Switching to 5w30?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Klowry97, Mar 23, 2020.
  1. Dec 5, 2021 at 9:30 AM
    #61
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Better screenshot of TIS pdf with correct capacity and oil recommendations for anyone interested.
    WAtundra4x4 and Rocko9999 like this.
  2. Dec 5, 2021 at 2:52 PM
    #62
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I use 5w30 in the summer and 0w20 the rest of the year
    Alex38, Sumo91 and Cpl_Punishment like this.
  3. Dec 5, 2021 at 3:08 PM
    #63
    Joe333x
    Joe333x Member
    Boston
    0w20 and 5w30 can both go 10,000 miles if you choose, the viscosity doesnt determine oil change intervals. CAFE standards have nothing to do with improving fuel economy that a consumer would notice, its about fleet fuel economy. Toyota sells millions of vehicles a year. If 0w20 gives them .002 better mpg per vehicle its not something they would advertise but would still help their CAFE requirements. Its very easy to see that when you just look at the oil recommendations for Tundras in Mexico.
    Mike59 and myt1 like this.
  4. Dec 5, 2021 at 3:09 PM
    #64
    Trust86
    Trust86 New Member
    2007 DC
    I been using 5w-30, no issues. Valve train nice and quiet, change oil every 7,500 miles AND it’s super tech :rofl:
    Run amsoil filter though.
    Chip_Tundra and TWJLee like this.
  5. Dec 7, 2021 at 9:45 AM
    #65
    Rocko9999
    Rocko9999 New Member
    So when they spec 5w30 for the same engine in other countries, Mexico, what's the reason?
    Mike59, 14burrito, Trust86 and 2 others like this.
  6. Dec 7, 2021 at 10:02 AM
    #66
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Has the engine changed from 2007 when they used to spec 5W-30?
    Mike59 likes this.
  7. Dec 7, 2021 at 10:12 AM
    #67
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Are people in normal climates still not using 5w-30? Get with the program lol
    CMikeB likes this.
  8. Dec 7, 2021 at 10:44 AM
    #68
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Mexico and other countries do not have the same fuel efficiency requirements. So they can spec 5W30 and still be complaint in that country. Furthermore, this reduces the overall market for 0W20 in Mexico, making it less likely to be available, further encouraging OEMs to spec the more readily available 5W30. Lastly some would argue that the heavier oil will protect better leading to longer life. Also keep in mind that Mexico is hotter than most of the US. Ie Northern Mexico is Southern Arizona climate wise.
    According to TIS, none of the clearances for bearings or anything have changed since 2007. So any viscosity from 0W20 to 20W50 is appropriate based on temperature.
  9. Dec 7, 2021 at 11:02 AM
    #69
    Rocko9999
    My point exactly. We an dispense with the tight tolerances argument.
  10. Dec 7, 2021 at 11:08 AM
    #70
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    Your engine is made for specific oil best to use what is recommended, there is a reason for the synthetic oil. best for cold weather starts and wear.
  11. Dec 7, 2021 at 11:21 AM
    #71
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    A few questions come to mind in regards to this debate…
    So if 0w20 is not up to the task in the 5.7 Tundra…
    A.) is there a large amount of bad used oil analysis such as Blackstone and similar?
    B.) are there more oils related motor failures since the “BIG” switch compared to the Tundras that were issued 5w30?
    There could be a multitude of reasons why the oil weight changed but where is the documentation saying it’s not strong enough to…. And Mexico is nothing like the U.S.A. in any way shape or form (conditions wise).
    nobodyintexas and Cpl_Punishment like this.
  12. Dec 7, 2021 at 11:22 AM
    #72
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Maybe the big question is: are the noises we're noticing in our engines actually a problem or do they just not sound the way we'd like?
    Oey12[QUOTED] likes this.
  13. Dec 7, 2021 at 11:31 AM
    #73
    Oey12
    Oey12 New Member
    Joey
    New York
    I have owned MANY Toyota trucks at this point in my life…
    And frankly I would be down right nervous if my Tundra didn’t the diesel tick. Because everyone one I owned had it and many of their cars/CUVs have it. The Highlander “tick” is definitely one of the quietest but the Tundra’s is hands down quieter than any of the Tacomas or 4Runners I owned…
  14. Dec 7, 2021 at 11:34 AM
    #74
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    The short answer is no.
    For example this truck has been feed nothing but 0W20 every 5k miles and is still going strong
    https://www.tundras.com/threads/high-mile-2015-tundra.95199/
    Another example, look at the wear numbers on this considering the load it was towing, again 0W20 every ~5k
    https://bobistheoilguy.com/forums/t...20-16-tundra-6-175-miles-heavy-towing.312638/
    Some engines are also just ticky. I have a 2017 C63S, spec is 5w40 and it is nearly as loud as the 3UR in my Tundra. Same with my NB Miata, I run T6 5w40 in that as well and its still got a noisy valvetrain. That's just how these engines are.
  15. Dec 7, 2021 at 11:38 AM
    #75
    AZBoatHauler
    So.Arizona
    Actually the deserts are in the north and all the humidity is in the south. :anonymous: The climate here in So. AZ is just as harsh as anything in Mexico.
    pman9003[QUOTED] likes this.
  16. Dec 7, 2021 at 11:39 AM
    #76
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Interesting. I haven't noticed anything similar in my wife's 2013 Corolla or my dad's 2003 Matrix.
  17. Dec 7, 2021 at 11:43 AM
    #77
    Oey12
    Oey12 New Member
    Joey
    New York
    My 2016 Corolla and my 1998 Camry had it but no where near as pronounced. You would almost have to put you ear right near the front driver’s tire. The 3.4’s had a savage tick…I could hear it with the window open.
    Truth be told, I am hypersensitive to vehicle noises for whatever reason ;)
  18. Dec 7, 2021 at 12:04 PM
    #78
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Thanks for clarifying. I was trying to say that Southern Arizona and Northern Mexico are similar temperature wise, words are hard lol. I was going off this map of average temperatures.
    As far as an engine is concerned. Hot and humid is only slightly better than just hot. Thermal conductivity and capacitance will go up with humidity, and engine power goes down as humidity goes up. *EDIT* I had the wrong graph here.
    AZBoatHauler[QUOTED] likes this.
  19. Dec 7, 2021 at 12:21 PM
    #79
    AZBoatHauler
    So.Arizona
    You've got your data to back you up! I think the graphic is somewhat flawed because the average temps in the north are driven down by the wide range of temps you see in a desert - extreme heat in the day but nothing to hold the heat when the sun goes down so the temp drops 40-45 degrees. Here are the monthly temps from Villahermosa, Mx which is in the darkest red area near the Yucatan in the south - nothing compared to the 110 average of Yuma, AZ in the summer.
    Villahermosa, Tabasco, Mexico
    Weather averages
    MonthHigh / Low(°F)
    January 82° / 68°
    February 85° / 69°
    March 90° / 71°
    April 94° / 75°
    May 96° / 76°
    June 94° / 76°
    July 93° / 76°
    August 92° / 76°
    September 91° / 76°
    October 88° / 75°
    November 85° / 72°
    December 83° / 70°
    Yuma, AZ
    Weather averages
    MonthHigh / Low(°F)
    January 71° / 44°
    February 75° / 46°
    March 83° / 51°
    April 89° / 55°
    May 97° / 61°
    June 106° / 69°
    July 110° / 77°
    August 109° / 77°
    September 104° / 70°
    October 93° / 59°
    November 80° / 49°
    December 69° / 42°
  20. Dec 7, 2021 at 2:30 PM
    #80
    Joe333x
    Joe333x Member
    Boston
    The same engine is in other vehicles, as well as in Tundras in Mexico and is recommended a wide variety of oil from Toyota themselves. Synthetic oil comes in many varieties, not just 0w20. I run full synthetic of what ever viscosity I am using.
    I don't think anyone is arguing that 0w20 is going to cause engine failure. It will work, it just is not necessary to use it unless you are in some crazy extremely cold climate.
  21. Dec 7, 2021 at 2:53 PM
    #81
    Trust86
    Trust86 New Member
    2007 DC
    Checked my super tech oil level today, all good. Looks brand new and it’s due in ~1000 miles. Next oil change will be with Fram ultra synthetic oil filter, same micron rating as amsoil I believe. Oh and 3 quarts of 0w-40 amsoil signature series, and 5 quarts of 5w-40 Castro edge. Why? Bc it was free. Flame suit on :bananadead:
  22. Dec 7, 2021 at 2:56 PM
    #82
    Oey12
    Oey12 New Member
    Joey
    New York
    …But that’s kinda my point…
    If it’s (0w20) isn’t going to cause a failure why use 5w30? I honestly do not believe it’s that much more stout.
    And I BELIEVE but could absolutely be wrong but doesn’t an engine receive the most wear at startup? Making a 0 weight perfect for any startup in any climate because it lubricants faster.
    mtucker and Cpl_Punishment like this.
  23. Dec 7, 2021 at 3:06 PM
    #83
    Joe333x
    Joe333x Member
    Boston
    Yes 0w20 does give the best start up protection since its the thinnest of recommend oils at below freezing temperatures but also is going to be very thin in hot climates. For example if you live in Saudi Arabia the Land Cruisers over there can run 20w50. If you're in a hot weather climate a heavier oil is going to give you better wear protection. Oil viscosities have more to do with the climate you're running them in than anything else. In the end fresh quality oil changed frequently is going to keep your engine running but to me just the sound difference between 0w20 and 5w30 is clear that the engine prefers the 5w30 and likes 15w40 even better when its summer time.
    Sumo91 and Oey12[QUOTED] like this.
  24. Dec 7, 2021 at 3:16 PM
    #84
    Oey12
    Oey12 New Member
    Joey
    New York
    In regards to the sounds I find the TGMO 0w20 to be hands down the quietest followed by Amsoil SS 0w20. I prefer Mobil 1 over many other brands but the AFE made my 2017 4Runner so noisy that I changed the oil early. People say I am crazy but there are different sounds among different oils. Hence why I seek out TGMO because it stays extremely quiet over the OCI.
  25. Dec 7, 2021 at 3:24 PM
    #85
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I live in a hot climate, I prefer a slightly thicker oil, it provides better wear protection on start up, if I were in a cold climate, I'd switch back to 0w20. 5w30 has a higher shear viscosity as well, which means that if the oil gets hot, it's less likely to shear out of grade as a lighter weight oil.
    5w30 bonus perks- engine is much more quiet than with 0w20.
    Myhobbes25, Punk1974 and Joe333x like this.
  26. Dec 7, 2021 at 4:39 PM
    #86
    Chip_Tundra
    Chip_Tundra New Member
    Switched to 5w-30 after 1000 miles of driving my truck and never looked back. Using either Supertech or Kirkland brands and changing every 5000 miles.
  27. Dec 7, 2021 at 5:57 PM
    #87
    joesTundra
    Joe
    sounds like a lot of oil experts in this conversation, enjoy
    georgiey22 likes this.
  28. Dec 8, 2021 at 12:48 AM
    #88
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Here’s another good conversation point for the oil experts: I only use conventional (aka dinosaur) oil in my brand new 5.7, 15w40 in summer and 10w30 in winter. Too bad the engine can’t read what is written on the label. My OCI is 2500 miles.
  29. Dec 8, 2021 at 12:58 AM
    #89
    Sumo91
    TN
    Why not go with a synthetic and quadruple your OCI to 10k? 2500 OCI seems like a waste of good Dino oil
    Alex38 and myt1 like this.
  30. Dec 8, 2021 at 1:03 AM
    #90
    sd172
    sd172 New Member
    South Dakota
    It doesn’t matter if it is a synthetic or a Dino oil. As soon as you burn an x amount of gas (which has a boat load of aromatics in it to keep the octane up) you end up with soot contamination of your oil. The dispersant package in your oil can only hold a certain amount of soot in suspension. After that the sludge will start to form.
