Catalytic converter security shield
Discussion in 'General Tundra Discussion' started by IBeam, Dec 6, 2021.
  1. Dec 6, 2021 at 9:10 AM
    IBeam
    IBeam [OP] New Member
    Southeast Texas
    2021 SR5 CM 4x4 Trail Edition, bed-mounted M2
    I am concerned about the 4 cats getting stolen off of my 2021, or at least the front ones (and my sons 2006 4Runner) in light of the exponential rise of such thefts around the country, especially in trucks and SUVs (and the friggin insane replacement costs), so I will be buying some cat plates. I will likely go with Desert Eagle Offroad in Dallas for my Tundra shield. I talked with the owner Kent. Seems a real solid, experienced guy. He said he's been making these for 9 years and he can barely keep up with demand, including dealer purchases. The total cost to me, including the security ("S") Torx bolts - delivered to me in Houston - would be $350. It is powder coated 10 gauge steel, 45 pounds, and mounts with four bolts between the two cross members. Per Ken, it will block removal of the front cats and the rear cats will be covered on the upstream front end side (so a thief trying to remove the rear ones is greatly impeded.
    (1) Anyone installed a DEO shield?
    (2) This is probably a foolish question, but am I safe in assuming that the 45 pound weight is of no concern in terms of sag, ride quality, or premature wear of components?
    Feedback is appreciated from the Tundra family !
    Mike59 likes this.
  2. Dec 6, 2021 at 9:30 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    If I was you, I would go with the valhallas sheild, for the simple fact that the DE plate only does half the job. Your rear cats will still be completely exposed. If you are dead set on the DE plate, at a minimum, you should order the Valhallas rear extender plate to cover the rear cats.
    AggiePhil, Taco-Spike and Uhhhh.... like this.
  3. Dec 6, 2021 at 9:37 AM
    The Towse Tundra 2.0
    The Towse Tundra 2.0 New Member
    Loy
    2021 Lunar Rock Tundra TRD Pro Crewmax
    TRD Inlay Package, Spray-in Bedliner, Cargo LED Light, Power Tailgate Lock, Center Console Safe, MX4 Bakflip Tonneau Cover, CaliRaised LED Rock Sliders, Nitto Ridge Grapplers 275/70/18, Rigid Industries Amber Fog Light Covers, Coachbuilder TRD Pro lift kit
    If you’re going to go with full protection I would highly recommend all aluminum. It dissipates heat better than steel. Covering all four CATS also covers your transmission which could overheat if not properly ventilated.
    This is what Toyota recommended for longevity of the truck.
  4. Dec 6, 2021 at 9:38 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Also, Valhalla offers aluminum plates for more not heaviness.
    NewImprovedRon and Taco-Spike like this.
  5. Dec 6, 2021 at 9:43 AM
    MadMaxCanon
    I have the full steel setup and have had 0 issues with heat, even without a tranny cooler. However, I will be adding a tranny cooler soon anyway since it SHOULD be there anyway and cooler is always better. I have already bashed them pretty hard and the steel didnt even get a dent. I think the weight difference is pretty minimal in the grand scheme of things.
    NewImprovedRon likes this.
  6. Dec 6, 2021 at 10:46 AM
    IBeam
    Southeast Texas
    Thanks for the input MadMaxCanon. As I noted, unless I missed something, mounint a shield like this (between the two cross beams) covers the front portion of the rear cats and keep a thief from being able to cut off both ends of the rear cats.
  7. Dec 6, 2021 at 10:47 AM
    tyst8
    tyst8 New Member
    PHX, AZ
    got the Valhalla front and rear plate installed last week. I can park it knowing it will take a lot of work for someone to cut thru those plates. is your '21 a 4x4 or a 2x4? I recall reading that the Valhalla rear plate doesn't protect very well for a 2x4.
  8. Dec 6, 2021 at 10:57 AM
    IBeam
    Southeast Texas
  9. Dec 6, 2021 at 10:59 AM
    IBeam
    Southeast Texas
    Mine is a 2021 4x4 (not the TRD)
  10. Dec 6, 2021 at 11:13 AM
    tyst8
    tyst8 New Member
    PHX, AZ
    okay you will be fine.
  11. Dec 6, 2021 at 12:33 PM
    steved0xTD
    steved0xTD New Member
    2020 Tundra SR5 4x4 TRD Off-road
    There was a post on the Valhalla thread about a RWD Desert Eagle plate owner that had the plate installed and had the cats stolen, they just cut before and after the plate and snaked them out. The 2WD Tundras have a lot more empty space up there vs 4WD that fills the space with transfer case and front drive shaft and front diff.
    https://www.tundras.com/threads/val...-and-ordering-post.84911/page-83#post-2490053
    tyst8[QUOTED] likes this.
  12. Dec 6, 2021 at 1:25 PM
    IBeam
    Southeast Texas
    Dang
  13. Dec 6, 2021 at 1:40 PM
    RobertD
    Robert
    DFW, Texas
    Don't give this guy your money... many different posts/threads on it.
    Go with Valhalla. @Classy63 is amazing to work with, great communication, and an honest dude. Just look at all the posts in his thread. Dude does everything he can to be transparent and get you a great product. I have the thinner steel plates for front and rear. Feel safe leaving my truck outside and have not noticed any decrease in ride quality or mpg.
    tyst8, Uhhhh...., Classy63 and 2 others like this.
  14. Dec 6, 2021 at 1:45 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Why not? Has there been any issues with them other than he allegedly stole Valhallas design? Not being a smart ass or trying to start a debate, just curious if theres been issues with his product or customer service?
  15. Dec 6, 2021 at 1:48 PM
    RobertD
    Robert
    DFW, Texas
    That, he's been unresponsive. Just seems shady. I'm not saying he is. But given the choice between supporting someone who is actively on this forum and is as open as Tyler is at Valhalla, and supporting some unknown entity that flaked after 1 post on this forum when people raised issues about their experience. I know where I'd put my money, and I did lol
  16. Dec 6, 2021 at 3:46 PM
    I have the DE front shield and the Valhalla rear shield. The truck won't even notice the weight.
  17. Dec 6, 2021 at 4:08 PM
    TL TRDPro LR
    TL TRDPro LR New Member
    Troy
    SoCal/Idaho
    2021 TRD Pro Lunar Rock CM
    Yep. Go with Valhalla’s Shield front and back covers and spend the extra couple hundred bucks on your ‘21 truck (it’s worth it) and then rest easy!
  18. Dec 6, 2021 at 4:17 PM
    He used to work for the old company known as OrFab. That's where his design came from. His communication was hit and miss. Sometimes he would respond to your text, sometimes not. One week he was making mass orders for dealers, the next week he says he wasn't going to any longer because he couldn't keep up. I have the DE shield because one of the other members on here had a lead to a dealer that had them in stock, and Valhalla was not on the forum yet at that time. Otherwise, I would have both Valhalla plates.
  19. Dec 7, 2021 at 7:33 AM
    IBeam
    Southeast Texas
    You folks are too cool. Thanks.
    I also have had some frustration with correspondence with Talon's Garage.
    I see on the Valhalla site...
    Aluminum front cat theft deterrent/transmission plate (valhallasshields.com)
    ...that the front and rear aluminum shields are offered in 3/16 or a 1/4" . Who thinks that 3/16" aluminum plate be a bit on the bendable, "cuttable" side?
    I reached out to Tyler at Valhalla and he notes that the use of just the front shield will leave the rear cats totally vulnerable (I was assuming that the rear cats would be partially covered if just the front shield was used)
    BTW - Do thieves target the rear cats? It is my understanding that the front ones are the big prize in terms of precious metals that they can sell...
  20. Dec 7, 2021 at 7:34 AM
    I have steel on mine. Yes, they will target front and rear cats.
  21. Dec 7, 2021 at 7:42 AM
    tyst8
    tyst8 New Member
    PHX, AZ
    I have the aluminum front and rear plate, 3/16. the front plate has a very very very slight wobble if you push up against it, other than that, it is durable. I took it to some med trail last weekend and nothing happened to it. And since you have the 4x4, make sure to remove the black case on your transfer case when installing the rear plates else you are going to notice vibration.
  22. Dec 7, 2021 at 7:44 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    No issues combining the different brands of shields and fitment?
    My dealer is putting some kind of shield on mine when my cats come in.
    I don't know the brand name.
    I would buy front and rear from Valhalla, but I can't wait for them.
    Being my theft happened at my employment parking lot, I don't want to go one day without something covering something.
    But I considered adding Valhalla's rear cover..
  23. Dec 7, 2021 at 7:46 AM
    MadMaxCanon
    If you are from Texas, it is likely the DE plate. Ken said the dealerships in Texas were snatching up his plates fast. That also means your rear cats will be exposed.
    1lowlife[QUOTED] likes this.
  24. Dec 7, 2021 at 7:47 AM
    MadMaxCanon
    Can you have your employer pay for the repairs since it happened on their property?
  25. Dec 7, 2021 at 7:56 AM
    No issues at all. It's just a matter of drilling holes. I have mine where the bolts go through both plates. I did the same with the RCI. My front plate has 8 bolts total IIRC.....I'll have to look.
  26. Dec 7, 2021 at 7:59 AM
    TL TRDPro LR
    Troy
    SoCal/Idaho
    3/16 Aluminum here and they are going on tomorrow but just from opening the packaging they seem very strong and Tyler has stated that they are not bendable - nothing is 100% bullet proof if someone wants your cats but mine are bright red and relay the message to move on to the next truck…
    1lowlife likes this.
  27. Dec 7, 2021 at 8:15 AM
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    I have front/rear 1/8 shields and front skid plate. I can tell you they work. Long story short, I parked in a unlit parking lot for several hours one night, someone tried to steel my cats. They tried to unbolted the rear shield and only got the rear right bolt out and gave up. I found the bolt and nut cast aside and reinstall it the next morning. Police came and told me how lucky I was to have the shields, if not I’d be waiting on new cats….
    1lowlife and MadMaxCanon like this.
  28. Dec 7, 2021 at 8:16 AM
    I'm glad I went with security bolts on mine.
    ealxele and MadMaxCanon like this.
  29. Dec 7, 2021 at 8:21 AM
    kittyhawk
    Dave
    I upgraded two weeks ago.
    Tundra234[QUOTED] likes this.
  30. Dec 7, 2021 at 8:27 AM
    IBeam
    Southeast Texas
    That's awesome kittyhawk. For the front and rear 1/8" steel plates, that is a total of sixty-some pounds. Do you notice that in the ride or handling?
    BTW - I see a Buffalo Texas reference in your member info. Do you know any Burtons up there? I used to work with one of the sons.
    kittyhawk[QUOTED] likes this.
