Shifter boot mod
Discussion in '2.5 Gen Tundras (2014-2021)' started by Andrew19, Jul 12, 2019.
  1. Dec 23, 2019 at 8:45 PM
    #121
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Does anybody know if we can do this on 2nd Gens??
  2. Dec 23, 2019 at 8:55 PM
    #122
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Look at post #87 of this thread.
  3. Oct 18, 2021 at 2:08 PM
    #123
    Joe Mamma
    Joe Mamma New Member
    Bakersfield CA
    2021 Tundra TRD Pro Crewmax MGM
    I'm going to order this from red line goods as well. I think it looks great, did you order the standard length or go shorter? Also do you have details on the install, I'm curious how it stays up under the shift knob.
  4. Oct 18, 2021 at 2:45 PM
    #124
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Tell you the truth, I can't remember as it's been a while. I would venture to guess that it's standard.
    For your second question, I just used a pry tool around the leather surround after unscrewing the shift knob. It should all come up as one piece as they are held down with yellow clips. You'll notice that the shifter area is gapped between that and the rest of the console area. I curled the top part of the shift boot so that it would hug the shift knob and hide the edges as well as the chrome at the bottom of the knob. The rest of it was wrapped around the shifter area. When you place the leather surround back on it, it should keep the boot in place due to the pressure of the yellow clips. I tested it by moving the shifter back and forth a few times and once I was satisfied with it moving freely in all positions, I then made sure all corners were to my likings. You just gotta make sure the creasing of the boot is to your likings.
    If you got further questions or need additional clarifications, don't hesitate to ask. I wouldn't worry about screwing anything up as it's essentially "plug and play" once you mess around with it.
    Wynnded likes this.
  5. Oct 18, 2021 at 3:14 PM
    #125
    Joe Mamma
    Bakersfield CA
    Awesome that all makes sense thank you
  6. Dec 6, 2021 at 12:13 PM
    #126
    Joe Mamma
    Bakersfield CA
    Finally got this done. Being extremely OCD it took time and multiple attempts to get it where I was satisfied and or frustrated enough to leave it be.
    I ordered a Tacoma TRD Pro shift knob on Amazon.
    I also ordered an aftermarket black Tacoma shift boot retainer on Etsy from seller TrailbreakerCustoms.
    The shift boot was ordered from redline goods. I requested 3” extra length, specifically 2” added to the top “neck” and 1” added to the bottom “flare”. This allowed extra neck length to compensate for the shorter Tacoma knob and all the movement required between positions. The extra bottom material allowed enough coverage to stay wrapped around the shifter box when shifting without pulling the boot up over the edges.
    Finally I used an O-ring instead of a zip tie to secure the boot onto the retainer. This eliminates the bulge at the zip tie lock, O-ring size was trial and error I don’t know the size, I grabbed a handful of small O-rings and tried a few until one fit nice and snug in the retainer groove.
    The rest of the install is pretty straightforward.
    FBCA99E0-4075-4A84-BF5C-71B3226AF5B9.jpg 57ADA47C-812C-449A-B48F-000F9717ED40.jpg C92A0E08-702A-47DC-A8EA-1B60C83103EB.jpg
  7. Dec 6, 2021 at 7:00 PM
    #127
    Tundra John
    Tundra John New Member
    2020 Tundra Platinum 4x4
    4” Readylift, Fuel 20” tires w/ Kenda 35”x12.5 tires, tint, dechromed, Custom Platinum Badging, Running Boards, Auto tailgate lock, LED swap, Changed out stereo system, VLeds Interior floor lights, DirtyDeeds 8” exhaust, TRD air filter, wrapped interior silver components,
    The Redline shifter boot is a very good quality and you could customize it.
    I havent installed mine and I am curious how someone installed the boot the way in the picture.
  8. Dec 6, 2021 at 8:13 PM
    #128
    Joe Mamma
    Bakersfield CA
    Yes I’m happy with the quality of the Redline boot. Be advised that if you ordered the standard length it will be a bit too short to use with a Tacoma shift knob. I thought to glue it on my Tundra shift knob but wanted something cleaner and done right.
    That picture looks like they cut the plastic face of the shift box.
  9. Dec 6, 2021 at 8:14 PM
    #129
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
  10. Dec 6, 2021 at 8:15 PM
    #130
    Joe Mamma
    Bakersfield CA
    Now that’s cool
    Clemshady[QUOTED] likes this.
  11. Dec 7, 2021 at 11:32 AM
    #131
    Clemshady
    Jeff
    Thank you sir. :thumbsup:
  12. Jan 18, 2022 at 12:19 PM
    #132
    rattmobbins
    rattmobbins New Member
    2021 Platinum 4x4
    This is the way. My OCD and desire for as OEM a look as possible drove me on a multi-night search to find that piece from Trailbreaker, only to discover he's out of them. Doh! Said he should have more in the next week, so until then, my Tacoma TRD Pro knob will sit and await it's newfound home in my Tundra.
  13. Jan 21, 2022 at 9:32 AM
    #133
    CGP
    CGP New Member
    It’s back in stock if anyone is looking.
    rattmobbins[QUOTED] likes this.
  14. Jan 24, 2022 at 4:24 PM
    #134
    Trailbreaker
    Trailbreaker New Member
    Rick
    2021 Silver 1794 4x4 OR
    Yep, back in stock. Sorry everyone, i was moving and had to let a few things sell out for a while.
    Clemshady and rattmobbins like this.
  15. Jan 24, 2022 at 4:43 PM
    #135
    SteyrM40A1
    SteyrM40A1 New Member
    Gregg
    2018 Toyota Tundra Crew Max SR5 TRD Sport, Magnetic Grey
    Air flow accelerator mod, charcoal filter delete. LED interior lights.
    Could you post a link to your install instructions?
  16. Jan 24, 2022 at 4:47 PM
    #136
    Don't have any.
    Very simple.
    Get a Tacoma TRD shifter
    Boot from Ebay
    Pull silver trim off
    Remove original handle
    Slip boot on, tuck in
    Clip silver trim back
    Screw on new handle.
  17. Jan 24, 2022 at 4:59 PM
    #137
    Clemshady
    Jeff
    I ordered from you last night. Smooth transaction and waiting to receive it. Thanks.
    Trailbreaker[QUOTED] likes this.
  18. Jan 24, 2022 at 5:07 PM
    #138
    SteyrM40A1
    Gregg
    Nice. Seems simple enough. Thx
  19. Jan 24, 2022 at 5:11 PM
    #139
    Trailbreaker
    Rick
    Thanks! I am dropping it off at the post office in the morning.
    Also, for future installs there is a large groove in the front of the collar that was designed to capture the head of the zip tie so there is no bulge. I will post a screen shot if it next time i fire up my CAD.
  20. Jan 24, 2022 at 5:15 PM
    #140
    SteyrM40A1
    Gregg
    What keeps the boot from sliding down the shifter?
  21. Jan 24, 2022 at 5:23 PM
    #141
    :hattip:
  22. Jan 24, 2022 at 5:24 PM
    #142
    The stiffness of the boot material.
  23. Jan 25, 2022 at 5:13 AM
    #143
    Trailbreaker
    Rick
    As promised, circled in red here ...
    The highlighted area in blue here below as well. Just smash the boot material into there, line up the zip tie head about where the groove is, bend around the corners, tighten with finger pressure applied; It should keep out of the way (especially if you install it reversed, to where the head is pointing inward). The Tacoma has a seam in this location to aid with feeding the zip tie through in reverse, but you may not have a boot seam oriented this way unless you planned for it. Either way, not a big deal as I supply low-profile head zip ties as well for maximum hide ability, so either way should be free of bulge.
    rattmobbins and Taco-Spike like this.
  24. Jan 28, 2022 at 5:21 PM
    #144
    CGP
    CGP New Member
    Got that collar from TrailBreaker installed. I like it a lot!
  25. Feb 1, 2022 at 4:05 PM
    #145
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    I’m pretty happy with it
  26. Feb 1, 2022 at 4:29 PM
    #146
    BlancaLaGordita
    BlancaLaGordita New Member
    Blanca
    2021 Tundra TRD Sport
    not as fancy as some of you guys but... i made this one myself and i like it a lot. ;)
    also..... in case you missed it
  27. Feb 1, 2022 at 5:47 PM
    #147
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  28. Feb 1, 2022 at 6:04 PM
    #148
    BigdaddyII
    South Louisiana
    2019 Ram 1500
    Wynnded[QUOTED] likes this.
  29. Feb 1, 2022 at 8:03 PM
    #149
    Pac12AfterDark
    Pac12AfterDark New Member
    This has been one of my favorite mods so far.
  30. Feb 2, 2022 at 5:37 PM
    #150
    BigdaddyII
    South Louisiana
    2019 Ram 1500
    Looks great! How did you make it?
