021 at 7:52 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    Cool thread. You guys really know your stuff. I think I’ll stick with and earlier gen tunny without the willy wonka air systems if I can find one. I read those dirty deeds 12 hole injectors with jba short headers is a good combo for added hp.
    Tundra2 and FrenchToasty like this.
  6. Nov 10, 2021 at 10:24 AM
    Riverdale21
    OTP ATL
    I've got their 12 hole injectors and was happy with those on the stock motor. Should really help out with the headers and full exhaust.
    Original plan was JBA shorties, stock cats, and bolt on cat back. But the opportunity for the tri-Y headers came up. Now I've spent double my original budget. Hahaha
    TRDGen and FrenchToasty like this.
  7. Nov 10, 2021 at 10:27 AM
    Riverdale21
    OTP ATL
    The 00-04 Tundra may not have the smog crap but it also doesn't have VVTi. Almost 50 horse difference between the two engines.
    Darkness and FrenchToasty like this.
  8. Nov 10, 2021 at 11:01 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Black paint is worth 100 horses. :cool:
  9. Nov 14, 2021 at 6:43 AM
    Riverdale21
    OTP ATL
    Just a quick update on the exhaust. The Magnaflow didn't have a center o2 bung so I would have had to get an extension harness. Here is my exhaust parts list as-is:
    Cats: (qty 2) p/n 495200 (2.5"ID in/out)
    Muffler: (qty 1) Borla ProXS 40351 (2.5"ID in/out)
    I've mimicked the stock exhaust just with higher flowing components and a stealthy black tip.
    The sound is a bit louder than I was hoping. Waiting for a Borla 400938 resonator to arrive to be installed. Right now the truck sounds like a Coyote Mustang with a cat back installed. Want the deep sound under throttle but want to cut down on the raspy tones. Hoping this does the trick.
    Also hoping to find the time to remove the last of the SAIS piping and install the Hewitt block off plates sometime soon. This truck isn't my daily, more of a special occasion vehicle. I've only put about 40-50 miles on it since the header/exhaust install.
    bmf4069, TRDGen and Darkness like this.
  10. Nov 14, 2021 at 1:44 PM
    Riverdale21
    OTP ATL
    Alright, finally took the time to install the Hewitt block off plates in the correct location. Took me maybe 45 minutes with a little bit of hand yoga, magnet, 1/4" extensions, and a wobbly extension. As discussed earlier in this thread the 00-04 headers don't have the SAIS tube. So my SAIS pump outlet piping has just been hanging out in open air. If this were my daily driver I would be more concerned but I only drive it maybe 2 times a week.
    Pictured below is the SAIS piping just hanging out, open to the atmosphere.
    You can see with a couple 1/4" extensions with my 10mm socket I was able to reach the SAIS output piping from either above or below. Pictured is driver's side from above.
    Removing the SAIS outlet piping from both sides you can see the block off plates can be installed on either end. Luckily the flange is the same shape/size on the manifold and pump sides. Also shown is where the Hewitt plates would be installed on the stock manifolds. The last photo shows me holding the block off plate to the pump side of the SAIS piping.
    There's a significant harness in the way on the driver's side but I was still able to get both upper and lower bolts started by reaching my mitts in there. Threaded them in just close enough to install the Hewitt plate then ran the bolts home with the 1/4" socket wrench. The SAIS pumps are aluminum so don't over torque the bolts where you strip the pump threads. Oh, and the Hewitt plates are aluminum so if you drop one you can't fish it out with a magnet. Here you see the driver's side complete from above, then the passenger side complete from below.
    This concludes the 00-04 header install onto 05-06 motor. I will update in a few months or as issues arise with the reliability of the SAIS port plugs on the heads. I checked them today and everything still seems to be in ship-shape. The suppressor thread lock seems to be holding up so far.
  11. Dec 7, 2021 at 6:52 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    What happened from the headers back?
    Jack McCarthy and bmf4069 like this.
  12. Dec 7, 2021 at 11:40 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i shall be installing the JBA headers soon... the 19th i should have them. may toss them on that same weekend. but then i'll be open headers for a bit while i get exhaust pipe...
    solid offroad motor mounts coming and JBA long tubes + Hewitt bypass..
    debating on stage 8 locking fasteners
    dinosaur, bmf4069 and TRDGen like this.
  13. Dec 8, 2021 at 2:45 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I can't wait for mine to show up
    dinosaur likes this.
  14. Dec 8, 2021 at 2:53 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    I thought the block off plates weren't necessary of you got the headers without the sais pipes. Hmm I guess I wasted my money on the sais disabler thing since I did t get one with plates. I guess I'll have to buy the Hewette plug n play. Serves me right for going cheap. But it'll be piece of mind since mines one that requires splicing.
  15. Dec 8, 2021 at 2:56 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    I e been wanting to upgrade my motor mounts. Hell I still need to have my spindle gussets welded on though among other things lol like my 1 inch body lift and snorkel
  16. Dec 8, 2021 at 11:30 AM
    Riverdale21
    OTP ATL
    I listed the part numbers for everything somewhere in the thread. Pretty much dual 2.5" cats, y-pipe, 2.5" x 10" borla resonator, and 2.5" Borla muffler.
    Got the return dyno in an hour to update how much power everything made. Will make a new thread for that.
  17. Dec 8, 2021 at 11:33 AM
    Riverdale21
    OTP ATL
    I don't think the plates are necessary when you install 04-05 headers without the pipes. Mostly put them on to clean up the engine bay and prevent too much moisture from making it's way into the disabled SAIS pumps. Don't know if it would cause any issues, especially with the system disabled, but I also didn't want to find out.
    TRDGen[QUOTED] likes this.
  18. Dec 8, 2021 at 12:15 PM
    I would imagine the high temp black paint on the exhaust helps keep if from rusting on the outside as well. I wish I did that years back.
    dinosaur, Darkness and FrenchToasty like this.
  19. Dec 8, 2021 at 12:16 PM
    Makes it faster too
  20. Dec 8, 2021 at 12:21 PM
    #50
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Weagle, bmf4069, dinosaur and 2 others like this.
  21. Dec 8, 2021 at 12:21 PM
    #51
    empty_lord
    05 rollover special
    Who made the x pipe. Is it a custom one?
  22. Dec 8, 2021 at 12:45 PM
    #52
    Darkness likes this.
  23. Dec 8, 2021 at 2:28 PM
    #53
    empty_lord
    05 rollover special
    Damn. No one make those style in stainless and it bugs me. I’m ordering 300 series for the exhaust.
  24. Dec 8, 2021 at 2:56 PM
    #54
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    #54
  25. Dec 8, 2021 at 3:05 PM
    #55
    #55
    des2mtn and dinosaur[QUOTED] like this.
  26. Dec 9, 2021 at 6:26 PM
    #56
    Riverdale21
    OTP ATL
    Update: lots of heavy foot driving, about 600 miles, and 3 dyno pulls later... the SAIS plugs and high temp sealant are still holding up just fine.
    Weagle, Darkness and Punk1974 like this.
  27. Apr 26, 2024 at 9:23 AM
    #57
    Riverdale21
    OTP ATL
    Update: 3 years in and the hot lock is still holding the SAIS plugs leak free.
    Been chasing an irritating ticking noise and found an exhaust leak at the passenger side collector flange and one at the 2nd Y on the driver's side header.
    For leak repairs I'm going to cheap out and put some JB weld on the leaking Y. And going to go to the exhaust shop to get the ball and socket flanges changed out with either V band or standard 3 bolt gasketed flange.
    Still happy with the added torque from these headers even after all this time. Ordered a VF Tuning programmer with their canned tune package for the 05-06 Tundra 2UZFE N/A. I'll dyno test their 91/93 tune in a separate post. Now that I found some engine management, later on this year will be Kelford Cams 251/251 stock spring drop in bump sticks.
  28. Apr 26, 2024 at 9:28 AM
    #58
    After doing long tube, and now gears, gears are a way better power upgrade
  29. Apr 26, 2024 at 10:06 AM
    #59
    Riverdale21
    OTP ATL
    I've gotten a quote for some mild 4.30:1 gears for my LSD. Math says I'd be happier on long trips with that vs a 4.56:1.
    My (very distant future) eventual goal is supercharging so I'm still on the fence about re-gear. I still want some amount of traction. Although, I suppose I can do the gears and if it proves too much with the supercharger I can find a stock 3.92:1 or 4.10:1 third member.
  30. Apr 26, 2024 at 10:09 AM
    #60
    Riverdale21
    OTP ATL
    At any rate I want to dyno the Orange Virus/VF Tuner on the same gears I had the other dyno runs.
