Replacing Steering Wheel On My 2016 Tundra
Discussion in 'General Tundra Discussion' started by nk1794, Feb 18, 2018.
  1. Feb 18, 2018 at 7:41 PM
    nk1794
    nk1794 [OP] Always torque to spec
    San Jose, CA
    2TONYJ, Pat, anthonygan and 7 others like this.
  2. Feb 18, 2018 at 7:50 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    Should definitely be added to mods and tutorials
    nk1794[OP] likes this.
  3. Feb 18, 2018 at 8:11 PM
    epa4wd
    epa4wd New Member
    Ed
    Thanks for posting, going to be useful if I upgrade to a leather steering wheel.
    Y0TA PR0 and nk1794[OP] like this.
  4. Feb 18, 2018 at 8:14 PM
    nk1794
    San Jose, CA
    You are welcome. I'm thinking of getting the old one wrap to match the seat or perhaps a TRD red. I wonder how much some thing like that would cost.
  5. Feb 18, 2018 at 10:54 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Awesome great video!!
  6. Feb 18, 2018 at 10:54 PM
    nk1794
    San Jose, CA
    Thanks
    Y0TA PR0[QUOTED] likes this.
  7. Feb 19, 2018 at 7:03 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Good video! I've wanted a wood wheel since my last vehicle had one, looks like the new Platinum Sequoia wheel would match the trim in my Limited. Curious why did you replace yours?
    nk1794[OP] and Y0TA PR0 like this.
  8. Feb 19, 2018 at 7:17 PM
    nk1794
    San Jose, CA
    Thanks. I took my truck to get it washed and they F'ed up the leather. Let us know how your Sequoia wheel swap goes.
    Y0TA PR0 likes this.
  9. Feb 19, 2018 at 7:47 PM
    Nice video! :thumbsup:
  10. Feb 19, 2018 at 9:10 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Nicely well done, thanks for the video, great to have if i ever need to change mine.
  11. Feb 19, 2018 at 9:20 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    This could really come in hand as the "leather" is starting to wear on the wheel of my '16.
  12. Feb 20, 2018 at 9:47 PM
    nk1794
    San Jose, CA
    There is probably going to be a part II to my how-to video. :) Here is what I'm experiencing. When I was installing the new wheel the other day I noticed that I could not get the wheel to be completely centered like the old one was. The wheel was either slightly off to the left or slightly off to the right. If I centered the wheel it would not slide down the shaft. I thought perhaps I didn't straighten the front wheels properly. I installed the wheel and opted slightly off to the left as it was much closer to the center than going the other way. After driving it for a couple of days I confirmed that it's off to the left. So today I took it apart, marked the current position and moved it 1 click to the right and now guess what? The wheel is now off to the right. The truck drives straight so it's not alignment problem. I think the problem is that the spline on the new wheel is 1 click off-center. Removing and reinstalling the wheel again would not help. I think I need to do a little bit of adjusting at the tie-rod ends. So that's the project for this weekend.
    As a side note. if I were removing and reinstalling the same wheel I would not run into this issue because I would have marked the position of the wheel and the shaft and more importantly the shaft and the wheel were already mated and adjusted from the factory so reinstalling the same wheel would have been a no-brainer. In my case marking the wheel would not have helped since I'm installing a new wheel.
    Any thoughts? If you think I'm way off base please let me know.
    Thanks
  13. Feb 20, 2018 at 9:52 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Added
  14. Nov 10, 2018 at 8:51 PM
    Dudley
    Dudley New Member
    Doyle
    14 Tundra
    What's the easiest way to only change the light bulbs on the steering wheel buttons?
  15. Nov 14, 2019 at 4:17 PM
    robbb38
    robbb38 New Member
    Rob
    18 limited crewmax
    I’m having the same issue after I just installed a new wheel. Did you ever fix the issue?! Thanks.
  16. Nov 14, 2019 at 6:30 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    I know this is older but @nk1794 I did the same with mine. Its either to much to the left or too much to the right. I just deal with it as my alignment is off pretty bad right now.
  17. Dec 12, 2019 at 1:41 PM
    nk1794
    San Jose, CA
    Guys,
    Just take it to the shop for an alignment and they should be able to set the steering wheel straight for you.
    Sas likes this.
  18. Dec 7, 2021 at 5:03 PM
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    Is there a part II to the how-to video. Is it on a different post?
