Omg check your cabin air filter
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sonicbluerider, Jun 14, 2021.
  1. Dec 7, 2021 at 6:31 PM
    #61
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I used this one last time, pretty nice quality, and grabbed all the Turds. :thumbsup:
  2. Dec 12, 2021 at 11:48 AM
    #62
    paleot11
    paleot11 New Member
    Tony
    2015 Toyota tundra 1794
    none
    Happened to mine after hurricane Laura wasn't mice it was RATS!!!! big RATS!
    hANNAbONE and worktruckwhite like this.
  3. Dec 12, 2021 at 12:29 PM
    #63
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Honestly so regret my K&N. It’s kind of a pain to wash and oil. One of the days I might go back to disposable.
    https://www.mishimoto.com/engineering/2016/11/filtering-right-stuff-dry-vs-oiled-air-filters/
    BrunoTheRescuePup likes this.
  4. Dec 12, 2021 at 12:35 PM
    #64
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did it decrease your airflow?
    Some Amazon reviewers are bitching about deceased airflow.
    If you're happy with it, I'm buying one..
  5. Dec 12, 2021 at 12:44 PM
    #65
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I change mine annually, usually with Fram whatever major brand I can get off Amazon
  6. Dec 12, 2021 at 8:21 PM
    #66
    TILLY
    Massachusetts
    I didn't notice any difference, would definitely buy again. :thumbsup:
    1lowlife[QUOTED] likes this.
  7. Dec 12, 2021 at 10:00 PM
    #67
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Can you confirm this hole goes inside the truck cabin on driver side?
    I have a water leak during heavy rains on driver side that nobody can find the source.
  8. Dec 12, 2021 at 10:18 PM
    #68
    TILLY
    Massachusetts
    I have never had any problems with water leaks so not sure if this helps you or not. Pretty sure the new inlet I found goes directly into the cab at some point since I found some droppings around that area. Since I blocked it off a week or so ago, still no signs of them getting in. Hope this helps a little.
  9. Dec 26, 2021 at 3:02 PM
    #69
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    Decided to check my cabin filter today since the Carfax has no record of it being changed in the first 88,000 miles. Discovered something I had never seen before and didn't realize existed... a K&N washable and reusable cabin filter was installed!
    I used compressed air to blow out a few bugs and debris and reinstalled it. I guess I'll never actually have to buy one of those.
    hANNAbONE likes this.
  10. Dec 30, 2021 at 3:22 PM
    #70
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    This is a super stupid question….which way is the cabin filter arrow supposed to face? Up toward the roof or down to the floor?
  11. Dec 30, 2021 at 3:44 PM
    #71
    TILLY
    Massachusetts
    Not stupid at all, flow is from top to bottom, arrow points down.
    LS3, toyofan87, KingsAustin and 2 others like this.
  12. Dec 30, 2021 at 3:45 PM
    #72
    PKFan
    2018 Inferno! DC SR5 4x4
    This is an oft discussed issue. Some aftermarket filters indicate direction of air flow (top to bottom), while the factory filter indicates orientation ("up"). I'm not sure it matters all that much, though.
    toyofan87 and TILLY like this.
  13. Dec 30, 2021 at 3:52 PM
    #73
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I bought one of these.
    It's sitting one my workbench still waiting to get my truck back from the dealership.
    45 days and counting...:eek2::thumbsup:
    TILLY[QUOTED] likes this.
  14. Dec 30, 2021 at 3:55 PM
    #74
    TILLY
    Massachusetts
  15. Jan 1, 2022 at 8:50 AM
    #75
    hANNAbONE
    hANNAbONE T U N D R A M A
    Des Moines / Dull Moan, Iowa
    still lookin' for my first one
    I always leave my vehicle with the "recirculate" button pushed on - that way the vent is closed...no intruders
    LS3 likes this.
  16. Jan 1, 2022 at 8:54 AM
    #76
    hANNAbONE
    You can buy little wood shaved pouches of PEPPERMINT enhanced and throw these in the engine bay, under seats etc. They hate Peppermint smell.
    You can then buy a bottle from LorAnn Oils and revive the shavings 1 time a month for repeated help. It works the charm. Get the pouches from Rural King or Tractor Supply or the like
  17. Jan 1, 2022 at 10:28 AM
    #77
    Randy Morton
    Randy
    Deepinahearta, Texas
    I keep mine in recirculate also. It didn't help. I had to take out the fan motor to get all of the nesting material out of the fan. The little rodent had chewed up the filter and drug in leafs and twigs to make his nest. Now I use this:
  18. Jan 1, 2022 at 12:59 PM
    #78
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    I bought a K&N cabin filter. I had a OEM one and was barely getting any air flow I put this in made a huge difference in air flow especially now that it is -35c
    Darkness and Randy Morton like this.
  19. Jan 1, 2022 at 1:28 PM
    #79
    Mr Badwrench
    Mr Badwrench New Member
    I should probably go check mine. My vents are weak as far as air flow, so I can only imagine what I am about to walk in on.
  20. Jan 3, 2022 at 2:31 PM
    #80
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Driver side view. A small ish square hole that DOES make its easy back behind the dash. Also, on both pax and driver side there’s a small hole. Likely not big enough for a mouse, but why take chances. Silicone the hell out of everything. Lol
    KingsAustin likes this.
  21. Jan 3, 2022 at 7:26 PM
    #81
    ZPhilip
    Philip
    West Chester, PA
    Thanks for replying. I sealed up this and other non-critical holes with some stuff I had in stock, and meshed over the large air intake hole for any future rodents.
    C0852BB1-7082-4846-83DB-718964DD98A3.jpg 043E6F92-B12D-4F4C-BEBF-43C7B1393993.jpg
    Tundra805 likes this.
  22. Jan 3, 2022 at 10:31 PM
    #82
    Dirtytruck
    Dirtytruck Overkill it
    2021 SR5
    I change both the engine and cabin af’s at every oil change (5000 miles). I do a lot of dirt road dusty driving.
    Like the guy said earlier mice can go through any opening they can get their heads through. Try spray foam in areas that don’t need to be open like the cabin air intake.
    Another option if you’re comfortable and able is to keep the hood cracked open and the interior of the engine bay illuminated with a led light set up when the truck is parked. They avoid well lit areas. If you trap them try peanut butter. It’s worked very well for me in the past.
    Eliminating them on their way to your truck makes sense too.
  23. Feb 1, 2022 at 6:50 AM
    #83
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Anyone have instructions on how to remove the plastic cowl? Need to seal up these holes on my truck.
  24. Feb 1, 2022 at 8:06 AM
    #84
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    I have been using these in the CR-V for 7 years and just put one in the Tundra. For the price and replacing every 6 months or so, I think they work just fine.
  25. Feb 1, 2022 at 8:46 AM
    #85
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You need to remove the wiper blades, which i beleive are 14mm nuts, then there are 2 pop clips on the sides of the cowl where it meets the metal body. There are also 4 plastic clips under the cowl along the length of it that are annoying to remove and easy to break. it should pop out after that pretty easily.
    1lowlife likes this.
  26. Feb 9, 2022 at 7:11 AM
    #86
    raspy87
    raspy87 New Member
    Andrew
    RI
    ‘19 DC SR5 Cement
    after they break? awesome I’m great at that. Lmao
    Kung likes this.
  27. Feb 9, 2022 at 7:11 AM
    #87
    MadMaxCanon
    Apparently I am too. Broke every last one of em.
  28. Feb 9, 2022 at 7:14 AM
    #88
    raspy87
    raspy87 New Member
    Andrew
    RI
    ‘19 DC SR5 Cement
    I’m at the dealership now should I just grab a bag? :spending:
  29. Feb 9, 2022 at 7:20 AM
    #89
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  30. Feb 9, 2022 at 7:25 AM
    #90
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    i can't imagine having dead mice in your cabin air supply has an appealing scent :oops:
